SLE4442卡_IC的51單片機(jī)驅(qū)動(dòng)程序
作者:liumei   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年03月31日   【字體:
整理了最初的實(shí)驗(yàn)草稿版,將端口宏定義,函數(shù)聲明以及常用的函數(shù)聲明建立頭文件,感覺清楚多了,在不斷地修改中凝練,在不停的實(shí)踐中提高,滿眼的思緒,在小小的Readme中劃過一筆~~~~~~~~
char data_RST[4], ErrorCount[4];
void IC_RST(void)
uchar value,i,count;
DATA_IN;  //IC輸入
RST_LOW;  //復(fù)位時(shí)序
CLK_LOW;
DATA_HIGH;
DelayUs(5);
RST_HIGH;
DelayUs(5);
CLK_HIGH;
DelayUs(5);
CLK_LOW;
DelayUs(5);
RST_LOW;
DelayUs(2);
for(i=0;i<4;i++) //讀4個(gè)BYTE  可用后面的Byte_Read()代替
  value = 0xff;
  for(count=0;count<8;count++)
   value = value >> 1;
   DelayUs(2);
   CLK_LOW;
   DelayUs(2);
   CLK_HIGH;
   DelayUs(2);
   if(RD5 == 1)
    value |= 0x80; //判斷IO腳是否為1,是則位置1
    value &= 0x7f; //否則位置0
   DelayUs(2);
  data_RST[i] = value;
  DelayUs(2);
DelayUs(2);
CLK_LOW;
DelayUs(2);
DATA_HIGH;
void IC_Init(void)  //初始化
TRISD1 = 0;
RD1 = 0;  //上電
TRISD4 = 0;  //時(shí)鐘輸出
TRISD3 = 0;  //RST輸出
DelayMs(5);  //上電的必要延時(shí),否則程序出錯(cuò)
void Start(void)
DATA_OUT; //開始時(shí)序
CLK_LOW;
DATA_HIGH;
DelayUs(2);
CLK_HIGH;
DelayUs(2);
DATA_LOW;
DelayUs(2);
CLK_LOW;
void Stop(void) //結(jié)束時(shí)序
DATA_OUT;
CLK_LOW;
NOP();
NOP();
DATA_LOW;
DelayUs(2);
CLK_HIGH;
DelayUs(2);
DATA_HIGH;
DelayUs(2);
uchar Byte_Read(void) //讀字節(jié)
uchar count;
uchar value;
DATA_IN;
DelayUs(2);
value = 0xff;
  value = value >> 1;  //循環(huán)右移,從最低位開始讀
  DelayUs(2);
  CLK_LOW;
  DelayUs(2);
  CLK_HIGH;
  DelayUs(2);
  if(RD5 == 1)
   value |= 0x80;//判斷IO腳是否為1
   value &= 0x7f;
  DelayUs(2);
return (value);
void Byte_WRT(uchar Xdata)   //寫字節(jié)
uchar count;
DATA_OUT;
DelayUs(2);
for(count=8;count!=0;count--)
  CLK_LOW;
  DelayUs(2);
  if((Xdata)&0x01)
   DATA_HIGH;
   DATA_LOW;
  DelayUs(2);
  CLK_HIGH;
  DelayUs(2);
  Xdata = Xdata >> 1;  //循環(huán)右移,從最低位開始寫
void Command(uchar command,uchar address,uchar IC_data)
Start();
Byte_WRT(command);         //發(fā)送命令
Byte_WRT(address);         //發(fā)送地址
Byte_WRT(IC_data);   //發(fā)送數(shù)據(jù)
Stop();                 //操作命令結(jié)束
void Process(void)
uint j;  //寫指令后的處理過程
DATA_OUT;
  DelayUs(2);
  CLK_LOW;
  DATA_LOW;
  DelayUs(2);
  for(j = 0;j < 255;j++)
   CLK_HIGH;
   DelayUs(2);
   CLK_LOW;
   DelayUs(2);
DATA_HIGH;
void Process2(void)
uint j;  //寫指令后的短處理過程
DATA_OUT;
  DelayUs(2);
  CLK_LOW;
  DATA_LOW;
  DelayUs(2);
  for(j = 0;j < 2;j++)
   CLK_HIGH;
   DelayUs(2);
   CLK_LOW;
   DelayUs(2);
DATA_HIGH;
uchar Code_Check(uchar Code1,uchar Code2,uchar Code3)  //密碼校驗(yàn)函數(shù)
uchar i;
Command(0x31,0x00,0x00);
for(i = 0;i < 4;i++)
  ErrorCount[i] = Byte_Read();
if(ErrorCount[0] == 0)
  return 0;
  if((ErrorCount[0]&0x01) == 1)
   ErrorCount[0] &= 0x06;      //bit0=0;
  else if((ErrorCount[0]&0x02) == 1)
   ErrorCount[0] &= 0x05;      //bit1=0;
   ErrorCount[0] &= 0x03;      //bit2=0
Command(0x39,0x00,ErrorCount[0]);
Process();
Command(0x33,0x01,Code1);
Process2();
Command(0x33,0x02,Code2);
Process2();
Command(0x33,0x03,Code3);
Process2();
Command(0x39,0x00,0xff);
Process();
for(i = 0;i < 4;i ++)
if(ErrorCount[0] == 0x07)
  return 1;
  return 0;
void ReadMainROM(uchar addr,uchar *p,uchar N)  //讀主存區(qū)
Command(0x30,addr,0xff);
while(N--)
  *p=Byte_Read();
     p++;
void WriteMainROM(uchar addr,uchar *t,uchar N)  //寫主存區(qū)
while(N--)
  Command(0x38,addr,*t);
  Process();
  addr++;
  t++;
void ReadProROM(uchar addr,uchar *p,uchar N)  //讀保護(hù)區(qū)
Command(0x34,addr,0xff);
while(N--)
  *p=Byte_Read();
     p++;
void WriteProROM(uchar addr,uchar *t,uchar N)  //寫保護(hù)區(qū)
while(N--)
  Command(0x3c,addr,*t);
  Process();
  addr++;
  t++;
void ReadCode(uchar addr,uchar *p,uchar N)  //讀密碼
Command(0x31,addr,0xff);
while(N--)
  *p=Byte_Read();
     p++;
void WriteCode(uchar addr,uchar *t,uchar N)  //寫密碼
while(N--)
  Command(0x39,addr,*t);
  Process();
  addr++;
  t++;
