注:P1口連接至LED用于顯示紅綠燈,P0口接數(shù)碼管段碼,用于顯示時(shí)間;
兩個(gè)74HC573控制段碼和位碼。段碼接P20,位碼接P21
#include<reg52.h>
sbit DUAN=P2^0;
sbit WEI=P2^1;
全局變量
bit red,green,yellow,turnred;//定義紅綠黃燈標(biāo)志位
code unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,
0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71,0x00} ;
//共陰數(shù)碼管 0-9
uchar shi,ge;
void delay(uint t)
while(t--);
主程序
main()
TMOD |=0x01;
TH0=(65535-50000)/256;
TL0=(65535-50000)%256;
EA=1;//開中斷
ET0=1;
TR0=1;//開定時(shí)器
P1=0xfc;//紅燈亮
red =1;
WEI=1;
P0=0xfe;
WEI=0;
DUAN=1;
P0=shi;//顯示十位
DUAN=0;
delay(300);
WEI=1;
P0=0xfd;
WEI=0;
DUAN=1;
P0=ge;//顯示十位
DUAN=0;
delay(300);
定時(shí)器0中斷函數(shù)
void tim(void) interrupt 1
static uchar second=60,count;
count++;
if (count==20)
count=0;
second--;//秒減1
if(second==0)
if(red)
red=0;yellow=1;
second=5;
P1=0xF3;//黃燈亮5秒
else if(yellow && !turnred)
yellow=0;green=1;
second=50;
P1=0xCF;//綠燈亮50秒
else if(green)
yellow=1;green=0;
second=5;
P1=0xF3;//黃燈亮5秒
turnred=1;
else if(yellow && turnred)
red=1;yellow=0;
P1=0xFC;//紅燈亮60秒
second=60;
turnred=0;
shi=tab[second/10];
ge=tab[second%10];
