電路圖:
protues仿真文件和完整代碼下載地址:http://www.torrancerestoration.com/bbs/dpj-20399-1.html
下面是部分程序代碼:
#include"reg51.h"
#include"intrins.h"
#include"math.h"
#include"absacc.h"
#define PORTA XBYTE[0x8500]
#define PORTB XBYTE[0x8502]
#define PORTC XBYTE[0x8504]
#define PORTC0 XBYTE[0x8506]
#define nop _nop_()
#define Right_RUN 1
#define Left_RUN 0
unsigned long RunSpeed=76;
unsigned char RUNState=1;
sbit RS=P2^0;
sbit RW=P2^1;
sbit E=P2^2;
sbit P17=P1^7;
bit flag=0;
unsigned char xx[]="speed(n/min):";
unsigned char SD[]="76";
char state[2][14]={"direction:cw","direction:ccw"};
unsigned char FLG,INMA=0;
unsigned char t,s=0x01;
unsigned int a;
main()
void OPJIAN();
unsigned char JIAN();
unsigned char JIANZHI();
void speed();
void SHOW_LCD();
void show_state();
void write1();
void writ2(unsigned char i);
void delay();
void time();
void busy();
unsigned char i;
i=0x90;
PORTC0=i;
i=0x01;
TMOD=i;
t=0x10;
a=0x0f;
TH0=0x10;
TL0=0x0f;
FLG=INMA;
SHOW_LCD();
show_state();
EA=1;
ET0=1;
TR0=1;
i=JIAN();
if(i!=0)
time();
time();
i=JIAN();
if(i!=0)
INMA=JIANZHI();
OPJIAN();
time();
if(FLG!=INMA||flag==1)
{ FLG=INMA;
SHOW_LCD();
show_state();
flag=0;
void SHOW_LCD()/*lcd設置程序*/
P1=0x38;
write1();
delay();
P1=0x38;
write1();
delay();
P1=0x38;
write1();
delay();
P1=0x01;
write1();
delay();
P1=0x0f;
write1();
delay();
P1=0x06;
write1();
delay();
P1=0x0c;
write1();
void show_state()/*狀態(tài)顯示程序*/
unsigned char i=0;
P1=0x80;
write1();
while(xx[i]!='\0')
writ2(xx[i]);
i++;
delay();
i=0;
while(SD[i]!='\0')
writ2(SD[i]);
delay();
i++;
P1=0xc0;
write1();
i=0;
if(RUNState==Right_RUN)
while(state[0][i]!='\0')
writ2(state[0][i]);
i++;
if(RUNState==Left_RUN)
while(state[1][i]!='\0')
writ2(state[1][i]);
i++;
void write1()/*lcd寫控制字*/
RS=0;
RW=0;
E=0;
busy();
E=1;
void writ2( unsigned char i)/*lcd寫數(shù)據(jù)*/
{ P1=i;
RS=1;
RW=0;
E=0;
busy();
E=1;
void delay()/*延時程序*/
unsigned char i;
for(i=0;i<100;i++)
i=i;
void time()
{ unsigned char i,j;
for(i=0;i<100;i++)
for(j=0;j<30;j++)
j=j;
void busy() //判斷LCD是否忙
do
P1=0xff;
RS=0;
RW=1;
E=0;
nop;
E=1;
}while(P17==1);
unsigned char JIAN()/*判斷是否有鍵按下*/
unsigned char i,j;
i=0xff;
PORTA=i;
time();
i=0x00;
PORTB=i;
j=PORTA;
j=~j;
j=j&(0x0f);
return j;
unsigned char JIANZHI()/*讀鍵值程序*/
unsigned i,j,d,k,m=1;
i=0xfe;
k=0x01;
do
PORTB=i;
j=PORTA;
m=j&(0x01);
if(m==0)
d=k/2;
m=j&(0x02);
if(m==0)
d=k/2+4;
m=j&(0x04);
if(m==0)
d=k/2+8;
m=j&(0x08);
if(m==0)
d=k/2+12;
k=k+2;
i=i<<1;
i=i|(0x01);
}while(m!=0);
return d;
void OPJIAN() /* 鍵值處理程序*/
switch(INMA)
case 0x08: {RUNState=Right_RUN;s=0xf7;}break;
case 0x09: {RUNState=Left_RUN;s=0x01;}break;
case 0x0b: {
flag=1;
t=t-2;
RunSpeed=5000000/(65536-t*256-a);
speed();}break;
case 0x0f: {flag=1;
t=t+2;
speed();}
void speed()/*速度處理程序*/
unsigned char i=0;
SD[0]=RunSpeed/100+48;
SD[1]=RunSpeed%100/10+48;
SD[2]=RunSpeed%10+48;
void time1(void) interrupt 1 using 2
TR0=0;
PORTC=s;
if(RUNState==0)
s=(s<<1);
if(s==0x10)
s=0x01;
s=s>>1;
if(s==0x0f)
s=0xf7;
TH0=t;
TL0=a;
TR0=1;
