#include<reg51.h>
sbit DQ=P1^6;//ds18b20與單片機(jī)連接口
sbit RS=P1^0;
sbit RW=P1^1;
sbit EN=P1^2;
sbit BEEP=P1^7;
//unsigned char code str1[]={" "};
unsigned char code str2[]={" "};
uchar data disdata[5];
uint tvalue;//溫度值
uchar tflag;//溫度正負(fù)標(biāo)志
uchar hshi,hge,Th=25;
uchar Tl=20,lshi,lge;
sbit s1=P2^3; //功能
sbit s2=P2^2; //加
sbit s3=P2^1; //減
sbit gnd=P2^5;
uchar s1num;
/*************************lcd1602程序**************************/
void delay1ms(unsigned int ms)//延時(shí)1毫秒(不夠精確的)
{unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<100;j++);
void wr_com(unsigned char com)//寫指令//
{ delay1ms(1);
RS=0;
RW=0;
EN=0;
P0=com;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void wr_dat(unsigned char dat)//寫數(shù)據(jù)//
{ delay1ms(1);;
RS=1;
RW=0;
EN=0;
P0=dat;
delay1ms(1);
EN=1;
delay1ms(1);
EN=0;
void lcd_init()//初始化設(shè)置//
{delay1ms(15);
wr_com(0x38);delay1ms(5);
wr_com(0x80);delay1ms(5);
wr_com(0x01);delay1ms(5);
wr_com(0x06);delay1ms(5);
wr_com(0x0c);delay1ms(5);
void display(unsigned char *p)//顯示//
while(*p!='\0')
wr_dat(*p);
p++;
delay1ms(1);
/*****************報(bào)警設(shè)置程序******************************/
void wr_Th(uchar add,uchar Th)
wr_com(0x80+add);
hshi=Th/10;
hge=Th%10;
wr_dat(0x30+hshi); //0x30是0的ACSII碼,
wr_dat(0x30+hge); //0x30是0的ACSII碼,
void wr_Tl(uchar add,uchar Tl)
wr_com(0x80+add);
lshi=Tl/10;
lge=Tl%10;
wr_dat(0x30+lshi); //0x30是0的ACSII碼,
wr_dat(0x30+lge); //0x30是0的ACSII碼,
void wr_HL()
wr_com(0x80);
wr_dat('H');
wr_com(0x80+9);
wr_dat('L');
init_play()//初始化顯示
{ lcd_init();
wr_com(0x80);
wr_Th(4,25);
wr_Tl(12,20);
wr_HL();
wr_com(0xc0);
display(str2);
/******************************ds1820程序***************************************/
void delay_18B20(unsigned int i)//延時(shí)1微秒
while(i--);
void ds1820rst()/*ds1820復(fù)位*/
{ unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(4); //延時(shí)
DQ = 0; //DQ拉低
delay_18B20(100); //精確延時(shí)大于480us
DQ = 1; //拉高
delay_18B20(40);
uchar ds1820rd()/*讀數(shù)據(jù)*/
{ unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
{ DQ = 0; //給脈沖信號
dat>>=1;
DQ = 1; //給脈沖信號
if(DQ)
dat|=0x80;
delay_18B20(10);
return(dat);
void ds1820wr(uchar wdata)/*寫數(shù)據(jù)*/
{unsigned char i=0;
for (i=8; i>0; i--)
{ DQ = 0;
DQ = wdata&0x01;
delay_18B20(10);
DQ = 1;
wdata>>=1;
read_temp()/*讀取溫度值并轉(zhuǎn)換*/
{uchar a,b;
ds1820rst();
ds1820wr(0xcc);//*跳過讀序列號*/
ds1820wr(0x44);//*啟動溫度轉(zhuǎn)換*/
ds1820rst();
ds1820wr(0xbe);//*讀取溫度*/
a=ds1820rd();
b=ds1820rd();
tvalue=b;
tvalue<<=8;
tvalue=tvalue|a;
if(tvalue<0x0fff)
tflag=0;
{tvalue=~tvalue+1;
tflag=1;
tvalue=tvalue*(0.625);//溫度值擴(kuò)大10倍,精確到1位小數(shù)
return(tvalue);
void ds1820disp()//溫度值顯示
{ uchar flagdat;
disdata[0]=tvalue/1000+0x30;//百位數(shù)
disdata[1]=tvalue%1000/100+0x30;//十位數(shù)
disdata[2]=tvalue%100/10+0x30;//個(gè)位數(shù)
disdata[3]=tvalue%10+0x30;//小數(shù)位
if(tflag==0)
flagdat=0x20;//正溫度不顯示符號
flagdat=0x2d;//負(fù)溫度顯示負(fù)號:-
if(disdata[0]==0x30)
{disdata[0]=0x20;//如果百位為0,不顯示
if(disdata[1]==0x30)
{disdata[1]=0x20;//如果百位為0,十位為0也不顯示
wr_com(0xc0);
wr_dat(flagdat);//顯示符號位
wr_com(0xc1);
wr_dat(disdata[0]);//顯示百位
wr_com(0xc2);
wr_dat(disdata[1]);//顯示十位
wr_com(0xc3);
wr_dat(disdata[2]);//顯示個(gè)位
wr_com(0xc4);
wr_dat(0x2e);//顯示小數(shù)點(diǎn)
wr_com(0xc5);
wr_dat(disdata[3]);//顯示小數(shù)位
wr_com(0x80+0x40+7);
wr_dat(0xdf); //寫入攝氏度的小圈
wr_com(0x80+0x40+8);//寫入攝氏度的C
wr_dat('C');
/*功能按鍵掃描函數(shù)*/
void keyscan()//按鍵掃描函數(shù) ,如果有按鍵按下,按照按下的功能鍵執(zhí)行相應(yīng)功能
if(s1==0)
delay1ms(5);
if(s1==0)
s1num++;
while(!s1);//松手檢測
if(s1num==1) //
wr_com(0x80+13);
wr_com(0x0f);//光標(biāo)開始閃
if(s1num==2)//被按兩下,
wr_com(0x80+5);
if(s1num==3)//被按三下
s1num=0;
wr_com(0x0c);//開顯示,光標(biāo)不顯示
if(s1num!=0)
if(s2==0)
delay1ms(5);
while(!s2);
if(s1num==1)
Tl++;
wr_Tl(12,Tl);//
wr_com(0x80+13);//因?yàn)槊看螌懭胫?br />
針自動加一,所以將批針前移一位
if(s1num==2)
Th++;
wr_Th(4,Th);
wr_com(0x80+5);
if(s3==0)
delay1ms(5);
while(!s3);
if(s1num==1)
Tl--;
wr_Tl(12,Tl);
wr_com(0x80+13);
if(s1num==2)
Th--;
wr_Th(4,Th);
wr_com(0x80+5);
void exter0()interrupt 0
BEEP=1;
keyscan();
/********************主程序***********************************/
gnd=0;
init_play();//初始化顯示
EA=1;//開總中斷
EX0=1;//開外中部斷0
IT0=0;//設(shè)定中斷觸發(fā)方式。IT0=0是電平觸發(fā)方式。IT0=1是下降沿觸發(fā)方式。12腳當(dāng)中斷源
read_temp();//讀取溫度
ds1820disp();//顯示
if((tvalue/10)>=Th||(tvalue/10)<=Tl)
delay1ms(2000);
//BEEP=0;
BEEP=1;
