MSP430F149單片機(jī)驅(qū)動(dòng)DS2762讀寫(xiě)操作C語(yǔ)言程序
作者:未知   來(lái)源:不詳   點(diǎn)擊數(shù):  更新時(shí)間:2013年12月27日   【字體:
基于MSP430F149單片機(jī)驅(qū)動(dòng)DS2762讀寫(xiě)操作C語(yǔ)言程序,能夠?qū)Π存I或著其他信號(hào)響應(yīng),讀出電流以及電壓量,并進(jìn)行相應(yīng)處理。
//#include <msp430x14x.h>
#define uint  unsigned int
uint A,B,C,D,E,F,G,H,I,J;//此處對(duì)io430x14x中的宏定義C進(jìn)行了注釋?zhuān)枳⒁?#define IO_OUT P3DIR |= BIT0;
#define IO_INP P3DIR &= ~BIT0;
uint data;
對(duì)讀寫(xiě)時(shí)間進(jìn)行規(guī)范化
初始調(diào)試采用standard=1的參數(shù)
// Pause for exactly 'tick' number of ticks = 0.25us
實(shí)際測(cè)的A延時(shí)14Us
B125US
void SetSpeed(uint standard)
        // Adjust tick values depending on speed
        if (standard)
                // Standard Speed
                A = 6 * 4 / 2;
                B = 64 * 4 / 2;
                C = 60 * 4 / 2;
                D = 10 * 4 / 2;
                E = 9 * 4 / 2;
                F = 55 * 4 / 2;
                G = 0 / 2;
                H = 480 * 4 / 2;
                I = 70 * 4 / 2;
                J = 410 * 4 / 2;
                // Overdrive Speed
                A = 1.5 * 4;
                B = 7.5 * 4;
                C = 7.5 * 4;
                D = 2.5 * 4;
                E = 0.75 * 4;
                F = 7 * 4;
                G = 2.5 * 4;
                H = 70 * 4;
                I = 8.5 * 4;
                J = 40 * 4;
延時(shí)程序
注意,需要選用8M晶振,時(shí)鐘周期125ns
void tickDelay(uint tick) // Implementation is platform specific
  for(;tick>0;tick--);
主機(jī)復(fù)位脈沖
當(dāng)接收結(jié)果result為0時(shí),表明從機(jī)應(yīng)答
uchar OWTouchReset(void)
        uchar result;
        IO_OUT;
        tickDelay(G);
        P30 = 0; // Drives DQ low
        tickDelay(H);
        P30 = 1; // Releases the bus
        tickDelay(I);
        IO_INP;
        result = P3IN & 0X01; // Sample for presence pulse from slave
        tickDelay(J); // Complete the reset sequence recovery
        return result; // Return sample presence pulse result
像寫(xiě)DS2762寫(xiě)入一位
Send a 1-Wire write bit. Provide 10us recovery time.
void OWWriteBit(uchar bit)
        if (bit)
                // Write '1' bit
                tickDelay(A);
                tickDelay(B); // Complete the time slot and 10us recovery
                // Write '0' bit
                tickDelay(C);
                tickDelay(D);
從DS2762讀出一位
Read a bit from the 1-Wire bus and return it. Provide 10us recovery time.
uchar OWReadBit(void)
        uchar result;
        tickDelay(A);
        tickDelay(E);
        result = P3IN & 0X01; // Sample the bit value from the slave
        tickDelay(F); // Complete the time slot and 10us recovery
        return result;
像寫(xiě)DS2762寫(xiě)入一個(gè)字節(jié)
Send a 1-Wire write . Provide 10us recovery time.
DS2762特性發(fā)送所有的命令和數(shù)據(jù)都是字節(jié)的低位在前,這與多數(shù)串行通信格式相反
void OWWriteByte(uchar data)
        uchar loop;
        // Loop to write each bit in the byte, LS-bit first
        for (loop = 0; loop < 8; loop++)
                OWWriteBit(data & 0x01);
                // shift the data byte for the next bit
                data >>= 1;
從DS2762中讀一個(gè)字節(jié)
uchar OWReadByte(void)
        uchar loop, result=0;
                // shift the result to get it ready for the next bit
                result >>= 1;
                // if result is one, then set MS bit
                if (OWReadBit())
                        result |= 0x80;
        return result;
發(fā)送字符函數(shù)
按照論文圖時(shí)序進(jìn)行的操作
目前不清楚連續(xù)讀需要通過(guò)測(cè)試進(jìn)行優(yōu)化。
方案一:發(fā)出讀命令 發(fā)出一個(gè)地址 讀兩次   應(yīng)該是正確的
方案二:發(fā)出讀命令 發(fā)出兩個(gè)地址 讀兩次
uint readvoltage(void)
         uchar j = 1;
         unsigned char volhigh,vollow;
         while(j)    //檢查2762是否應(yīng)答
            j = OWTouchReset();
OWWriteByte(0xcc); //
         OWWriteByte(0x69);
         OWWriteByte(0x0c);
         vollow = OWReadByte();
         volhigh = OWReadByte();
         return ((volhigh<<8)|(vollow)); //將兩個(gè)字節(jié)進(jìn)行合并
時(shí)鐘初始化
void Init_clk(void)
{unsigned char i;
 //時(shí)基模塊的時(shí)鐘設(shè)置
 //單片機(jī)上電時(shí),MCLK主時(shí)鐘的源默認(rèn)選擇為DCO提供.F1系列DCO默認(rèn)800KHZ.
 //ACLK輔助時(shí)鐘默認(rèn)為XT1,XT1一般接32768HZ晶體.
 //SMCLK子時(shí)鐘默認(rèn)為DCO,同樣是800KHZ.
 //XT2需要人為開(kāi)啟,并要檢測(cè)其開(kāi)啟是否成功.
 BCSCTL1 &= ~(XT2OFF + XTS);   //啟動(dòng)XT2高速時(shí)鐘模塊
 BCSCTL2 |= SELM1;            //MCLK主時(shí)鐘選XT2為時(shí)鐘源.TX2輸入不分頻.
 BCSCTL2 &= ~SELS;            //SMCLK選為DCO為時(shí)鐘源.(參考)
 //剛才開(kāi)啟了XT2,需要一定時(shí)間XT2才進(jìn)入穩(wěn)定狀態(tài).所以需要等待并檢測(cè)穩(wěn)定狀態(tài).
 //通常采用do...for語(yǔ)法,這是TI推薦的程序?qū)懛?
 do
  IFG1 &=~OFIFG;              //清OSCFault 標(biāo)志
  for(i=0xff;i>0;i--)         //延時(shí)等待其開(kāi)啟穩(wěn)定
 while((IFG1 & OFIFG) !=0);   //檢查OSCFault標(biāo)志位是否為0,若為0則表示XT2開(kāi)啟穩(wěn)定.
                            //否則一直等下去...
主函數(shù)
  WDTCTL = WDTPW | WDTHOLD;            //  停止看門(mén)狗
  Init_clk();
  SetSpeed(1);
    data = readvoltage();
