UDA1341TS驅(qū)動程序
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2014年04月21日   【字體:
雖然濾波器的設(shè)置上還不是那么完美,但應(yīng)該也算是于征服了UDA1341TS。這個(gè)驅(qū)動做了很久一直在用串口監(jiān)測錄音數(shù)據(jù),但由于噪聲的影響, 一直不知怎么回事,今天算是大功告成了,甚是開心,決定把代碼貼出來做個(gè)慶祝,同時(shí)希望后學(xué)者能用得上。直管coppy不會介意的。注解:端口初始化函數(shù) (uda_io_init())L3操作函數(shù)(WriteL3())錄音函數(shù)(record())播放函數(shù)(playsound())。提示:時(shí)鐘要知道 怎么設(shè)置(我使用MDK的啟動代碼設(shè)置了)對照S3C2440A 和UDA1341TS的datasheet來設(shè)置IIS和L3問題不大了,我這個(gè)驅(qū)動沒有使用DMA,而是通過CPU來讀寫的,不用多說了,我想你懂的。
/*L3MODE:J7(GPB2);L3DATA:K3(GPB3);L3CLOCK:K4(GPB4)*/
#define L3MODE  (1<<2)
#define L3DATA   (1<<3)
#define L3CLOCK  (1<<4)
//**********uda1341ts端口初始化
void uda_io_init()
 /*IISLRCLK=GPE0,IISSCLK=GPE1,CDCLK=GPE2,IISSDI=GPE3,IISSDO=GP4*/
 GPECON|=(1<<1)|(1<<3)|(1<<5)|(1<<7)|(1<<9);
 GPEUP|=(1<<4)|(1<<3)|(1<<2)|(1<<1)|(1<<0);;
 GPBCON|=(1<<4)|(1<<6)|(1<<8);
 GPBUP|=(1<<4)|(1<<3)|(1<<2);
//**********L3寫
void WriteL3(unsigned char data, unsigned char mode)
 //mode = 0,地址模式;mode = 1,數(shù)據(jù)傳輸模式
 int i, k;
 uda_io_init();
 if(mode == 0)  //地址模式時(shí)序
    GPBDAT = GPBDAT & ~(L3MODE|L3DATA|L3CLOCK )|L3CLOCK;
 else     //數(shù)據(jù)模式時(shí)序
    GPBDAT = GPBDAT & ~(L3MODE|L3DATA|L3CLOCK)|(L3CLOCK|L3MODE);
 for(k = 0; k < 5; k++);          //延時(shí)
 for(i = 0; i < 8; i++)
     if(data & 0x1)
         GPBDAT &= ~L3CLOCK;
         GPBDAT |= L3DATA;          //發(fā)送高電平
         GPBDAT |= L3CLOCK;
         GPBDAT |= L3DATA;
         GPBDAT &= ~L3CLOCK;
         GPBDAT &= ~L3DATA;    //發(fā)送低電平
         GPBDAT |= L3CLOCK;
         GPBDAT &= ~L3DATA;
     data >>= 1;
//**********記錄錄音止
void record()
   unsigned short int temp;
   unsigned int i,stop=0,count=0;
    WriteL3(0x14+2,0);
    WriteL3(0x60,1);   //復(fù)位
    WriteL3(0x14+2,0);
    WriteL3(0x10,1);     //00010000 系統(tǒng)時(shí)鐘頻率384fs
    WriteL3(0x14+2,0);
    WriteL3(0xa2,1);    //10100010 輸入增益6db,ADC開,DAC關(guān)
    WriteL3(0x14+0,0);
    WriteL3(0x0,1);          //音量衰減0db
   WriteL3(0x14+0,0);
    WriteL3(0x7b,1);         //01,1110,11 (BB 18dB~24dB) Treble 6dB
   WriteL3(0x14+0,0);
    WriteL3(0x90,1);         //采樣頻率為44.1khz
    WriteL3(0xc0,1);
    WriteL3(0xe0,1);         //000,00000 MA 0dB
    WriteL3(0xc4,1);
    WriteL3(0xf0,1);         //100,1,00,00 AGC使能
    WriteL3(0xc2,1);
    WriteL3(0xf9,1);         //010,110,11 MIC 27dB input 1選擇 通道2關(guān)閉
    WriteL3(0xc6,1);
    WriteL3(0xe0,1);         //output lever -9db ATTACK TIME=11ms,DECAY TIME=100ms
    /*IIS配置*/
    IISCON = (0<<5)|(0<<4)|(1<<3)|(0<<2)|(1<<1);         //DMA禁止,在接受空閑狀態(tài),不產(chǎn)生IISLRCK信號,IIS預(yù)分頻使能
    IISMOD = (0<<9)|(0<<8)|(1<<6)|(0<<5)|(0<<4)|(1<<3)|(1<<2)|(1<<0); //主設(shè)備時(shí)鐘PCLK,主設(shè)備模式,接收模式,串行數(shù)據(jù)16位,主時(shí)鐘是384fs,串行位時(shí)鐘32fs
    IISPSR = (2<<5)|2;            //預(yù)分頻都是N=2
    IISFCON = (0<<14)|(1<<12);       //發(fā)送FIFO正常,發(fā)送FIFO使能
 IISCON|=(1<<0);      //iis開啟
   while(stop==0)
      if((IISCON & (1<<6))==0)          //檢查輸入FIFO是否為滿
         //FIFO中的數(shù)據(jù)為16位,深度為32
         //當(dāng)輸入FIFO為滿時(shí),一次性讀取FIFO中的32個(gè)16位數(shù)據(jù)
         for(i=0;i<32;i++)
            temp=IISFIFO;
   record_buffer[count+2*i]=temp;
            record_buffer[count+2*i+1]=(temp>>8);
   //IISFIFO=0;
         count+=64;
         if(count>500000)
         stop=1;                    //當(dāng)錄制的數(shù)據(jù)超過數(shù)組長度時(shí),退出
 stop=0;
 IISCON = 0x0;               //關(guān)閉IIS
 GPBCON|=1;           //蜂鳴器輸出
 GPBDAT|=1;       //蜂鳴器輸出高點(diǎn)平
 delay_us(100);
 GPBDAT&=~(1<<0);     //蜂蜜輸出低電平
void playsound(unsigned char *buffer, int length)
 int count,i;
 char flag;
 GPBDAT = GPBDAT & ~(L3MODE|L3CLOCK|L3DATA) |(L3MODE|L3CLOCK); //L3開始傳輸:L3M=H, L3C=H
 //配置UDA1341
 WriteL3(0x14 + 2,0);            //狀態(tài)模式(000101xx+10)
 WriteL3(0x60,1);          //0,1,10, 000,0 : 狀態(tài)0,復(fù)位
 WriteL3(0x14 + 2,0);            //狀態(tài)模式 (000101xx+10)
 WriteL3(0x10,1);          //0,0,01, 000,0 : 狀態(tài)0, 384fs,IIS,no DC-filtering
 WriteL3(0xc1,1);           //1,0,0,0, 0,0,01:狀態(tài)1,
 //Gain of DAC 6 dB,Gain of ADC 0dB,ADC non-inverting,
 //DAC non-inverting,Single speed playback,ADC-Off DAC-On
 //配置s3c2440的IIS寄存器
 //預(yù)分頻器為2,所以CDCLK=PCLK/(3+1)=16.928kHz
 IISPSR = 2<<5|2;
 //無效DMA,輸入空閑,預(yù)分頻器有效
 IISCON  = (0<<5)|(0<<4)|(0<<3)|(1<<2)|(1<<1);
 //PCLK為時(shí)鐘源,輸出模式,IIS模式,每個(gè)聲道16位,CODECLK=384fs,SCLK=32fs
 IISMOD  = (0<<9)|(0<<8)|(2<<6)|(0<<5)|(0<<4)|(1<<3)|(1<<2)|(1<<0);
 IISFCON = (0<<15)|(1<<13);           //輸出FIFO正常模式,輸出FIFO使能
 flag=1;
 count=0;
 //開啟IIS
 IISCON |= 0x1;
 while(flag)
  if((IISCON & (1<<7))==0)               //檢查輸出FIFO是否為空
   //當(dāng)輸出FIFO為空時(shí),一次性向FIFO寫入32個(gè)16位數(shù)據(jù)
   for(i=0;i<32;i++)
    IISFIFO=(buffer[2*i+count])+(buffer[2*i+1+count]<<8);
   count+=64;
   if(count>length)
   flag=0;                  //音頻數(shù)據(jù)傳輸完,則退出
