數(shù)碼管計(jì)時(shí)器程序
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年11月16日   【字體:
這是一個(gè)51hei網(wǎng)友測(cè)試通過的計(jì)時(shí)器程序、電路很簡單就不畫了數(shù)碼管的段選是P0口位選是P1口
#include <reg52.h>
typedef unsigned char uint8;
typedef unsigned int uint16;
typedef unsigned long uint32;
code uint8 number[]={0xc0,0xf9,0xa4,0xb0, 0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83, 0xa7,0xa1,0x86,0x8e};       //數(shù)字0到F
uint16 counter = 0;                                                              //定義計(jì)數(shù)器初始化
uint8 a[6];        //六個(gè)數(shù)碼管
sbit ENLED = P1^4;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
void timer1_led()
 TMOD |= 0x10;        //寄存器狀態(tài)M0位置1,或運(yùn)算
 TMOD &= 0xDF;
 TH1 = 0xFC;        //12*(65535-x)/11059200 =1s
 TL1 = 0x67;
 TR1 = 1;        //定時(shí)器置1打開,計(jì)數(shù)器開始計(jì)時(shí)
void int_init()
 ET1 = 1;        // 打開定時(shí)器1溢出中斷使能置1
 EA = 1;        //總閥門打開
 refresh_led()
 static uint8 j = 0;        //靜態(tài)變量刷新
  switch(j)
   case 0:ADDR0 = 0;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[0]];break;
   case 1:ADDR0 = 1;ADDR1 = 0;ADDR2 = 0;j++;P0 = number[a[1]];break;
   case 2:ADDR0 = 0;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[2]];break;
   case 3:ADDR0 = 1;ADDR1 = 1;ADDR2 = 0;j++;P0 = number[a[3]];break;
   case 4:ADDR0 = 0;ADDR1 = 0;ADDR2 = 1;j++;P0 = number[a[4]];break;
   case 5:ADDR0 = 1;ADDR1 = 0;ADDR2 = 1;j = 0;P0 = number[a[5]];break;
   default :break;
main()
 ENLED = 0;ADDR3 = 1;        //138譯碼器使能
 timer1_led();        //定時(shí)初始化
 int_init();
 while(1);
void interrupt_timer1() interrupt 3                                                //中斷函數(shù)
 static uint32 sec=0;        //定義變量
 TH1 = 0xFC;
 TL1 = 0x67;
 counter++;
if(1000==counter)
 sec++;
 counter=0;
 a[0] = sec%10;        //個(gè)位數(shù)取余
 a[1] = sec/10%10;        //十位取余
 a[2] = sec/100%10;        //百位取余
 a[3] = sec/1000%10;        //...............
 a[4] = sec/10000%10;
 a[5] = sec/100000%10;
 refresh_led();
