這個(gè)是仿真圖電路圖:
//晶振12mhz
#include <reg51.h>
sbit RS=P2^0; // RS數(shù)據(jù)和指令
sbit RW=P2^1; //讀和寫
sbit EN=P2^2; //讀取時(shí)能
sbit busy=P0^7;
sbit DQ=P3^4;
uchar temp_value;
unsigned char show1[]="18B20";
unsigned char show2[]="temperature";
unsigned char tab[]={0+'0',1+'0',2+'0',3+'0',4+'0',5+'0',6+'0',7+'0',8+'0',9+'0'};
void delay_18B20(uint i)
while(i--);
void Init_DS18B20(void)
uchar x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(80); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線
delay_18B20(14);
x=DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
delay_18B20(20);
uchar ReadOneChar(void)
uchar i=0;
uchar dat = 0;
for (i=8;i>0;i--)
DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(4);
return(dat);
void WriteOneChar(uchar dat)
uchar i=0;
for (i=8; i>0; i--)
DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;
void ReadTemp(void)
uchar a=0;
uchar b=0;
uchar t=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
delay_18B20(100); // this message is wery important
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個(gè)寄存器) 前兩個(gè)就是溫度
delay_18B20(100);
a=ReadOneChar(); //讀取溫度值低位
b=ReadOneChar(); //讀取溫度值高位
temp_value=b<<4;
temp_value+=(a&0xf0)>>4;
void time1(void)
unsigned char i;
for(i=0;i<20;i++)
TMOD = 0x01;
TH0 = 0x3C;
TL0 = 0x0B0;
TR0 = 1;
while(!TF0);
TF0=0;
TH0=0x3c;
TL0=0x0b0;
TR0=1;
void wait() //等待繁忙
P0=0xff;
do
EN=0;
RS=0;
RW=1;
EN=1;
}while(busy==1);
EN=0;
void writecmd(unsigned char k) //寫命令
wait();
RS=0;
RW=0;
P0=k;
EN=1;
EN=0;
void writedat(unsigned char p) //寫數(shù)據(jù)
wait();
RS=1;
RW=0;
P0=p;
EN=1;
EN=0;
void init1602() //1602初始化
writecmd(0x38);
writecmd(0x0c);
writecmd(0x06);
writecmd(0x01);
unsigned char *p;
init1602();
p=show1;
writecmd(0x80);
while(*p!='\0') //讀到字符末尾結(jié)束
writedat(*p);
++p;
p=show2;
writecmd(0xc0);
while(*p!='\0')
writedat(*p);
++p;
writedat(' ');
writecmd(0x06);
writecmd(0xcc);
{ ReadTemp();
writecmd(0xcc);
writedat(tab[(int)temp_value/10]);
writecmd(0xcd);
writedat(tab[(int)temp_value%10]);
time1();
