測試環(huán)境:MPLAB IDE v8.73
測試芯片:PIC16F877A
所需器件:
PIC16F877A單片機最小系統(tǒng)板
L298N電機驅(qū)動模塊
4P杜邦線
最終的主要的電路實物連接圖
最終測試圖
電路連接圖:
對應(yīng)程序一的電路原理圖
程序一:簡單實現(xiàn)兩個電機的正反轉(zhuǎn),未加調(diào)速。
#include <pic.h> //調(diào)用頭文件,可以去PICC軟件下去查找PIC16F87XA單片機的頭文件
__CONFIG(XT&WDTDIS&LVPDIS); //定義配置字,晶振類型:XT,關(guān)閉開門狗,禁止低電壓編程
/*宏定義區(qū)*/
#define IN1 RB7//Left Motor
#define IN2 RB6//Left Motor
#define IN3 RB5//Right Motor
#define IN4 RB4//Right Motor
/*相關(guān)函數(shù)聲明部分*/
void delay_ms(unsigned int ms);//聲明延時函數(shù)
void IO_Config(void);//聲明IO配置函數(shù)
void Motor_Go_Forward(void);//聲明前進函數(shù)
void Motor_Go_Back(void);//聲明后退函數(shù)
void Motor_Turn_Left(void);//聲明左轉(zhuǎn)函數(shù)
void Motor_Turn_Right(void);//聲明右轉(zhuǎn)函數(shù)
//Name: 系統(tǒng)主函數(shù)
//Created By: xd
//Email: 58969288@qq.com
//Date: 2014-04-05
void main(void)
IO_Config();//調(diào)用IO配置函數(shù)
Motor_Go_Forward();//小車前進
Motor_Go_Back();//小車后退
Motor_Turn_Right();//小車右轉(zhuǎn)
Motor_Turn_Left();//小車左轉(zhuǎn)
//Name: 延時函數(shù)
//Description:to delay time
//Created By: xd
//Date: 2014-04-05
while(--ms);
//Name: IO配置函數(shù)
//Created By: xd
//Date: 2014-04-05
void IO_Config(void){
TRISA = 0B11111111; //RA0-RA7設(shè)置為輸入
TRISB = 0B00001111; //RB0-RB3設(shè)置為輸入,RB4-RB7設(shè)置為輸出
TRISC = 0B00000000; //RC0-RC7設(shè)置為輸出
TRISD = 0B00000000; //RD0-RD7設(shè)置為輸出
PORTB = 0B00000000; //RB初始化輸出或輸入低電平
PORTC = 0B00000000; //RC初始化輸出低電平
PORTD = 0B00000000; //RD初始化輸出低電平
//Name: 前進函數(shù)
//Description:Left Motor↑ Right Motor↓
//Created By: xd
//Date: 20104-04-05
void Motor_Go_Forward(void){
IN1 = 0;
IN2 = 1;
IN3 = 0;
IN4 = 1;
//Name: 后退函數(shù)
//Description:Left Motor↓ Right Motor↓
//Created By: xd
//Date: 2014-04-05
void Motor_Go_Back(void){
IN1 = 1;
IN2 = 0;
IN3 = 1;
IN4 = 0;
//Name: 右轉(zhuǎn)函數(shù)
//Created By: xd
//Date: 2014-04-05
void Motor_Turn_Right(void){
IN1 = 1;
IN2 = 0;
IN3 = 0;
IN4 = 1;
//Name: 左轉(zhuǎn)函數(shù)
//Description:Left Motor↓ Right Motor↑
//Created By: xd
//Date: 2014-04-05
void Motor_Turn_Left(void){
IN1 = 0;
IN2 = 1;
IN3 = 1;
IN4 = 0;
程序二:可以實現(xiàn)直流電機的調(diào)速,這里在上面的原理基礎(chǔ)上,將L298N模塊的ENA和ENB連接的短接冒拔下來,將ENA接在RC1上,ENB接在RC2上。
#include <pic.h>//調(diào)用頭文件
__CONFIG(XT & WDTDIS & LVPDIS);//定義配置字,晶振類型:XT,關(guān)閉開門狗,禁止低電壓編程
/*宏定義區(qū)*/
#define IN1 RB7//Left Motor,L298N模塊的IN1
#define IN2 RB6//Left Motor,L298N模塊的IN1
#define IN3 RB5//Right Motor,L298N模塊的IN1
#define IN4 RB4//Right Motor,L298N模塊的IN1
void PWM_Init(void);//聲明PWM初始化函數(shù)
void Motor_Speed_Config(unsigned char PWM1,unsigned char PWM2);//聲明電機速度調(diào)節(jié)函數(shù)
//Created By: xd
//Date: 2014-04-05
void main(void) //主函數(shù),單片機開機后就是從這個函數(shù)開始運行
IO_Config();//調(diào)用IO端口配置函數(shù)
PWM_Init();//調(diào)用PWM初始化函數(shù)
while(1) //死循環(huán),單片機初始化后,將一直運行這個死循環(huán)
//占空比為0% --傳的實參為0
//占空比為20% --傳的實參為20
//占空比為40% --傳的實參為40
//占空比為60% --傳的實參為60
//占空比為80% --傳的實參為80
//占空比為100% --傳的實參為100
//當(dāng)調(diào)用void Motor_Speed_Config(unsigned char PWM1,unsigned char PWM2)
//時傳入的兩個參數(shù)如果相等的話,左右電機將獲得相同占空比的PWM信號,此時小
//可以前進或者后退;當(dāng)傳入的兩個參數(shù)不相等的話,那么左右電機將獲得不同占空比
//的PWM,獲得的速度也就會不一樣,這樣就會實現(xiàn)小車的左轉(zhuǎn)或右轉(zhuǎn)的效果,當(dāng)
//占空比設(shè)置為0時,小車的左右電機停止轉(zhuǎn)動,可以實現(xiàn)小車停車效果
Motor_Speed_Config(100,100);
//Name: PWM初始化函數(shù)
//Created By: xd
//Date: 2014-04-05
void PWM_Init(void){
//PWM周期 = (PR2 + 1) * 4 * Tosc * (TMR2預(yù)分頻值)
//PWM頻率 = 1/【PWM周期】
//其中Tosc這里為4MHz,TMR2預(yù)分頻值下面設(shè)置的為1
CCP1CON = 0B00001100; //設(shè)置CCP1為PWM模式,PWM占空比bit1:0,bit0:0;
CCP2CON = 0B00001100; //設(shè)置CCP2為PWM模式,PWM占空比bit1:0,bit0:0;
PR2 = 99;//頻頻:10.000KHZ周期:0.0001s
/*T2CKPS1:T2CKPS0:TMR2時鐘預(yù)分頻選擇位*/
/*0 0 = 預(yù)分頻值為1*/
/*0 1 = 預(yù)分頻值為4*/
/*1 x = 預(yù)分頻值為16*/
T2CKPS1 = 0;
T2CKPS0 = 0;//前分頻為1:1
TMR2IF = 0;//清零PIR1寄存器中的TMR2IF中斷標(biāo)志位
TMR2ON = 1;//啟動TIMER2
//PWM占空比 = (CCPRxL:CCPxCON<5:4>) * Tosc * (TMR2預(yù)分頻值)
CCPR1L = 0;//占空比初始值為0
CCPR2L = 0;//占空比初始值為0
//這里具體說明下占空比的計算方法:例如要設(shè)置占空比為80%,這里PWM
//周期設(shè)置為0.0001s,0.0001 * 80% = x * 1/4MHz * 1
//計算得到x = 320,因為CCP1CON = 0B00001100或者CCP2CON = 0B00001100;
//這么設(shè)置的,那么PWM占空比的bit1:0,bit0:0;CCPR1L或CCPR2L為其bit9-bit2,
//所以寫入CCPR1L或CCPR2L中的值為320除以4等于80,即輸出占空比為80%的PWM信號
//就往CCPR1L或CCPR2L中寫入80,這樣在RC1或RC2引腳上就可以輸出相應(yīng)占空比的
//的PWM信號,設(shè)置PWM頻率為10KHz,有個好處就是,這里計算占空比很容易,設(shè)置
//占空比的數(shù)值和寫入CCPR1L或CCPR2L中的值一樣
T2CKPS1 = 0;
//Name: IO配置函數(shù)
//Created By: xd
//Date: 2014-04-05
//Name: 電機速度調(diào)節(jié)函數(shù)
//Description:
//Created By: xd
//Date: 2014-04-05
void Motor_Speed_Config(unsigned char PWM1,unsigned char PWM2){
CCPR1L = PWM1;
IN1 = 0;
IN2 = 1;
CCPR2L = PWM2;
IN3 = 0;
IN4 = 1;
