在制作數(shù)字時(shí)鐘之前,先要熟悉 用vhdl實(shí)現(xiàn)74LS161十進(jìn)制計(jì)數(shù)器http://www.torrancerestoration.com/mcu/2233.html
然后在編寫(xiě)時(shí)鐘描述語(yǔ)言
Library ieee;
Use ieee.std_logic_1164.all;
Use ieee.std_logic_unsigned.all;
Entity timer24 is
port(CP,CR:IN STD_LOGIC;
AS0,BS0,CS0,DS0,ES0,FS0,GS0,AS1,BS1,CS1,DS1,ES1,FS1,GS1:OUT STD_LOGIC;
AM0,BM0,CM0,DM0,EM0,FM0,GM0,AM1,BM1,CM1,DM1,EM1,FM1,GM1:OUT STD_LOGIC;
AH0,BH0,CH0,DH0,EH0,FH0,GH0,AH1,BH1,CH1,DH1,EH1,FH1,GH1:OUT STD_LOGIC);
END TIMER24;
architecture TIMER of TIMER24 is
signal H1,H0,M1,M0,S1,S0:std_logic_vector(3 downto 0);
SIGNAL C0,C1,C2,C3,C4,C5: std_logic ;
COMPONENT court161 IS
port( clk,CTT,CTP,LD,CR:in std_logic;
D3,D2,D1,D0: in std_logic;
Q:out std_logic_VECTOR(3 DOWNTO 0);
Co: out std_logic);
end COMPONENT;
COMPONENT QDLED7 IS
PORT(DATA:IN STD_LOGIC_VECTOR(3 DOWNTO 0);
a,b,c,d,e,f,g:out std_logic);
end COMPONENT;
begin
U0:court161 PORT MAP(CP,'1','1','1',CR,'0','0','0','0',S0,C0);
U1:court161 PORT MAP(C0,'1','1',(NOT(S1(2)AND S1(0))),CR,'0','0','0','0',S1,C1);
U2:court161 PORT MAP((NOT(S1(2)AND S1(0))),'1','1','1',CR,'0','0','0','0',M0,C2);
U3:court161 PORT MAP(C2,'1','1',(NOT(M1(2)AND M1(0))),CR,'0','0','0','0',M1,C3);
U4:court161 PORT MAP(C3,'1','1','1',(CR AND(NOT(H1(1) AND H0(2)))),'0','0','0','0',H0,C4);
U5:court161 PORT MAP(C4,'1','1',(NOT H1(1)),(CR AND(NOT(H1(1) AND H0(2)))),'0','0','0','0',H1,C5);
U6:QDLED7 PORT MAP(S0,AS0,BS0,CS0,DS0,ES0,FS0,GS0);
U7:QDLED7 PORT MAP(S1,AS1,BS1,CS1,DS1,ES1,FS1,GS1);
U8:QDLED7 PORT MAP(M0,AM0,BM0,CM0,DM0,EM0,FM0,GM0);
U9:QDLED7 PORT MAP(M1,AM1,BM1,CM1,DM1,EM1,FM1,GM1);
U10:QDLED7 PORT MAP(H0,AH0,BH0,CH0,DH0,EH0,FH0,GH0);
U11:QDLED7 PORT MAP(H1,AH1,BH1,CH1,DH1,EH1,FH1,GH1);
END;
接上數(shù)碼管,和脈沖信號(hào)發(fā)生器,必要時(shí)要分頻,分成脈沖周期為1秒的脈沖周期方可。數(shù)碼管的驅(qū)動(dòng)程序: http://www.torrancerestoration.com/mcu/2234.html
一般電路里的晶振頻率都很高,在設(shè)計(jì)秒表或鐘表時(shí),需要將頻率很高的脈沖變成頻率為1Hz的脈沖,就可作為計(jì)時(shí)的標(biāo)準(zhǔn)單位,這個(gè)過(guò)程叫分頻,下面是將6MHz的頻率分頻為周期是1秒的分頻電路程序,即用2個(gè)計(jì)數(shù)200和一個(gè)計(jì)數(shù)150的三個(gè)計(jì)數(shù)器串聯(lián)而成,這樣200*200*150=6000000,即三個(gè)合起來(lái)計(jì)數(shù)6000000次剛好為1秒:
Library ieee;
entity fenpin6M is
port(cp:in std_logic;
clk:out std_logic);
end fenpin12M;
Architecture fen of fenpin12M is
signal Q0,Q1,Q2:std_logic_vector(7 downto 0);
signal c0,c1,c2:std_logic;
begin
process(cp,c0,c1)
begin
if cp'event and cp='1' then
if Q0<199 then Q0<=Q0+1;
else Q0<="00000000";
end if;
if Q0=199 then c0<='1';
else c0<='0';
end if;
end if;
if c0'event and c0='1' then
if Q1<149 then Q1<=Q1+1;
else Q1<="00000000";
end if;
if Q1=149 then c1<='1';
else c1<='0';
end if;
end if;
if c1'event and c1='1' then
if Q2<199 then Q2<=Q2+1;
else Q2<="00000000";
end if;
if Q2=199 then c2<='1';
else c2<='0';
end if;
end if;
end process;
clk<=c2;
end;
