單片機C語言時鐘源碼
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年05月02日   【字體:
 此程序是在51hei單片機開發(fā)板上面做的,如需要移植到自己的電路上,修改相應(yīng)的端口即可,開發(fā)板完整的電路圖下載:  點這里 (注意:只需要看相關(guān)部分即可,其他部分可以忽略)
//****80c52***時鐘程序
//***手把手教你學(xué)單片開發(fā)板***
//**2012/9/7***23:02***
# include<reg52.h>
typedef unsigned char uint8;
typedef unsigned int  uint16;
typedef unsigned long uint32;
uint8 block[]={0xc0,0xf9,0xa4,0xb0,0x99,
  0x92,0x82,0xf8,0x80,0x90};//顯示數(shù)組
uint8 a[6];
uint16 counter=0;
uint32 sec=0;
#define tr 40  //發(fā)聲值
bit MS    = 1;    //狀態(tài)字;
sbit ADDR0 = P1^0; //A0****
sbit ADDR1 = P1^1; //A1*****
sbit ADDR2 = P1^2; //A2*****
sbit ADDR3 = P1^3; //E1|E2**
sbit ENLED = P1^4; //E3****38譯碼器
sbit BUZZ  = P1^6; //蜂鳴器
sbit    keyout1 = P2^3; //按鍵公共端
sbit keyin1  = P2^4; //k1 長安0.1S進入時間調(diào)節(jié);
sbit keyin2  = P2^5; //k2 時間調(diào)節(jié)斷碼選擇
sbit keyin3  = P2^6; //k3 調(diào)節(jié)時間加
sbit keyin4  = P2^7; //k4 調(diào)節(jié)時間減
void refresh_LS(); //數(shù)碼管掃描函數(shù)
void timer1_int(); //定時器1中斷函數(shù)
void keying(); //按鍵讀取函數(shù)
void display(); //數(shù)碼管顯示函數(shù)
void buzzer(); //蜂鳴器發(fā)聲函數(shù)
void delay(uint16 n); //延時函數(shù)
main()
keyout1 = 0;
keyin1 = 1; keyin2 = 1; keyin3 = 1; keyin4 = 1;
ENLED = 0; ADDR3 = 1;
timer1_int();
display();
if(keyin1 == 0)
delay(100000);
if(keyin1 == 0)
MS = ~MS;
buzzer();
while(!keyin1);
if(MS == 0)keying();
void buzzer()
static  uint8 i=0;
for(i=0;i<tr;i++)
BUZZ =~BUZZ;
delay(100);
    BUZZ = 1;
while(n--);
void timer1_int()
TMOD |= 0X10;
TMOD &= 0xdf;
TH1   = 0xfc;
TL1   = 0x67;
TR1   = 1;
EA    = 1;
ET1   = 1;
void interrupt_tiner1() interrupt 3
TH1 = 0xfc;
TL1 = 0x67;
counter++;
if(counter == 1000)
display();
refresh_LS();
void display()
counter = 0;
if(sec>=86400)sec=0;
a[0] = 0x7f&block[sec%10];
a[1] = block[sec/10%6];
a[2] = 0x7f&block[sec/60%10];
a[3] = block[sec/600%6];
a[4] = 0x7f&block[sec/3600%10];
a[5] = block[sec/36000%3];
if(MS ==1)sec++;
void keying()
static uint8 i=0,y,y1;
   if(keyin2 == 0)
i+=2;
if(i == 6)i=0;
delay(500);
else if(keyin3 == 0)
if(i == 0)sec++;
if(i == 2)sec+=60;
if(i == 4)sec+=3600;
delay(1000);
else if(keyin4 == 0)
if(i == 0)sec--;
if(i == 2)sec-=60;
if(i == 4)sec-=3600;
delay(500);
display();
if((keyin1 == 0)||(keyin2 == 0)||(keyin3 == 0)||(keyin4 == 0))buzzer();
while((keyin1 == 0)||(keyin2 == 0)||(keyin3 == 0)||(keyin4 == 0));
y    = a[i];
y1   = a[i+1];
a[i] = 0xff;
a[i+1]=0xff;
delay(5000);
a[i]  = y;
a[i+1]=y1;
delay(5000);
void refresh_LS()
static uint8 j=0;
switch(j)
case 0: ADDR0 = 0; ADDR1 = 0; ADDR2 = 0; P0=a[0]; j++; break;
case 1: ADDR0 = 1; ADDR1 = 0; ADDR2 = 0; P0=a[1]; j++; break;
case 2: ADDR0 = 0; ADDR1 = 1; ADDR2 = 0; P0=a[2]; j++; break;
case 3: ADDR0 = 1; ADDR1 = 1; ADDR2 = 0; P0=a[3]; j++; break;
case 4: ADDR0 = 0; ADDR1 = 0; ADDR2 = 1; P0=a[4]; j++; break;
case 5: ADDR0 = 1; ADDR1 = 0; ADDR2 = 1; P0=a[5]; j=0; break;
default: break;
