串行通迅 LCD1602顯示
* 描述:(用串口調(diào)試助手軟件觀察)
* 主機(jī)發(fā)送123456給單片機(jī),單片機(jī)接收到數(shù)據(jù)后發(fā)送TX-MCU給主機(jī)。 *
* 主機(jī)發(fā)送其它數(shù)據(jù)給單片機(jī),單片機(jī)接收到數(shù)據(jù)后,再發(fā)送給主機(jī)。 *
* LCD1602顯示接收數(shù)據(jù)的ASCII碼。 波特率9600 *
* 注:當(dāng)單片機(jī)收到數(shù)據(jù)只有湊夠16個(gè)時(shí)才會一次在液晶上顯示出來 *
#include <reg52.h>
#include <intrins.h>
sbit LCD_RS = P3^5;
sbit LCD_EN = P3^4;
sbit LCD_WR = P3^6;
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar data RXDdata[ ] = {0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20,
0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x20 };
uchar temp,buf,m,count;
bit playflag=0;
uchar code cdis1[ ] = {" SERILA TRANFER "};
uchar code cdis2[ ] = {" "};
延時(shí)子程序
void delay1(uint ms)
uchar k;
while(ms--)
for(k = 0; k < 120; k++);
/*檢查LCD忙狀態(tài) */
/*lcd_busy為1時(shí),忙,等待。lcd-busy為0時(shí),閑,可寫指令與數(shù)據(jù)。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
// LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*寫指令數(shù)據(jù)到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void lcd_wcmd(uchar cmd)
// while(lcd_busy());
LCD_RS = 0;
LCD_WR = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
void lcd_wdat(uchar dat)
LCD_RS = 1;
LCD_WR = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delayNOP();
LCD_EN = 0;
/* LCD初始化設(shè)定 */
void lcd_init()
delay1(15);
lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
lcd_wcmd(0x38); //16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x38);
delay1(5);
lcd_wcmd(0x0c); //開顯示,顯示光標(biāo),光標(biāo)閃爍
delay1(5);
delay1(5);
/* 設(shè)定顯示位置 */
void lcd_pos(uchar pos)
lcd_wcmd(pos | 0x80); //數(shù)據(jù)指針=80+地址變量
發(fā)送數(shù)據(jù)函數(shù)
void senddata(uchar dat)
SBUF =dat;
while(!TI);
TI = 0;
串行中斷服務(wù)函數(shù)
void serial() interrupt 4
ES = 0; //關(guān)閉串行中斷
RI = 0; //清除串行接受標(biāo)志位
buf = SBUF; //從串口緩沖區(qū)取得數(shù)據(jù)
switch(buf)
case 0x31: senddata('T');break; //接受到1,發(fā)送字符'T'給計(jì)算機(jī)
case 0x32: senddata('X');break; //接受到2,發(fā)送字符'X'給計(jì)算機(jī)
case 0x33: senddata('-');break; //接受到3,發(fā)送字符'-'給計(jì)算機(jī)
case 0x34: senddata('M');break; //接受到4,發(fā)送字符'M'給計(jì)算機(jī)
case 0x35: senddata('C');break; //接受到5,發(fā)送字符'C'給計(jì)算機(jī)
case 0x36: senddata('U');break; //接受到5,發(fā)送字符'U'給計(jì)算機(jī)
default: senddata(buf);break; //接受到其它數(shù)據(jù),將其發(fā)送給計(jì)算機(jī)
if(buf!=0x0D)
if(buf!=0x0A)
temp =buf;
if(count<16)
RXDdata[count]=temp;
count++;
if(count==16)
playflag=1;
ES = 1; //允許串口中斷
數(shù)據(jù)顯示函數(shù)
void play()
if(playflag)
lcd_pos(0x40); //設(shè)置位置為第二行
for(m=0;m<16;m++)
lcd_wdat(cdis2[m]); //清LCD1602第二行
delay1(5);
for(m=0;m<16;m++)
// lcd_pos(0x40+m); //設(shè)置顯示位置為第二行
lcd_wdat(RXDdata[m]); //顯示字符
delay1(5);
playflag=0;
count=0x00;
for(m=0;m<16;m++)
RXDdata[m]=0x20; //清顯存單元
delay1(5);
主函數(shù)
void main(void)
P0 = 0xff;
P2 = 0xff;
SCON=0x50; //設(shè)定串口工作方式
PCON=0x00; //波特率不倍增
TMOD=0x20; //定時(shí)器1工作于8位自動重載模式, 用于產(chǎn)生波特率
EA=1;
ES = 1; //允許串口中斷
TL1=0xfd;
TH1=0xfd; //波特率9600
TR1=1;
lcd_init();
lcd_pos(0x00); //設(shè)置顯示位置為第一行
for(m=0;m<16;m++)
lcd_wdat(cdis1[m]); //顯示字符
delay1(5);
lcd_pos(0x40); //設(shè)置顯示位置為第二行
for(m=0;m<16;m++)
lcd_wdat(cdis2[m]); //顯示字符
delay1(5);
play();
