本程序所用的原理圖下載: 點(diǎn)這里 ,單片機(jī)芯片使用的stc89c51;找到數(shù)碼管部分的原理圖即可.這是一整個(gè)單片機(jī)開發(fā)板的電路圖其他的忽略.
以下是3個(gè)程序的源碼:
/**********利用定時(shí)器定時(shí)50毫秒動(dòng)態(tài)掃描數(shù)碼管***********/
*功能:定時(shí)器T1實(shí)現(xiàn)數(shù)碼管動(dòng)態(tài)掃瞄123456(if)
*作者:徐冉
*日期:2013-06-12-22:10
*備注:不同的方法實(shí)現(xiàn)顯示設(shè)備的動(dòng)態(tài)掃描,節(jié)約能耗
/****************AT89C52-RC MCU*************/
/****************51hei開發(fā)板*************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
//段選數(shù)據(jù)編碼表
uchar code table[] = {
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F //"9"
//位選數(shù)據(jù)編碼表
uchar code table1[] = {
0xfe,
0xfd,
0xfb,
0xf7,
0xef,
0xdf
uchar j = 1, counter = 0;
//延時(shí)程序
void display()
dula = 1;
P0 = table[j++];
dula = 0;
if(j >= 7)
j = 1;
//刷新程序
void refrash()
static uchar i = 0;
if(0 == i)
wela = 1;
P0 = table1[0];
wela = 0;
if(1 == i)
wela = 1;
P0 = table1[1];
wela = 0;
if(2 == i)
wela = 1;
P0 = table1[2];
wela = 0;
if(3 == i)
wela = 1;
P0 = table1[3];
wela = 0;
if(4 == i)
wela = 1;
P0 = table1[4];
wela = 0;
if(5 == i)
wela = 1;
P0 = table1[5];
wela = 0;
i++;
if(i >= 6)
i = 0;
//定時(shí)器T1初始化
void init()
P0 = 0x00;//關(guān)閉數(shù)碼管顯示
TMOD = 0x11;
TH1 = 0xFC; //T1定時(shí)1毫秒
TL1 = 0x66;
TR1 = 1;
EA = 1;
ET1 = 1;
//主程序
void main(void)
init();
if(counter == 50)
counter = 0;
display();//顯示
refrash();//刷新
//T1中斷服務(wù)程序
void timer1_int() interrupt 3
TH1 = 0xFC;
TL1 = 0x66;
counter++;
*功能:定時(shí)器T1實(shí)現(xiàn)數(shù)碼管動(dòng)態(tài)掃瞄123456(switch case)
*作者:徐冉
*日期:2013-06-12-21:50
#include <reg52.h>
sbit wela = P2^7;
sbit dula = P2^6;
//段選數(shù)據(jù)編碼表
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F //"9"
//位選數(shù)據(jù)編碼表
0xfe,
0xfd,
0xfb,
0xf7,
0xef,
0xdf
//延時(shí)程序
void display()
dula = 1;
P0 = table[j++];
dula = 0;
if(j >= 7)
j = 1;
//刷新程序
void refrash()
static uchar i = 0;
switch(i)
case 0: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
case 1: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
case 2: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
case 3: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
case 4: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
case 5: wela = 1; P0 = table1[i]; wela = 0; i++;
break;
default: break;
if(i >= 6)
i = 0;
//定時(shí)器T1初始化
void init()
TMOD = 0x11;
TL1 = 0x66;
TR1 = 1;
EA = 1;
ET1 = 1;
//主程序
void main(void)
init();
if(counter == 50)
counter = 0;
display();//顯示
refrash();//刷新
//T1中斷服務(wù)程序
TH1 = 0xFC;
TL1 = 0x66;
counter++;
/**********利用延時(shí)函數(shù)定時(shí)50毫秒動(dòng)態(tài)掃描數(shù)碼管***********/
*功能:延時(shí)函數(shù)實(shí)現(xiàn)數(shù)碼管動(dòng)態(tài)掃瞄123456
*作者:徐冉
*日期:2013-06-12-20:50
#include <reg52.h>
sbit wela = P2^7;
sbit dula = P2^6;
//段選編碼表
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F //"9"
//位選編碼表
0xfe,
0xfd,
0xfb,
0xf7,
0xef,
0xdf
//毫秒延時(shí)程序
void delay(uint xms)
uint x, y;
for(x = 0; x < xms; x++)
for(y = 0; y < 110; y++);
//動(dòng)態(tài)掃描程序
void display()
static uchar i = 0;//靜態(tài)變量i
dula = 1;
P0 = table[i+1];//段選數(shù)據(jù)
dula = 0;
P0 = 0xff;//消影
wela = 1;
P0 = table1[i]; //位選數(shù)據(jù)
wela = 0;
delay(50);//延時(shí)50毫秒
i++;
if(i >= 6)
i = 0;
//主程序
void main(void)
P0 = 0x00;//開始時(shí)關(guān)閉所有數(shù)碼管顯示
display();
