C8051F330 16*16點(diǎn)陣(SPI 、SMBus、I2C)PCF8563
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2013年11月17日   【字體:
#include <c8051f330.h>
#include <stdio.h>
#include <math.h>
#include <Intrins.h>
#include <absacc.h>
#define SPEED 2000
#define TIME 1800
#define BLKN 2   //用于點(diǎn)陣列掃描的595的個(gè)數(shù)
#define TOTAL 26  //待顯示的字?jǐn)?shù)
#define CONIO P1
uchar number;//d=0,
uchar control=0,choose,send;
uchar receive_number=3,send_number=0;
bit BUSY;
bit SMB_RW;
uchar hou=0;
uchar min=0;
uchar sec=0;
uchar sg;//時(shí)高位
uchar sd;//時(shí)低位
uchar fg;//分高位
uchar fd;//分低位
uchar mg;//秒高位
uchar md;//秒低位
sbit CLK=P1^7;  //輸出脈沖
sbit scyx=P1^6;  //復(fù)位
sbit led=P0^7;
sbit pcf8563_scl=P0^5;//時(shí)鐘頻率
sbit pcf8563_sda=P0^4;//串行數(shù)據(jù)傳輸腳
uchar idata dispram[(BLKN/2)*32]={0};
uchar receive1[3]={0x00,0x00,0x00};//時(shí)、分、秒
uchar send1[4]={0x02,0x33,0x25,0x03};//時(shí)、分、秒、器件地址
/*********************************字模表***************************************/
uchar code Bmp[][32]={
{0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xF0,0x1C,0x18,0x38,0x1C,0x38,0x0E,0x38,0x0E,
0x78,0x0E,0x38,0x0E,0x38,0x0E,0x38,0x1C,0x1C,0x18,0x07,0xF0,0x00,0x00,0x00,0x00},
/***數(shù)字0***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xC0,0x0F,0xC0,0x01,0xC0,0x01,0xC0,0x01,0xC0,
0x01,0xC0,0x01,0xC0,0x01,0xC0,0x01,0xC0,0x01,0xC0,0x0F,0xFC,0x00,0x00,0x00,0x00},
/***數(shù)字1***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF8,0x18,0x1C,0x38,0x1C,0x18,0x1C,0x00,0x38,
0x00,0x70,0x01,0xC0,0x07,0x00,0x0C,0x06,0x3F,0xFC,0x3F,0xFC,0x00,0x00,0x00,0x00},
/***數(shù)字2***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF0,0x38,0x38,0x38,0x1C,0x00,0x38,0x03,0xF0,
0x03,0xF0,0x00,0x1C,0x00,0x0E,0x38,0x1C,0x38,0x1C,0x0F,0xF0,0x00,0x00,0x00,0x00},
/***數(shù)字3***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x00,0xF0,0x01,0xF0,0x03,0x70,0x0C,0x70,
0x18,0x70,0x30,0x70,0x3F,0xFE,0x00,0x70,0x00,0x70,0x03,0xFE,0x00,0x00,0x00,0x00},
/***數(shù)字4***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFC,0x18,0x00,0x18,0x00,0x18,0xC0,0x1F,0xF8,
0x18,0x1C,0x00,0x1E,0x10,0x0E,0x38,0x1C,0x38,0x18,0x0F,0xF0,0x00,0x00,0x00,0x00},
/***數(shù)字5***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xF8,0x0C,0x3C,0x18,0x08,0x38,0x00,0x3F,0xF8,
0x7C,0x1C,0x78,0x0E,0x38,0x0E,0x38,0x0E,0x1C,0x1C,0x07,0xF0,0x00,0x00,0x00,0x00},
/***數(shù)字6***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFE,0x3C,0x0C,0x30,0x18,0x00,0x30,0x00,0x60,
0x00,0xC0,0x01,0xC0,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x00,0x00,0x00,0x00},
/***數(shù)字7***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF8,0x38,0x0C,0x30,0x0E,0x3C,0x0C,0x1F,0xF8,
0x0F,0xF0,0x38,0x3C,0x30,0x0E,0x70,0x0E,0x38,0x0C,0x0F,0xF0,0x00,0x00,0x00,0x00},
/***數(shù)字8***/
{0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF0,0x38,0x18,0x30,0x0C,0x70,0x0E,0x30,0x0E,
0x38,0x3E,0x1F,0xEE,0x00,0x1C,0x18,0x18,0x3C,0x30,0x1F,0xE0,0x00,0x00,0x00,0x00},
/***數(shù)字9***/
{0x00,0x40,0x40,0x40,0x30,0x40,0x10,0x40,0x00,0x48,0x00,0x7C,0xF0,0x40,0x10,0x40,
0x10,0x40,0x10,0x40,0x10,0x40,0x12,0x40,0x14,0x40,0x18,0x44,0x17,0xFE,0x00,0x00},//讓
{0x00,0x08,0x3F,0xFC,0x21,0x08,0x21,0x08,0x21,0x08,0x3F,0xF8,0x21,0x08,0x21,0x08,
0x21,0x08,0x3F,0xF8,0x20,0x08,0x02,0x00,0x51,0x88,0x50,0x96,0x90,0x12,0x0F,0xF0},//思
{0x10,0x80,0x10,0xA0,0x20,0x94,0x21,0xFE,0x49,0x10,0xFB,0x10,0x15,0xFC,0x21,0x10,
0x41,0x10,0xFD,0xFC,0x01,0x10,0x01,0x10,0x1D,0x14,0xE1,0xFE,0x41,0x00,0x01,0x00},//維
{0x01,0x20,0x41,0x24,0x2F,0xFE,0x21,0x24,0x01,0x24,0x8F,0xFC,0x49,0x24,0x09,0x20,
0x1F,0xFE,0x29,0x22,0xE1,0x22,0x21,0x2A,0x22,0x24,0x22,0x20,0x24,0x20,0x28,0x20},//沸
{0x00,0x40,0x7A,0x48,0x49,0x50,0x4B,0xFC,0x48,0x80,0x7F,0xFE,0x49,0x10,0x4A,0x0E,
0x4D,0xF4,0x78,0x10,0x49,0x14,0x49,0xFE,0x48,0x04,0x4F,0xE4,0x88,0x14,0x18,0x08},//騰
{0x08,0x00,0x08,0x08,0x08,0xFC,0x7E,0x08,0x08,0x08,0x08,0x08,0xFE,0xF8,0x08,0x88,
0x28,0x80,0x2E,0x84,0x28,0x84,0x28,0x7C,0x28,0x00,0x58,0x06,0x8F,0xFC,0x00,0x00},//起
{0x01,0x00,0x01,0x00,0x01,0x08,0x7F,0xFC,0x01,0x00,0x21,0x10,0x19,0x30,0x09,0x44,
0xFF,0xFE,0x03,0x80,0x05,0x40,0x09,0x30,0x31,0x1E,0xC1,0x04,0x01,0x00,0x01,0x00},//來
{0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x0C,0x00,0x1E,0x00,0x1E,0x00,0x0C,0x00,0x04,0x00,0x08,0x00,0x10,0x00,0x00,0x00},//,
{0x20,0x00,0x22,0x04,0x3F,0x7E,0x48,0x44,0x08,0x44,0xFF,0xC4,0x10,0x44,0x14,0x7C,
0x22,0x44,0x42,0x10,0x9F,0xF8,0x10,0x10,0x1F,0xF0,0x10,0x10,0x1F,0xF0,0x10,0x10},//智
{0x08,0x20,0x7E,0xFC,0x08,0x20,0x3E,0xF8,0x08,0x20,0x7E,0xFC,0x08,0x20,0x3F,0xF8,
0x00,0x08,0xFF,0xFE,0x00,0x08,0x3F,0xF8,0x09,0x00,0x28,0xA8,0x48,0x24,0x07,0xE0},//慧
{0x08,0x08,0x0B,0xFC,0x10,0x00,0x20,0x00,0x40,0x00,0x08,0x04,0x17,0xFE,0x30,0x10,
0x50,0x10,0x90,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x50,0x10,0x20},//行
{0x00,0x40,0x08,0x40,0x7C,0x40,0x00,0x44,0x05,0xFE,0xFE,0x44,0x10,0x44,0x10,0x44,
0x20,0x44,0x24,0x44,0x42,0x84,0xFE,0x84,0x41,0x04,0x01,0x04,0x02,0x28,0x04,0x10},//動(dòng)
0x00,0x00,0x00,0x00,0x3C,0x00,0x66,0x00,0x66,0x00,0x66,0x00,0x3C,0x00,0x00,0x00},//.};
uchar code Bmp1[][32]={
{0x01,0x00,0x11,0x00,0x11,0x00,0x11,0x08,0x3F,0xFC,0x21,0x00,0x41,0x00,0x41,0x00,
0x81,0x10,0x3F,0xF8,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x04,0xFF,0xFE,0x00,0x00},
{0x00,0x10,0x1F,0xF8,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0xF0,
0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x10,0x1F,0xF0,0x10,0x10,0x00,0x00},
{0x10,0x80,0x10,0x80,0x10,0x80,0x10,0x88,0x5B,0xFC,0x54,0x88,0x50,0x88,0x90,0x88,
0x10,0x88,0x1F,0xFE,0x10,0x80,0x11,0x40,0x11,0x20,0x12,0x10,0x14,0x0E,0x18,0x04},
{0x00,0x20,0x00,0xF0,0x1F,0x00,0x10,0x00,0x11,0x00,0x11,0x00,0x21,0x04,0x7F,0xFE,
0x01,0x00,0x01,0x00,0x09,0x20,0x09,0x10,0x11,0x08,0x21,0x0C,0x45,0x04,0x02,0x00},
{0x00,0x00,0x38,0x1C,0x44,0x22,0x54,0x2A,0x44,0x22,0x37,0xEC,0x08,0x10,0x10,0x08,
0x2E,0x74,0x20,0x04,0x21,0x84,0x24,0x24,0x13,0xC8,0x08,0x10,0x07,0xE0,0x00,0x00}
/************系統(tǒng)函數(shù)的配置***********/
void sysclk_int(void)    //內(nèi)部晶振
   OSCICL=0x83;
   OSCICN=0xc3; //不分頻
   CLKSEL=0x00;
void delay1(uchar n)  //延時(shí)程序
 uchar j;
    for(j=0;j<n;j++)
  _nop_();
  _nop_();
  _nop_();
  _nop_();
void delay(uint i) //毫秒延時(shí)
 register uchar j;//
for(;i;i--)
 for(j=0;j<255;j++);
void SPI_INT(void)  //SPI初始化
 SPI0CFG=0x40;
 SPI0CN=0x01; //0000 0001最后一位是SPI使能位 SPI工作在三線主方式
 SPI0CKR=0x0f; //SPI 時(shí)鐘頻率設(shè)置為100kHz 0x63
 IE &= 0xbf;  //關(guān)閉SPI中斷
void SMB_INT(void)  //SMB初始化
 SMB0CF=0x5f; //使能SMB 允許時(shí)間擴(kuò)充 定時(shí)器2低字節(jié)溢出時(shí)鐘源
 SMB0CF|=0x80;
void TIME01_INT(void)  //定時(shí)器初始化
 TCON=0x10;   //定時(shí)器0允許
 TMOD=0x01;   //定時(shí)器0在16位工作方式
 CKCON &= 0xf8;
 CKCON |= 0x01;  //定時(shí)器0使用系統(tǒng)4分頻
 TL0=0x03;
 TH0=0x03;
 IE|=0x02;
void TIME2_INT(void)  //定時(shí)器2用于配置SMB的時(shí)鐘頻率
 TMR2CN=0x00;
 CKCON |= 0x00;
 TMR2RLL = 0xef;
 TMR2RLH = 0xff;
 TMR2L = 0xef;
 TMR2H = 0xff;
 TMR2CN |= 0x0c;
void TIME3_INT(void)//用于I2C的超時(shí)檢測(cè)
 TMR3CN = 0x00;  //定時(shí)器3為16位自動(dòng)重載
 CKCON &= ~0x40;
 TMR3RLL = 0xaf;
 TMR3RLH = 0x57;
 TMR3L = 0xaf;
 TMR3H = 0x57;
 EIE1|=0x00;
 TMR3CN |= 0x04;
void pio_int(void)     // 端口配置
 XBR0=0x06;
 XBR1=0x40;
 P0MDIN=0xff;    //禁止模擬輸入,0為模擬,1為數(shù)字
 P0MDOUT=0x0d;   //0為開漏,1為推挽(ff)
 P0SKIP=0x08;
 P1MDIN=0xff;
 P1MDOUT=0xff; //低四位用于138
 P1SKIP=0x00;
 P0=0xff;
 P1=0xff;
/*************呈現(xiàn)各種顯示效果的函數(shù)集****************/
//void Jump_Word(uchar a) 立即跳顯示一個(gè)字或一張圖案
//void M_Word(uchar a)     卷簾出顯示一個(gè)字或一張圖案
//void M_Words(number)     顯示幾個(gè)交換的字
//void UP_Run(number)     向上滾屏n個(gè)字
//void L_Removeout(number) 右入左出n個(gè)字
//void M_Black(void)  黑屏
//void R_Removeout(number) 左入右出n個(gè)字
/****************立即跳顯示一個(gè)字或一張圖案***************/
{register uchar i,q;
for(i=0;i<32;i++)
 for(q=0;q<BLKN/2;q++)
  {dispram[i+q*32]=Bmp[a][i];}
  //if(i%2)delay(SPEED);
/****************卷簾出顯示一個(gè)字或一張圖案***************/
for(i=0;i<32;i++)
  {dispram[i+q*32]=Bmp1[a][i];}
/****************卷簾出顯示number個(gè)字***************/
{register uchar i,q,w;
for(w=0;w<number*2/BLKN;w++)
 for(i=0;i<32;i++)
  for(q=0;q<BLKN/2;q++){dispram[i+q*32]=Bmp[q+w*BLKN/2][i];}
 delay(TIME);
/****************向上滾屏number個(gè)字***************/
void UP_Run(number)
{register uchar i,j,k,q;
for(i=0;i<number*2/BLKN;i++)
 for(j=0;j<16;j++)
  for(k=0;k<15;k++)
    dispram[k*2+q*32]=dispram[(k+1)*2+q*32];
    dispram[k*2+1+q*32]=dispram[(k+1)*2+1+q*32];
   dispram[30+q*32]=Bmp[q+i*BLKN/2][j*2];
   dispram[31+q*32]=Bmp[q+i*BLKN/2][j*2+1];
  delay(2*SPEED);
 delay(2*TIME);
/****************左移出顯示number個(gè)字*******************/
{register uchar i,j,k,l,q;
for(i=0;i<number;i++)
 for(j=0;j<2;j++)
  for(k=0;k<8;k++)
   for(l=0;l<16;l++)
     dispram[l*2+q*32]=dispram[l*2+q*32]<<1|dispram[l*2+1+q*32]>>7;
     if(q==BLKN/2-1)
      dispram[l*2+1+q*32]=dispram[l*2+1+q*32]<<1|Bmp[i][l*2+j]>>(7-k);
      dispram[l*2+1+q*32]=dispram[l*2+1+q*32]<<1|dispram[l*2+(q+1)*32]>>7;
   delay(2*SPEED);
/****************卷簾出黑屏***************/
void M_Black(void)
for(i=0;i<32;i++)
  {dispram[i+q*32]=0x00;}
/****************右移出顯示number個(gè)字*******************/
 for(j=2;j>0;j--)
  for(k=0;k<8;k++)
   for(l=0;l<16;l++)
     dispram[l*2+1+q*32]=dispram[l*2+1+q*32]>>1|dispram[l*2+q*32]<<7;
     if(q==0)
      dispram[l*2+q*32]=dispram[l*2+q*32]>>1|Bmp[i][l*2+j-1]<<(7-k);
      dispram[l*2+q*32]=dispram[l*2+q*32]>>1|dispram[l*2+1+(q-1)*32]<<7;
   delay(2*SPEED);
/*************用于時(shí)鐘芯片操作的函數(shù)集****************/
//void write_pcf8563(void)寫時(shí)鐘芯片
//void read_pcf8563(void)讀時(shí)鐘芯片
 SPI0CN &=~0x01; //暫時(shí)關(guān)掉SPI通訊
 send =0xa2;  //送子器件地址
 while(BUSY);
 BUSY=1;
 SMB_RW=0;control=5;
 STA=1;   //開始傳送
 while(BUSY);
 SPI0CN |=0x01; //重新開啟SPI
void read_pcf8563(void)   //讀當(dāng)時(shí)的時(shí),分,鈔
 SPI0CN &=~0x01;
 while(BUSY);
 BUSY=1;
 SMB_RW=0;
 STA=1;
 send=0x02;
 while(!SI);
 BUSY=1;
 send=0xa2;
 while(BUSY);
 BUSY=1;
 SMB_RW=1;
 STA=1;
 while(BUSY);
 BUSY=1;
 sec=receive1[2]&0x7f;//讀秒
 min=receive1[1]&0x7f;//讀分
 hou=receive1[0]&0x3f;//讀時(shí)
 SPI0CN |=0x01;
void spit_time(void)//分別計(jì)算時(shí)、分、秒的各位數(shù)字
 sg=(int)hou/16;
 sd=(int)hou%16;
 fg=(int)min/16;
 fd=(int)min%16;
 mg=(int)sec/16;
 md=(int)sec%16;
void dat_int(void) //數(shù)據(jù)初始化
 scyx=1;
 CLK=0;
void sysclk_int(void);
void delay(unsigned n);
void pio_int(void);
void SPI_INT(void);
void SMB_INT(void);
void dat_int(void);
void TIME01_INT(void);
void TIME2_INT(void);
void TIME3_INT(void);
void write_pcf8563(void);
void read_pcf8563(void);
void spit_time(void);
/**************主函數(shù)**************/
void main(void)   //主程序
 register uchar i;
 PCA0MD &= ~0x40;// 關(guān)閉看門狗
 sysclk_int();
 OSCICN |= 0x02;
/****************初始化檢測(cè)pcf8563****************/
   while(!pcf8563_sda)
      XBR1 = 0x40;
      pcf8563_scl = 0;
      for(i = 0; i < 255; i++);
      pcf8563_scl = 1;
      while(!pcf8563_scl);
      for(i = 0; i < 10; i++);
     XBR1 = 0x00;
 pio_int();
 TIME01_INT();
 TIME2_INT();
 TIME3_INT();
 SPI_INT();   //SPI0DAT是SPI的數(shù)據(jù)寄存
 SMB_INT();
 spit_time();
 EIE1|=0x01;
 EA=1;
 dat_int();
 led=0;
TR0=0;
delay(1000);
write_pcf8563();
TR0=0;
BUSY=0;
read_pcf8563();
spit_time();
TR0=1;
//Jump_Word(sg);
//Jump_Word(sd);
//Jump_Word(fg);
//Jump_Word(fd);
//Jump_Word(md);
//M_Word(md);
M_Word(4);
delay(10*TIME);
M_Words(TOTAL);
UP_Run(TOTAL);
M_Black();
delay(10*TIME);
L_Removeout(TOTAL);
delay(3*TIME);
M_Black();
delay(10*TIME);
R_Removeout(TOTAL);
delay(3*TIME);
}//總while循環(huán)的結(jié)束
}//main函數(shù)的結(jié)束
void t0(void) interrupt 1 //定時(shí)器0的中斷服務(wù)程序
register uchar m,n=BLKN;
TH0 = 0xfc;
TL0 = 0x18;
m = CONIO;
m = (++m)&0x0f;
for(n=0;n<BLKN;n++)
 SPI0DAT = dispram[30-m*2+n];//dispram[((BLKN-)n/2+1)*30-m*2-(n/2)*30+n]
 while(!SPIF);
 SPIF=0;
CONIO &= 0xf0;
CLK = 1;
CONIO |= m;
CLK = 0;
scyx=1;
void SMBus_ISR (void) interrupt 7
   bit FAIL = 0;
   if (ARBLOST == 0)   //如果贏得總線
      switch (SMB0CN & 0xF0)  //確定中斷來源
         case 0xe0:    //主發(fā)送方式下產(chǎn)生開始條件
            SMB0DAT = send;
            SMB0DAT &= 0xFE;
            SMB0DAT |= SMB_RW;  //對(duì)發(fā)送的數(shù)據(jù)進(jìn)行處理
            STA = 0;
            break;
         case 0xc0:    //主方式下發(fā)送
            if (ACK)
               if (SMB_RW == 0)
    if(send_number<=3)
     if(control==0)
      SMB0DAT = send;
      send_number+=5;
        SMB0DAT = send1[send_number];
      send_number++;
     send_number=0;control=0;
     STO = 1;
     BUSY = 0;
               else {;} //BUSY=0
               STO = 1;
               STA = 1;
            break;
         case 0x80:    //主方式下接收
      if (receive_number-1>0)   //控制接收3個(gè)數(shù)據(jù)就結(jié)束
                  receive1[receive_number-1] = SMB0DAT;
                  ACK = 1;
     receive_number--;
                 receive_number=3;
                 BUSY = 0;
                 ACK = 0;
                 STO = 1;
    break;
         default:
            FAIL = 1;
            break;
   else       //輸?shù)艨偩
      FAIL = 1;
if (FAIL)      //SMBUS通訊失敗后的處理
      SMB0CF &= ~0x80;
      SMB0CF |= 0x80;
      STA = 0;
      STO = 0;
      ACK = 0;
      BUSY = 0;
      FAIL = 0;
SI = 0;
void T3_ISR() interrupt 14 //定時(shí)器3中斷服務(wù)程序 用于檢測(cè)SMBus是否超時(shí)
 SMB0CF &= ~0x80;
 SMB0CF |= 0x80;
 TMR3CN &=~0x80;
 STA = 0;
 BUSY = 0;
 pcf8563_scl=1;
