專注電子技術(shù)學習與研究
當前位置:單片機教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
單片機矩陣按鍵定時器消抖程序源碼
作者:寒竹子   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年03月18日   【字體:
芯片是采用的stc89c51單片機.
下面是矩陣鍵盤的電路圖,矩陣鍵盤是接在p2口的.
下面是單片機部分的圖,數(shù)碼管顯示等完整的原理圖可以從 http://www.torrancerestoration.com/f/ks51.pdf  這里下載
下面是程序源碼:
/********矩陣按鍵定時器消抖**************/
*時間:2014年3月18日20:27:23
*作者:寒竹子
*工程寫法:用定時器為按鍵消抖不占用cpu的時間
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
//138
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
//KeyIn
sbit KeyIn1 = P2^4;
sbit KeyIn2 = P2^5;
sbit KeyIn3 = P2^6;
sbit KeyIn4 = P2^7;
//KeyOut
sbit KeyOut1 = P2^3;
sbit KeyOut2 = P2^2;
sbit KeyOut3 = P2^1;
sbit KeyOut4 = P2^0;
//數(shù)碼管編碼
uchar code table[] = {
0xC0,  //"0"
                0xF9,  //"1"
                0xA4,  //"2"
                0xB0,  //"3"
                0x99,  //"4"
                0x92,  //"5"
                0x82,  //"6"
                0xF8,  //"7"
                0x80,  //"8"
                0x90,  //"9"
                0x88,  //"A"
                0x83,  //"B"
                0xC6,  //"C"
                0xA1,  //"D"
                0x86,  //"E"
                0x8E   //"F"
uchar key = 0;
//16個按鍵初始化1
uchar keysta[4][4] =
{1, 1, 1, 1}, //K1 - K4
{1, 1, 1, 1}, //K5 - K8
{1, 1, 1, 1}, //K9 - K 12
{1, 1, 1, 1} //K13 - K16
//16個按鍵的備份值初始值1
uchar keybackup[4][4] = {
{1, 1, 1, 1},
{1, 1, 1, 1},
{1, 1, 1, 1},
{1, 1, 1, 1}
void keymatrixScan();
void timer0_init();
void refresh();
void HC138_init();
timer0_init();
HC138_init();
while (1)
keymatrixScan();
/********timer0 init*************/
void timer0_init()
TMOD |= 0x01;
TMOD &= 0xF1; //1111 0001,配置T0方式1
TH0 = 0xFC;
TL0 = 0x67;//1ms
TR0 = 1;//start T0
EA = 1; //open main int
ET0 = 1;//open T0 int
/***********HC138 init*********/
void HC138_init()
ADDR3 = 1;
ENLED = 0;//使能U3
/***********刷新數(shù)碼管************/
void refresh()
static uchar j = 0;//刷新數(shù)碼管
P0 = 0xFF;//消隱
switch (j)
case 0: ADDR2 = 0; ADDR1 = 0; ADDR0 = 0;
break;
case 1: ADDR2 = 0; ADDR1 = 0; ADDR0 = 1;
break;
case 2: ADDR2 = 0; ADDR1 = 1; ADDR0 = 0;
break;
case 3: ADDR2 = 0; ADDR1 = 1; ADDR0 = 1;
break;
case 4: ADDR2 = 1; ADDR1 = 0; ADDR0 = 0;
break;
case 5: ADDR2 = 1; ADDR1 = 0; ADDR0 = 1;
break;
default:
break;
P0 = table[key]; //在此處送入顯示的數(shù)據(jù),很正常的顯示出來,當放到while(1)中時會出現(xiàn)抖動
j++;
if (j >= 6)
j = 0;
/**********矩陣按鍵檢測***********/
//16個按鍵檢測
uchar i = 0, j = 0;
for (i = 0; i < 4; i++) //4行
for (j = 0; j < 4; j++) //4列
if (keysta[j] != keybackup[j]) //檢測第i行第j列按鍵是否有動作
if (keybackup[j] == 0) //若第i行第j列的按鍵的前一個狀態(tài)為0,則由0-1,即按鍵彈起
key = i * 4 + j;//按鍵定位
//備份當前按鍵的值,以備下一次比較
keybackup[j] = keysta[j];
/**********timer0 int****************/
void timer0_int() interrupt 1 using 3
static uchar keybuf[4][4] = {
{0xFF, 0xFF, 0xFF, 0xFF},
};//16個按鍵的掃描緩沖區(qū)
static uchar keyout = 0;//按鍵的列,即KeyOut1 - KeyOut4
uchar i = 0;
TH0 = 0xFC;
TL0 = 0x67; //1ms
refresh();
//掃描第keyout列的按鍵的值
keybuf[keyout][0] = (keybuf[keyout][0] << 1) | KeyIn1;//將按鍵1的掃描值存入keybuf中
keybuf[keyout][1] = (keybuf[keyout][1] << 1) | KeyIn2;
keybuf[keyout][2] = (keybuf[keyout][2] << 1) | KeyIn3;
keybuf[keyout][3] = (keybuf[keyout][3] << 1) | KeyIn4; //每1ms掃描一列,4ms掃描四列,共掃描四位,設(shè)定掃描16ms,即每個按鍵掃描4次
//更新消抖后按鍵的值
for (i = 0; i < 4; i++) //4行, 一列4個按鍵
if ((keybuf[keyout] & 0x0F) == 0x00) //按鍵的緩沖區(qū)的低四位都是0,因為16ms只掃描了4次,移入了四位狀態(tài)值
keysta[keyout] = 0;//按鍵按下
else if ((keybuf[keyout] & 0x0F) == 0x0F) //按鍵的緩沖區(qū)的第四位都是1
keysta[keyout] = 1;//第keyout列第i行的按鍵彈起
//列++
keyout++;
//keyout 0-3
/*if (keyout >= 4)
keyout = 0;
keyout &= 0x03;//當keyout到4則會等于3
//通過keyout列數(shù)選中列
switch (keyout)
case 0: KeyOut1 = 0; KeyOut4 = 1; KeyOut2 = 1; KeyOut3 = 1; //選中第一列,開發(fā)板上的第一行
break;
case 1: KeyOut2 = 0; KeyOut1 = 1; KeyOut3 = 1; KeyOut4 = 1;
break;
case 2: KeyOut3 = 0; KeyOut1 = 1; KeyOut2 = 1; KeyOut4 = 1;
break;
case 3: KeyOut4 = 0; KeyOut1 = 1; KeyOut2 = 1; KeyOut3 = 1;
break;
default:
break;
