專注電子技術學習與研究
單片機定時器實現(xiàn)實時時鐘程序-lcd1602顯示
作者:寒竹子   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年03月21日   【字體:
本程序所用的原理圖下載: http://www.torrancerestoration.com/f/HL-1V6.5.pdf ,單片機芯片使用的stc89c52;找到1602液晶部分的原理圖即可.這是一張單片機開發(fā)板的整體圖.
下面是程序的源代碼:
*功能:在LCD1602上顯示當前時間(Time)和日期(Date)
*      自動計時,可計時年月日(包括平年和閏年)
*    可用按鍵調(diào)整時間和日期
* L  *****************************
* C  * Time: 00  Date:        *
* D  * 00:00  2013-06-05   *
*作者:徐冉
*日期:2013-06-05-19:10-22:50~2013-06-06-07:20-10:20
*備注:此程序已經(jīng)通過調(diào)試,已做修改。耗時:5小時30分鐘
/****************AT89C52-RC MCU******************************/
/********************51hei單片機實驗板****************************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit RS = P1^0;
sbit RW = P1^1;
sbit EN = P2^5;
sbit wela = P2^7;
sbit dula = P2^6;
sbit BUSY = P0^7;
sbit FM = P2^3;
uchar counter,tshi, tfen, tmiao;
uchar sshi, sge, fshi, fge, mshi, mge;
uint nian;
uchar yue, ri;
uchar nqian, nbai, nshi, nge, yshi, yge, rshi, rge;
uchar code time[] = "Time:";
uchar code date[] = "Date:";
//delay:xms
void delay(uint xms)
 uchar i, j;
 for(i = 0; i < xms; i++)
   for(j = 0; j < 125; j++);
//wait:
void wait()
 P0 = 0xff;
 RS = 0;
 RW = 1;
 EN = 0;
 EN = 1;
 while(BUSY == 1);
 EN = 0;
//write:cmd
void write_cmd(uchar cmd)
 wait(); //寫數(shù)據(jù)和命令時,必須進行判忙等待!!
 RS = 0;
 RW = 0;
 EN = 0;
 P0 = cmd;
 EN = 1;
 EN = 0;
//write:data
void write_data(uchar dat)
 wait();//寫入數(shù)據(jù)之前必須進行判忙等待,否則數(shù)據(jù)將寫入不成功!!
 RS = 1;
 RW = 0;
 EN = 0;
 P0 = dat;
 EN = 1;
 EN = 0;
//LCD1602:init
void init()
 nian = 2013;
 yue = 6;
 ri = 5;
 wela = 0;
 dula = 0;
 P1 = 0xff;
 delay(10);
 write_cmd(0x38);
 delay(5);
 write_cmd(0x38);
 delay(5);
 write_cmd(0x38);
 wait();
 write_cmd(0x38);
 wait();
 write_cmd(0x0c);
 wait();
 write_cmd(0x06);
 wait();
 write_cmd(0x01);
//timer1:init
void timer1_init()
 TMOD = 0x10;
 TH1 = 0xB8;
 TL1 = 0x00;
 TR1 = 1;
 EA = 1;
 ET1 = 1;
//write:byteaddress
void write_pos(uchar add)
 write_cmd(add | 0x80);
//write:string
void send_string(uchar *str)
 while(*str != '\0')
  write_data(*str++);
//dis:date
void dates()
 nqian = nian / 1000 % 10;
 nbai = nian / 100 % 10;
 nshi = nian / 10 % 10;
 nge = nian % 10;
 yshi = yue / 10 % 10;
 yge = yue % 10;
 rshi = ri / 10 % 10;
 rge = ri % 10;
 write_pos(0x00);
 send_string(time);
 write_pos(0x09);
 send_string(date);
 write_pos(0x46);
 write_data(nqian + 0x30);
 write_pos(0x47);
 write_data(nbai + 0x30);
 write_pos(0x48);
 write_data(nshi + 0x30);
 write_pos(0x49);
 write_data(nge + 0x30);
 write_pos(0x4A);
 write_data('-');
 write_pos(0x4B);
 write_data(yshi + 0x30);
 write_pos(0x4C);
 write_data(yge + 0x30);
 write_pos(0x4D);
 write_data('-');
 write_pos(0x4E);
 write_data(rshi + 0x30);
 write_pos(0x4F);
 write_data(rge + 0x30);
//dis:time
void times()
 sshi = tshi / 10 % 10;
 sge = tshi % 10;
 fshi = tfen / 10 % 10;
 fge = tfen % 10;
 mshi = tmiao / 10 % 10;
 mge = tmiao % 10;
 write_pos(0x40);
 write_data(sshi + 0x30);
 write_pos(0x41);
 write_data(sge + 0x30);
 write_pos(0x43);
 write_data(fshi + 0x30);
 write_pos(0x44);
 write_data(fge + 0x30);
 write_pos(0x06);
 write_data(mshi + 0x30);
 write_pos(0x07);
 write_data(mge + 0x30);
//keyscan:
void marixKeyscan()
 uchar temp;
 P3 = 0xfe;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xee: tshi++; if(tshi >= 24) tshi = 0; break;
    case 0xde: tfen++; if(tfen >= 60) tfen = 0; break;
    case 0xbe: nian++; if(nian >= 10000) nian = 0; break;
    case 0x7e: yue++; if(yue >= 13) yue = 1; break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(2);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfd;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xed: ri++; if(yue == 1 || yue == 3 || yue == 5 || yue == 7 || yue == 8 || yue == 10 || yue == 12 )
          if(ri >= 32)
           ri = 1;
         if(yue == 4 || yue == 6 || yue == 9 || yue == 11)
          if(ri >= 31)
           ri = 1;
         if(yue == 2)
          if(((nian % 4 == 0) && (nian % 100) != 0) || (nian % 400 == 0))
           if(ri >= 30)
            ri = 1;
           if(ri >= 29)
            ri = 1;
         break;
     case 0xdd: tshi--; if(tshi <= 0) {tshi = 23;} break;
     case 0xbd: tfen--; if(tfen <= 0) {tfen = 59;} break;
     case 0x7d: nian--; if(nian <= 0) {nian = 10000;} break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(2);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   FM = 1;
 P3 = 0xfb;
 temp = P3;
 temp &= 0xf0;
 if(temp != 0xf0)
  delay(5);
  temp = P3;
  temp &= 0xf0;
  if(temp != 0xf0)
   FM = 0;
   temp = P3;
   switch(temp)
    case 0xeb:
      ri--;
       if(ri <= 0)
        ri = 31;
       if(ri <= 0)
        ri = 30;
      if(yue == 2)
        if(ri <= 0)
         ri = 29;
        if(ri <= 0)
         ri = 28;
       break;
     case 0xdb:  tshi = 0;
        tfen = 0;
        tmiao = 0;
        nian = 0;
        yue = 1;
        ri = 1;
        break;
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
   delay(2);
   while(temp != 0xf0)
    temp = P3;
    temp &= 0xf0;
      FM = 1;
//main:
void main(void)
 init();
 timer1_init();
 write_pos(0x42);
 write_data(':');
 write_pos(0x06);
 write_data('-');
  times();
  dates();
  marixKeyscan();
  if(counter == 50)
   counter = 0;
   tmiao++;
   if(tmiao >= 60)
    tmiao = 0;
    tfen++;
    if(tfen >= 60)
      tfen = 0;
      tshi++;
      if(tshi >= 24)
       tshi = 0;
       ri++;
        switch(yue)
         case 1:
         case 3:
         case 5:
         case 7:
         case 8:
         case 10:
         case 12: if(ri >= 32)
             ri = 1;
                yue++;
            break;
         case 4:
         case 6:
         case 9:
         case 11:   if(ri >= 31)
              ri = 1;
              yue++;
              break;
         case 2: if(((nian % 4 ) == 0 && (nian % 100) != 0) || (nian % 400 == 0))
             if(ri >= 30)
              ri = 1;
              yue++;
             if(ri >= 29)
              ri = 1;
              yue++;
            break;
         default: break;
         if(yue >= 13)
           yue = 1;
          nian++;
          if(nian >= 10000)
           nian = 0;
//timr1:int
void timer1_int() interrupt 3
 TH1 = 0xB8;
 TL1 = 0x00;
 counter++;
關閉窗口
相關文章
