基于51單片機(jī)的雙人對(duì)戰(zhàn)小游戲的實(shí)現(xiàn)
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年10月20日   【字體:
#include<AT89X52.h>
unsigned char position1=1;//position一共有3種狀態(tài),0代表最邊上,1代表初始位置,2代表最前的位置
unsigned char position2=1;//position一共有3種狀態(tài),0代表最邊上,1代表初始位置,2代表最前的位置
unsigned char fist1=0;//1沒(méi)有出拳
unsigned char fist2=0;//2沒(méi)有出拳
unsigned char leg1=0;//1沒(méi)有出腳
unsigned char leg2=0;//2沒(méi)有出腳
unsigned char count_back1=0;
unsigned char count_back2=0;
unsigned char count_forth1=0;
unsigned char count_forth2=0;
unsigned char time0_count=0;
unsigned char time1_count=0;
unsigned char blood1=7;
unsigned char blood2=7;
unsigned char buff1[16]={0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//右邊小人的初始形態(tài)
                                                0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00};
unsigned char buff2[16]={0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//右邊小人的初始形態(tài)
//定義兩名選手的操作鍵
//選手1
#define S11 P1_0//向前
#define S12 P1_1//后退
#define S13 P1_2//出拳
#define S14 P1_3//出腿
//選手2
#define S21 P1_4//向前
#define S22 P1_5//向后
#define S23 P1_6//出出
#define S24 P1_7//腿拳
//兩個(gè)選手的led點(diǎn)陣行掃描使能端
#define A_1 P0_0
#define B_1 P0_1
#define C_1 P0_2
#define D_1 P0_3
//兩個(gè)選手的2個(gè)595使能端
#define SCLK P2_0
#define SI P2_1
#define RCLK P2_2
//當(dāng)按下S1時(shí) 開(kāi)始游戲,游戲結(jié)束時(shí)顯示哪方獲勝,然后按下S2鍵后重新開(kāi)始新一輪游戲
#define S1 P2_6
#define S2 P2_7
//第一個(gè)人的74HC154區(qū)域行選
#define NUMLED1OPEN(); {D_1=0;C_1=0;B_1=0;A_1=0;};
#define NUMLED2OPEN(); {D_1=0;C_1=0;B_1=0;A_1=1;};
#define NUMLED3OPEN(); {D_1=0;C_1=0;B_1=1;A_1=0;};
#define NUMLED4OPEN(); {D_1=0;C_1=0;B_1=1;A_1=1;};
#define NUMLED5OPEN(); {D_1=0;C_1=1;B_1=0;A_1=0;};
#define NUMLED6OPEN(); {D_1=0;C_1=1;B_1=0;A_1=1;};
#define NUMLED7OPEN(); {D_1=0;C_1=1;B_1=1;A_1=0;};
#define NUMLED8OPEN(); {D_1=0;C_1=1;B_1=1;A_1=1;};
#define NUMLED9OPEN(); {D_1=1;C_1=0;B_1=0;A_1=0;};
#define NUMLED10OPEN(); {D_1=1;C_1=0;B_1=0;A_1=1;};
#define NUMLED11OPEN(); {D_1=1;C_1=0;B_1=1;A_1=0;};
#define NUMLED12OPEN(); {D_1=1;C_1=0;B_1=1;A_1=1;};
#define NUMLED13OPEN(); {D_1=1;C_1=1;B_1=0;A_1=0;};
#define NUMLED14OPEN(); {D_1=1;C_1=1;B_1=0;A_1=1;};
#define NUMLED15OPEN(); {D_1=1;C_1=1;B_1=1;A_1=0;};
#define NUMLED16OPEN(); {D_1=1;C_1=1;B_1=1;A_1=1;};
//0是第一個(gè)選手的索引表的開(kāi)始 80是第二個(gè)選手開(kāi)始在表中的位置
#define START1 0
#define START2 80
#define INIT 16//第一個(gè)選手從的初始狀態(tài)在中間 為16
#define JUMP_UP_AND_BACK1 48//向后跳起的緩沖動(dòng)作的位置
#define JUMP_UP_AND_BACK2 64//向后跳起的緩沖動(dòng)作的位置
#define BACK 0//在最邊后面的狀態(tài)的位置
#define FORTH 32//在最前面的狀態(tài)的位置
#define GO 0//游戲的開(kāi)始畫(huà)面 然后按S1開(kāi)始游戲
//#define KO 32
#define P1_WIN 64//顯示P1勝利在索引表中的位置
#define P2_WIN 96//顯示P2勝利在索引表中的位置
//圖像表
//人物的各種形態(tài)和位置
unsigned char code role_action[]=
0x00,0x0C,0x12,0x12,0x0C,0x0C,0x3F,0x33,//左邊小人后退一步的狀態(tài)0
0x33,0x12,0x1E,0x12,0x12,0x12,0x12,0x00,
0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//左邊小人的初始形態(tài)16
0x66,0x24,0x3C,0x24,0x24,0x24,0x24,0x00,
0x00,0x30,0x48,0x48,0x30,0x30,0xFC,0xCC,//左邊小人前進(jìn)一步的狀態(tài)32
0xCC,0x48,0x78,0x48,0x48,0x48,0x48,0x00,
0x18,0x24,0x24,0x18,0x18,0x66,0x66,0x65,//左邊小人向右后方向跳起的動(dòng)作1 48
0x24,0x3C,0x24,0x12,0x12,0x12,0x00,0x00,
0x0C,0x12,0x12,0x0C,0x0C,0x33,0x33,0x53,//左邊小人向右后方向跳起的動(dòng)作2 64
0x12,0x1E,0x12,0x24,0x24,0x24,0x00,0x00,
0x00,0x30,0x48,0x48,0x30,0x30,0xCC,0xCC,//右邊小人后退一步的動(dòng)作80
0x00,0x18,0x24,0x24,0x18,0x18,0x7E,0x66,//左邊小人的初始形態(tài)96
0x00,0x0C,0x12,0x12,0x0C,0x0C,0x33,0x33,//右邊小人前進(jìn)一步的狀態(tài)112
0x18,0x24,0x24,0x18,0x18,0x66,0x66,0xA6,//右邊小人向左后方向跳起的動(dòng)作1 128
0x24,0x3C,0x24,0x48,0x48,0x48,0x00,0x00,
0x30,0x48,0x48,0x30,0x30,0xCC,0xCC,0xCA,//右邊小人向左后方向跳起的動(dòng)作2 144
0x48,0x78,0x48,0x24,0x24,0x24,0x00,0x00
//開(kāi)機(jī)畫(huà)面和結(jié)束時(shí)顯示哪方勝利的索引表
unsigned char code welecome_and_end[]=
0x00,0x00,0x00,0x04,0xF9,0xF4,0xF9,0xF4,0x00,0x04,0xF9,0xF4,0xF9,0xF4,0x00,0x00,
0x00,0x04,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//GO!!!  0
0x00,0x00,0x22,0x38,0x24,0x44,0x28,0x44,0x30,0x44,0x28,0x44,0x24,0x44,0x22,0x44,
0x22,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x92,0x49,0x45,0x14,0x28,0xA2,0x92,0x49,//KO 32
0x00,0x00,0x00,0x00,0x00,0x00,0x25,0x12,0x51,0x13,0x55,0x12,0x55,0x52,0x54,0xA7,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//P1 WIN 64
0x00,0x00,0x00,0x00,0x00,0x00,0x4A,0x24,0xA2,0x2A,0xAA,0x24,0xAA,0xA2,0xA9,0x4E,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00//P2 WIN  96
void delayu(unsigned int time);//延時(shí)函數(shù) 延時(shí)0.1ms
void delay(unsigned int time);//延時(shí)函數(shù) 延時(shí)1ms
void NUMLEDOPEN(int i);//74HC154進(jìn)行行選擇,第i行
void dat_in(unsigned char dat);//將8為數(shù)據(jù)從597傳送過(guò)去
void display_one_page();//先加載各方“血”的狀態(tài),并顯示一張圖片,顯示人的狀態(tài)和血的狀態(tài)
void display_scene(int scene);//顯示開(kāi)機(jī)畫(huà)面和勝負(fù)畫(huà)面的函數(shù)
void change_buffer_to1(int position);//修改1的圖像狀態(tài)緩沖 從人物索引表的第position個(gè)8位數(shù)個(gè)開(kāi)始顯示
void change_buffer_to2(int position);//修改2的圖像狀態(tài)緩沖 從人物索引表的第position個(gè)8位數(shù)個(gè)開(kāi)始顯示
void action_back1();//第1個(gè)人向后一步 并將position減1 直到它不能后退
void action_back2();//第2個(gè)人向后一步 并將position減1 直到它不能后退
void action_forth1();//第1個(gè)人向前一步 并將position加1 直到它不能后退
void action_forth2();//第2個(gè)人向前一步 并將position加1 直到它不能后退
void fist_change_buff1();//由于1出拳對(duì)畫(huà)面的改動(dòng) 要調(diào)用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函數(shù)
void leg_change_buff1();//由于1出腿對(duì)畫(huà)面的改動(dòng)        要調(diào)用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函數(shù)
void fist_change_buff2();//由于2出拳對(duì)畫(huà)面的改動(dòng) 要調(diào)用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函數(shù)
void leg_change_buff2();//由于2出腿對(duì)畫(huà)面的改動(dòng) 要調(diào)用change_buff1_to_bit(int pos)和change_buff1_to_bit_low(int pos)函數(shù)
void change_buff1_to_bit(int pos); //將特定某一位置一
void change_buff2_to_bit(int pos);//將特定某一位置一
void change_buff1_to_bit_low(int pos);//將特定某一位置0
void change_buff2_to_bit_low(int pos);//將特定某一位置0
void action_fist1();//第1個(gè)人出拳 并處理減血情況
void action_fist2();//第2個(gè)人出拳 并處理減血情況
void action_leg1();//第1個(gè)人出腿 并處理減血情況
void action_leg2();//第2個(gè)人出腿 并處理減血情況
void scan_key();
//這個(gè)是函數(shù)的主體部分 分別掃描并處理向后退 向前走 出拳 出腿的動(dòng)作 當(dāng)出拳和出腿的時(shí)候 開(kāi)啟定時(shí)器
//這300ms內(nèi)記錄是否有對(duì)方出拳出腿的動(dòng)作 并按照先掃描向后退 后掃描向前進(jìn)的順序 掃描一遍 并處理 如果沒(méi)有這兩個(gè)動(dòng)作 直接返回調(diào)用出拳
//否則處理后再出拳 出腳的道理一致
void init_interrupt();//中斷位的設(shè)置
//開(kāi)啟定兩個(gè)時(shí)器中斷 16位模式
void shed_blood1();
//記錄流血的數(shù)字
void shed_blood2();
        int i;
                if(S1==0)
                        delay(1);
                        if(S1==0)
                                for(i=0;i<blood1;i++)
                                        change_buff1_to_bit(120+i);
                                for(i=0;i<blood2;i++)
                                        change_buff2_to_bit(120+i);
                                init_interrupt();
                                scan_key();
                        while(S2)
                                if(blood1==0)
                                        display_scene(P2_WIN);
                                        display_scene(P1_WIN);
                        blood1=7;
                        blood2=7;
                        if(S2==0)
                                delay(1);
                                while(S2)
                                        if(blood1==0)
                        while(S1)
                                display_scene(GO);
void delayu(unsigned int time)//延時(shí)函數(shù) 延時(shí)0.1ms
        unsigned int i,j;
        for(i=0;i<time;i++)
        for(j=0;j<100;j++);//1000次空操作的時(shí)間約為1ms
void delay(unsigned int time)//延時(shí)函數(shù) 延時(shí)1ms
        unsigned int i,j;
        for(i=0;i<time;i++)
        for(j=0;j<1000;j++);//1000次空操作的時(shí)間約為1ms
        unsigned char i;
        for(i=0;i<8;i++)
                SCLK=0;
                if((dat&0X80)!=0)SI=1;
                        else SI=0;
                dat<<=1;
                SCLK=1;
        //RCLK=0;                //dat_out
        //RCLK=1;
void NUMLEDOPEN(int i)//74HC154進(jìn)行行選擇,顯示第一個(gè)人的led區(qū)
        if(i==0)
        {NUMLED1OPEN();return;}
        if(i==1)
        {NUMLED2OPEN();return;}
        if(i==2)
        {NUMLED3OPEN();return;}
        if(i==3)
        {NUMLED4OPEN();return;}
        if(i==4)
        {NUMLED5OPEN();return;}
        if(i==5)
        {NUMLED6OPEN();return;}
        if(i==6)
        {NUMLED7OPEN();return;}
        if(i==7)
        {NUMLED8OPEN();return;}
        if(i==8)
        {NUMLED9OPEN();return;}
        if(i==9)
        {NUMLED10OPEN();return;}
        if(i==10)
        {NUMLED11OPEN();return;}
        if(i==11)
        {NUMLED12OPEN();return;}
        if(i==12)
        {NUMLED13OPEN();return;}
        if(i==13)
        {NUMLED14OPEN();return;}
        if(i==14)
        {NUMLED15OPEN();return;}
        if(i==15)
        {NUMLED16OPEN();return;}
void display_one_page()//顯示第i個(gè)人的一幀圖像
        int i;
                //NUMLEDOPEN1(1);
        for(i=0;i<16;i++)
                dat_in(0x00);
                dat_in(0x00);
                NUMLEDOPEN(i);
                dat_in(buff2[i]);
                dat_in(buff1[i]);
                RCLK=0;                //dat_out
                RCLK=1;
                delayu(1);
void display_scene(int scene)//第1個(gè)人整體動(dòng)畫(huà)的顯示函數(shù)
        int i;
        for(i=0;i<16;i++)
                NUMLEDOPEN(i);
                dat_in(welecome_and_end[scene+i*2]);
                dat_in(welecome_and_end[scene+i*2+1]);
                RCLK=0;                //dat_out
                RCLK=1;
                delayu(1);
void change_buffer_to1(int position)//修改1的圖像狀態(tài)緩沖
        int i;
        for(i=0;i<16;i++)
                buff1[i]=role_action[position+i];
void change_buffer_to2(int position)//修改2的圖像狀態(tài)緩沖
        int i;
                for(i=0;i<16;i++)
                        buff2[i]=role_action[position+i];
void action_back1()//第1個(gè)人向后一步
        int i;
        if(position1>0)
        if(position1==2)
                i=15;
                change_buffer_to1(START1+JUMP_UP_AND_BACK2);
                while(i--)
                        display_one_page();
                i=5;
                change_buffer_to1(START1+INIT);
                while(i--)
                        display_one_page();
        else if(position1==1)
                i=15;
                while(i--)
                        display_one_page();
                i=5;
                change_buffer_to1(START1+BACK);
                while(i--)
                        display_one_page();
        position1--;
void action_back2()//第2個(gè)人向后一步
//先顯示向后跳起的動(dòng)作 再顯示后退的狀態(tài)
        int i;
        if(position2>0)
        if(position2==2)
                i=15;
                change_buffer_to2(START1+JUMP_UP_AND_BACK1);
                while(i--)
                        display_one_page();
                i=5;
                change_buffer_to2(START2+INIT);
                while(i--)
                        display_one_page();
        else if(position2==1)
                i=15;
                change_buffer_to2(START2+JUMP_UP_AND_BACK2);
                while(i--)
                        display_one_page();
                i=5;
                change_buffer_to2(START2+BACK);
                while(i--)
                        display_one_page();
        position2--;
void action_forth1()//第1個(gè)人向前一步
        int i;
        if(position1<2)
                if(position1==1)
                        i=10;
                        change_buffer_to1(START1+FORTH);
                        while(i--)
                                display_one_page();
                else if(position1==0)
                        i=10;
                        while(i--)
                                display_one_page();
                position1++;
void action_forth2()//第2個(gè)人向前一步
//直接顯示向前一步的狀態(tài)
int i;
        if(position2<2)
                if(position2==1)
                        i=10;
                        change_buffer_to2(START2+FORTH);
                        while(i--)
                                display_one_page();
                else if(position2==0)
                        i=10;
                        change_buffer_to2(START1+INIT);
                        while(i--)
                                display_one_page();
                position2++;
        int p1=pos/8;
        int p2=pos%8;
        unsigned char flag=0x01;
        flag=flag<<p2;
        buff1[p1]=buff1[p1]|flag;
        int p1=pos/8;
        int p2=pos%8;
        flag=flag<<p2;
        buff2[p1]=buff2[p1]|flag;
        int p1=pos/8;
        int p2=pos%8;
        flag=flag<<p2;
        flag=~flag;
        buff1[p1]=buff1[p1]&flag;
        int p1=pos/8;
        int p2=pos%8;
        flag=flag<<p2;
        flag=~flag;
        buff2[p1]=buff2[p1]&flag;
void fist_change_buff1()//由于1出拳對(duì)畫(huà)面的改動(dòng)
        if(position1==0)
                change_buff1_to_bit(54);
                change_buff1_to_bit(55);
                change_buff1_to_bit_low(61);
                change_buff1_to_bit_low(69);
                change_buff2_to_bit(48);
                change_buff1_to_bit_low(62);
                change_buff1_to_bit_low(70);
        else if(position1==2)
                change_buff2_to_bit(49);
                change_buff1_to_bit_low(63);
                change_buff1_to_bit_low(71);
這四個(gè)函數(shù)僅改變顯示緩沖的值
void leg_change_buff1()//由于1出腿對(duì)畫(huà)面的改動(dòng)
        if(position1==0)
                change_buff1_to_bit(85);
                change_buff1_to_bit(86);
                change_buff1_to_bit(87);
                change_buff2_to_bit(80);
                change_buff1_to_bit_low(92);
                change_buff1_to_bit_low(100);
                change_buff1_to_bit_low(108);
                change_buff1_to_bit_low(116);
                change_buff2_to_bit(81);
                change_buff1_to_bit_low(93);
                change_buff1_to_bit_low(101);
                change_buff1_to_bit_low(109);
                change_buff1_to_bit_low(117);
                change_buff2_to_bit(82);
                change_buff1_to_bit_low(94);
                change_buff1_to_bit_low(102);
                change_buff1_to_bit_low(110);
                change_buff1_to_bit_low(118);
void fist_change_buff2()//由于2出拳對(duì)畫(huà)面的改動(dòng)
        if(position2==0)
                change_buff2_to_bit_low(58);
                change_buff2_to_bit_low(66);
                change_buff2_to_bit_low(57);
                change_buff2_to_bit_low(65);
        else if(position2==2)
                change_buff2_to_bit_low(56);
                change_buff2_to_bit_low(64);
void leg_change_buff2()//由于2出腿對(duì)畫(huà)面的改動(dòng)
        if(position2==0)
                change_buff2_to_bit_low(91);
                change_buff2_to_bit_low(99);
                change_buff2_to_bit_low(107);
                change_buff2_to_bit_low(115);
                change_buff2_to_bit_low(90);
                change_buff2_to_bit_low(98);
                change_buff2_to_bit_low(106);
                change_buff2_to_bit_low(114);
                change_buff2_to_bit_low(89);
                change_buff2_to_bit_low(97);
                change_buff2_to_bit_low(105);
                change_buff2_to_bit_low(113);
void action_fist1()//第1個(gè)人出拳
        int i;
        i=5;
        shed_blood2();
        while(i--)
                display_one_page();
        i=5;
        change_buffer_to1(position1*16);
        change_buffer_to2(position2*16);
void action_fist2()//第2個(gè)人出拳
        int i;
        i=10;
        shed_blood1();
        while(i--)
                display_one_page();
void action_leg1()//第1個(gè)人出腿
        int i;
        i=10;
        leg_change_buff1();
        shed_blood2();
        while(i--)
                //display_one_page1();
                display_one_page();
void action_leg2()//第2個(gè)人出腿
        int i;
        i=10;
        leg_change_buff2();
        shed_blood1();
        while(i--)
                display_one_page();
void init_interrupt()//中斷位的設(shè)置
TMOD=0x11;//定時(shí)器T0 T1工作在1模式 16位方式下
TH0=63536/256;//2ms一次定時(shí)器中斷
TL0=63536%256;
TH1=63536/256;//2ms一次定時(shí)器中斷
TL1=63536%256;
EA=1;//開(kāi)總中斷
ET0=1;//開(kāi)定時(shí)計(jì)數(shù)器T0
ET1=1;//開(kāi)定時(shí)計(jì)數(shù)器T1
void scan_key()
                if(blood1==0||blood2==0)
                        break;
                while(S11&&S12&&S13&&S14&&S21&&S22&&S23&&S24)
                display_one_page();
                while(S11||S12||S13||S14||S21||S22||S23||S24)
                        delay(1);
                        if(S11&&S12&&S13&&S14&&S21&&S22&&S23&&S24)
                        display_one_page();
                        break;
                if(S12==0)
                        delay(1);
                        if(S12==0)//1向后的動(dòng)作
                                action_back1();
                if(S22==0)
                        delay(1);
                        if(S22==0)//2向后的動(dòng)作
                                action_back2();
                else if(S11==0)
                        delay(1);
                        if(S11==0)//1向前的動(dòng)作
                                action_forth1();
                else if(S21==0)
                        delay(1);
                        if(S21==0)//2向前的動(dòng)作
                                action_forth2();
                else if(S13==0)
                        delay(1);
                        if(S13==0)
                                TR0=1;
                                while(TR0==1)
                                        display_one_page();
                                        if(S22==0)
                                                        delay(1);
                                                        if(S22==0)
        count_back2=1;
                                        else if(S21==0)
                                                        delay(1);
                                                        if(S21==0)
        count_forth2=1;
                                action_fist1();
                else if(S23==0)
                        delay(1);
                        if(S23==0)
                                TR1=1;
                                while(TR1==1)
                                        display_one_page();
                                        if(S12==0)
                                                        delay(1);
                                                        if(S12==0)
        count_back1=1;
                                        else if(S11==0)
                                                        delay(1);
                                                        if(S11==0)
        count_forth1=1;
                                action_fist2();
                else if(S13==0)
                        delay(1);
                        if(S13==0)
                                TR0=1;
                                while(TR0==1)
                                        display_one_page();
                                        if(S22==0)
                                                        delay(1);
                                                        if(S22==0)
        count_back2=1;
                                        else if(S21==0)
                                                        delay(1);
                                                        if(S21==0)
        count_forth2=1;
                                action_fist1();
                else if(S23==0)
                        delay(1);
                        if(S23==0)
                                TR1=1;
                                while(TR1==1)
                                        display_one_page();
                                        if(S12==0)
                                                        delay(1);
                                                        if(S12==0)
        count_back1=1;
                                        else if(S11==0)
                                                        delay(1);
                                                        if(S11==0)
        count_forth1=1;
                                action_fist2();
                else if(S14==0)
                        delay(1);
                        if(S14==0)
                                TR0=1;
                                while(TR0==1)
                                        display_one_page();
                                        if(S22==0)
                                                        delay(1);
                                                        if(S22==0)
        count_back2=1;
                                        else if(S21==0)
                                                        delay(1);
                                                        if(S21==0)
        count_forth2=1;
                                action_leg1();
                else if(S24==0)
                        delay(1);
                        if(S24==0)
                                TR1=1;
                                while(TR1==1)
                                        display_one_page();
                                        if(S12==0)
                                                        delay(1);
                                                        if(S12==0)
        count_back1=1;
                                        else if(S11==0)
                                                        delay(1);
                                                        if(S11==0)
        count_forth1=1;
                                action_leg2();
void shed_blood1()
        if(position2==1)
                if(position1==2)
                        if(blood1>0)
                                blood1--;
                if(position1>0)
                        if(blood1>0)
                                blood1--;
void shed_blood2()
        if(position1==1)
                if(position2==2)
                        if(blood2>0)
                                blood2--;
                if(position2>0)
                        if(blood2>0)
                                blood2--;
void handle1() interrupt 1
        EA=0;
        TL0=63536%256;
        time0_count++;
        if(time0_count==200)
                time0_count=0;
                TR0=0;
                if(count_back2==1)
                        count_back2=0;
                        action_back2();
                else if(count_forth2==1)
                        count_forth2=0;
                        action_forth2();
        EA=1;
void handle2() interrupt 3
        EA=0;
        TL1=63536%256;
        time1_count++;
        if(time1_count==200)
                time1_count=0;
                TR1=0;
                if(count_back1==1)
                        count_back1=0;
                        action_back1();
                else if(count_forth1==1)
                        count_forth1=0;
                        action_forth1();
        EA=1;
