專注電子技術學習與研究
帶中斷MSP430G2553控制程序和錯誤處理
作者:huqin   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年04月08日   【字體:
MSP430G2553板LED在P1.0和P1.6,和P1.3連著一個按鈕開關,可以對其進行中斷編程。
#include "MSP430G2553.h"
int ms,k,i;
char jj[]={
           0x01,0x00,0x40,0x00,0x01,0x00,0x40,0x00,0x40,0x00,0x01,
           0x00,0x40,0x00,0x01,0x00,0x41,0x00,0x41,0x00,0x41,0x00
void delay(int ms)
  while(ms--)
    for(i=0;i<120;i++);
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  P1DIR |=BIT6+BIT0;
  P1IE  |=BIT3;
  P1IES |=BIT3;
  P1IFG &=~BIT3;
  _BIS_SR(GIE);
    for(k=0;k<22;k++)
     P1OUT=jj[k];
     delay(300);
 #pragma   vector=PORT1_VECTOR
 __interrupt void zhansan(void)
        for(k=0;k<5;k++)
           P1OUT |=BIT6+BIT0;
           delay(1000);
           P1OUT &=~(BIT6+BIT0);
           delay(1000);
        P1IFG &=~BIT3;
IAR調試msp430時出現(xiàn)警告提示:
The stack plug-n failed to set a breakpoint on "main". The Stack window will not be able to display stack contents. (You can change this setting in the Tool>Options dialog box.)需要進行以下配置:
 1. iar->options->linker->output->format;
    選擇 Debug information for c-SPY選項
 2. iar->Tools->options->stack->去掉選項“stack pointer(s) not valid until program reaches”
關閉窗口
相關文章
