函數(shù)的復(fù)用性表現(xiàn)為庫
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時間:2013年06月09日   【字體:
//引入函數(shù)庫頭文件
#include <curl/curl.h>
#include <string.h>
//用#pragma comment預(yù)編譯命令,表示這個程序?qū)⑹褂胕bcurld_imp.lib這個庫文件
#pragma comment(lib,"libcurld_imp.lib")
//復(fù)制將數(shù)據(jù)寫入文件的回調(diào)函數(shù)
size_t write_data(void *ptr, size_t size,size_t nmemb,FILE *stream) {
    int written=fwrite(ptr,size,nmemb,stream);
    return written;
//使用函數(shù)庫提供函數(shù)實(shí)現(xiàn)的文件下載函數(shù)
CURLcode download( char* url,
                   char* out)
 CURL *curl = NULL;
 FILE *fp = NULL;
 CURLcode res;
//調(diào)用函數(shù)庫中的curl_easy _init()函數(shù)完成初始化
curl = curl_easy_init();
if (curl)
    fp=fopen(out,"wb");
    curl_easy_setopt(curl,CURLOPT_URL, url);
    curl_easy_setopt(curl,CURLOPT_WRITEFUNCTION, write_data);
    curl_easy_setopt(curl,CURLOPT_WRITEDATA, fp);
res=curl_easy_perform(curl);
curl_easy_cleanup(curl);
//下載完成,進(jìn)行最后的清理工作
fclose(fp);
return res;
return CURLE_FAILED_INIT;
//輔助函數(shù),用于獲取文件名
void getfilename(char* url, char* name)
char* pos = strrchr(url,"/");
if (NULL!=pos)
  strcpy(name,pos+1);
int main(int argc,char* argv[])
if (2!=argc)
  return -1;
 char* url = argv[1];
 char name[32];
 getfilename(url,name);
 CURLcode res = download(url,name);
if(CURLE_OK==res)
  printf("great! download %s as %s succerfully.",url,name);
 printf("sorry:cannot download %s.",url);
 return 0;
