轉(zhuǎn)兩個stm32定時器的使用代碼
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2013年11月20日   【字體:
 具體沒有測試,先收藏,以后去嘗試一下
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_Pulse = Pluse;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
    TIM_OC1Init(BLDC_TIMER_NUM, &TIM_OCInitStructure);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    Pluse = MotorA.TimerPeriod - Pluse;
    TIM_OC2Init(BLDC_TIMER_NUM, &TIM_OCInitStructure);
#define   Fsys           72000000ul   //  system freq 72MHz
#define   Fpwm           20000        //  PWM freq  20K
void  ConfigTimer(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  RCC_APB1PeriphClockCmd(  RCC_APB1Periph_TIM4,ENABLE);
  RCC_APB2PeriphClockCmd(  RCC_APB2Periph_GPIOB,ENABLE);
  TIM_DeInit(TIM4);
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned1;
  TIM_TimeBaseStructure.TIM_Period = (Fsys/2) / Fpwm;
  TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1;
  TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
  TIM_TimeBaseInit(TIM4,&TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OutputNState = TIM_OutputState_Disable;
  TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
  TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * 20) / 100;
  TIM_OC3Init(TIM4,&TIM_OCInitStructure);
  TIM_OCInitStructure.TIM_Pulse = (((Fsys/2) / Fpwm) * (100-20)) / 100;
  TIM_OC4Init(TIM4,&TIM_OCInitStructure);
  GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_8 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  TIM_CtrlPWMOutputs(TIM4, ENABLE);
  TIM_Cmd(TIM4,ENABLE);
基本設(shè)置如下:
1)配置定時器的計數(shù)器為中間對齊計數(shù),即先向上計數(shù)再向下計數(shù)。
2)在該定時器上選擇2個通道,并分別配置為輸出比較模式,并配置在比較成功時翻轉(zhuǎn)對應(yīng)的引腳輸出。
3)配置自動重裝載寄存器TIMx_ARR為要求輸出頻率的一半。
4)假定CC1為第一個輸出信號的通道,再假定第一個信號的正脈沖寬度對應(yīng)為W1,則配置TIMx_CCR1為TIMx_ARR-W1/2。
5) 同4),假定CC2為第二個輸出信號的通道,正脈沖寬度對應(yīng)為W2,配置TIMx_CCR2為W2/2。
下面以一個例子說明:
假設(shè)要求輸出的信號頻率為10kHz,占空比為1:3。
再假設(shè)定時器的輸入時鐘為72MHz。
輸出信號的頻率10kHz,換算為計數(shù)器的數(shù)值為7200。
按照上述3),設(shè)置TIMx_ARR=3600
輸出信號1的高電平時間W1,換算為計數(shù)器的數(shù)值為W1=7200/4=1800
按照上述4),設(shè)置TIMx_CC1=3600 - W1/2=2700
輸出信號2的高電平時間W2,換算為計數(shù)器的數(shù)值為W2=7200/4=1800
按照上述5),設(shè)置TIMx_CC2=2/2=450
參照下圖,圖中紅線表示計數(shù)器的數(shù)值變化:
①當(dāng)計數(shù)器的數(shù)值從0向上計數(shù),達(dá)到TIMx_CC1時,CC1匹配成功,CC1的輸出電平翻轉(zhuǎn);
②計數(shù)器繼續(xù)向上計數(shù),達(dá)到TIMx_ARR時開始調(diào)頭向下計數(shù);當(dāng)計數(shù)器的數(shù)值下降到TIMx_CC1時,CC1再次匹配成功,CC1的輸出電平再次翻轉(zhuǎn);
③計數(shù)器繼續(xù)向下計數(shù),達(dá)到到TIMx_CC2時,CC2匹配成功,CC2的輸出電平翻轉(zhuǎn);
④計數(shù)器繼續(xù)向下計數(shù),減到0時開始調(diào)頭向上計數(shù);當(dāng)計數(shù)器的數(shù)值上升到TIMx_CC2時,CC2再次匹配成功,CC2的輸出電平再次翻轉(zhuǎn);
如此循環(huán),得到連續(xù)的相位互為180度的兩路輸出波形。
注意:上述描述是一個原理性的說明,但能夠輸出要求的波形并且占空比可調(diào),實際編程計算中需要可能需要對某些數(shù)值加1或者減1,以達(dá)到準(zhǔn)確地輸出。
