本程序所用的原理圖下載: 點(diǎn)這里 ,單片機(jī)芯片使用的stc89c52;找到相應(yīng)部分即可.這是一整個(gè)單片機(jī)開發(fā)板的電路圖其他的忽略.
hex文件及其工程文件下載:http://www.torrancerestoration.com/f/youhuajs.rar以下是通過測(cè)試的源代碼:
*功能:實(shí)現(xiàn)一秒優(yōu)化計(jì)時(shí)(只顯示有效位),0~59;
*作者:徐冉
*日期:2013-05-02
/************AT89C52-RC 單片機(jī)-51hei-5實(shí)驗(yàn)板***********/
/*******************51hei-開發(fā)板**********************/
#include <reg52.h>
typedef unsigned int uint;
typedef unsigned char uchar;
sbit wela = P2^7;
sbit dula = P2^6;
uchar counter,shi,ge;
uint num;
void init();
void display(uint num1);
void delay(uint xms);
//數(shù)碼管編碼
uchar code table[] = {
0x3F, //"0"
0x06, //"1"
0x5B, //"2"
0x4F, //"3"
0x66, //"4"
0x6D, //"5"
0x7D, //"6"
0x07, //"7"
0x7F, //"8"
0x6F //"9"
//主程序
init();
display(num);
//定時(shí)器初始化程序
void init()
TMOD = 0x01;
TH0 = 0xB8;//精確定時(shí)20毫秒
TL0 = 0x00;
TR0 = 1;
EA = 1;
ET0 = 1;
//顯示子程序
shi = num1 / 10 % 10;
ge = num1 % 10;
if(num1 < 10)
dula = 1;
P0 = table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xdf;
wela = 0;
delay(1);
dula = 1;
P0 = table[shi];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xef;
wela = 0;
delay(1);
dula = 1;
P0 = table[ge];
dula = 0;
P0 = 0xff;
wela = 1;
P0 = 0xdf;
wela = 0;
delay(1);
//延時(shí)程序
uint i,j;
for(i = xms; i > 0; i--)
for(j = 110; j > 0; j--);
//定時(shí)器0中斷服務(wù)子程序
void int_time0() interrupt 1
TH0 = 0xB8;
TL0 = 0x00;
counter++;
if(counter == 50)
counter = 0;
num++;
if(num == 60)
num = 0;
