專注電子技術學習與研究
51單片機_1602液晶自定義心形圖案
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2013年10月20日   【字體:
 # include <reg51.h>
unsigned char table1[]={0x03,0x07,0x0f,0x1f,0x1f,0x1f,0x1f,0x1f,
                         0x18,0x1E,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,
                         0x07,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,0x1f,
                         0x10,0x18,0x1c,0x1E,0x1E,0x1E,0x1E,0x1E,
                         0x0f,0x07,0x03,0x01,0x00,0x00,0x00,0x00,
                         0x1f,0x1f,0x1f,0x1f,0x1f,0x0f,0x07,0x01,
                         0x1f,0x1f,0x1f,0x1f,0x1f,0x1c,0x18,0x00,
                         0x1c,0x18,0x10,0x00,0x00,0x00,0x00,0x00};//心圖案
#define   CLEARSCREEN   LCD_write_command(0x01)
/**************定義接口************************/
#define   LCDIO    P0
sbit LCD1602_RS=P2^2;
sbit LCD1602_RW=P2^1;
sbit LCD1602_EN=P2^0;
/**************定義函數(shù)************************/
void LCD_write_command(unsigned char command);//寫入指令函數(shù)
void LCD_write_dat(unsigned char dat);//寫入數(shù)據(jù)函數(shù)
void LCD_set_xy( unsigned char x, unsigned char y );//設置顯示位置函數(shù)
void LCD_dsp_char( unsigned x,unsigned char y,unsigned char dat);//顯示一個字符函數(shù)
void LCD_dsp_string(unsigned char X,unsigned char Y,unsigned char *s);//顯示字符串函數(shù)
void LCD_init(void);//初始化函數(shù)
void delay_nms(unsigned int n);//延時函數(shù)
/************初始化函數(shù)****************/
void LCD_init(void)
CLEARSCREEN;//clear screen
LCD_write_command(0x38);//set 8 bit data transmission mode
LCD_write_command(0x0c);//open display (enable lcd display)
LCD_write_command(0x80);//set lcd first display address
/**************寫指令函數(shù)********************************/
    LCDIO=command;
    LCD1602_RS=0;
    LCD1602_RW=0;
    LCD1602_EN=0;
    LCD1602_EN=1;
    delay_nms(10);
/****************寫數(shù)據(jù)函數(shù)************************/
LCDIO=dat;
LCD1602_RS=1;
LCD1602_RW=0;
LCD1602_EN=0;
delay_nms(1);
LCD1602_EN=1;
/***************設置顯示位置**************************/
unsigned char address;
if (y == 1)
   address = 0x80 + x;
      address =0xc0+ x;
LCD_write_command(address);
/****************顯示一個字符**********************/
LCD_set_xy( x, y );
LCD_write_dat(dat);
/***************顯示字符串函數(shù)***************/
     LCD_set_xy( X, Y );
     while (*s)
       LCD_write_dat(*s);
       s ++;
/********** 延時**********************/
     unsigned int i=0,j=0;
     for (i=n;i>0;i--)
     for (j=0;j<10;j++);
/***********主函數(shù)**************/
void main(void)
unsigned char i,j,k,tmp;
LCD_init();
delay_nms(100);
tmp=0x40;//設置CGRAM地址的格式字
k=0;
for(j=0;j<8;j++)
      for(i=0;i<8;i++)
         LCD_write_command(tmp+i); // 設置自定義字符的 CGRAM 地址
         delay_nms(2);
         LCD_write_dat(table1[k]); // 向CGRAM寫入自定義字符表的數(shù)據(jù)
         k++;
         delay_nms(2);
      tmp=tmp+8;
   LCD_dsp_string(1,1,"heart:      ");//在第一行第一列顯示“heart”
   for (i=0;i<4;i++)
       LCD_dsp_char( 10+i,1,i);//在第一行第10列位置顯示心圖案的上半部
       delay_nms(1);
   for (i=4;i<8;i++)
       LCD_dsp_char( 10+i-4,2,i);//在第二行第10列位置顯示心圖案的下半部
       delay_nms(1);
   while (1);
/************************   感謝陳青華老師的幫助********************************************/
關閉窗口
相關文章
