當前位置:單片機教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
240128液晶單片機驅(qū)動
作者:浪子   來源:浪子   點擊數(shù):  更新時間:2014年06月10日   【字體:
方波;
鋸齒波正弦波
#include<AT89X52.H>
#include <INTRINS.H>
#include<math.h>
#define uint  unsigned int
// 繪圖坐標限制
#define glcd_XMAX 240
#define glcd_XMIN 0
#define glcd_YMAX 128
#define glcd_YMIN 0
#define L240DAT P1
sbit L240CD=P3^3;
sbit L240RD=P3^4;
sbit L240WR=P3^5;
sbit L240BC=P1^0;
sbit L240BD=P1^1;
sbit RST=P3^2;
sbit    CLK=P3^0;
sbit    DAT= P3^1;
sbit    CS= P3^7;
 void   L_Delay()
   uchar i;
   for ( i=0; i<48; i++ ) ;
 void  S_Delay()                      //在傳送指令或字節(jié)時,CLK要持續(xù)8μs的高電平.
    char i;
        for ( i=0; i<8; i++ ) ;
void line(int x1, int y1, int x2, int y2, unsigned char show)
 int dy ;
 int dx ;
 int stepx, stepy, fraction;
 dy = y2 - y1;         //Y長度
 dx = x2 - x1;         //X長度
 if (dy < 0)           //Y2<Y1:
  dy = -dy;
  stepy = -1;   //Y負向
  stepy = 1;    //Y正向
 if (dx < 0)
  dx = -dx;     //X負向
  stepx = -1;
  stepx = 1;    //X正向
 dy <<= 1;             //DY左移一位*2
 dx <<= 1;
        if((x2<240&x1>0)|(x1<240&x2>0))
 {writepoint(x1,y1,show);}
 if (dx > dy)
  fraction = dy - (dx >> 1);
  while (x1 != x2)
   if (fraction >= 0)
    y1 += stepy;
    fraction -= dx;
   x1 += stepx;
   fraction += dy;
  fraction = dx - (dy >> 1);
  while (y1 != y2)
   if (fraction >= 0)
    x1 += stepx;
    fraction -= dy;
   y1 += stepy;
   fraction += dx;
void circle(int x, int y, int radius, unsigned char show)
 int xc = 0;
 int yc ;
 int p ;
        clear_graph();
 yc=radius;
 p = 3 - (radius<<1);
 while (xc <= yc)
  writepoint(x + xc, y + yc, show);//在X+XC(圓點附近值最大)上下畫兩個點
  writepoint(x + xc, y - yc, show);
  writepoint(x - xc, y + yc, show);//在X-XC上下畫兩個點
  writepoint(x - xc, y - yc, show);
  writepoint(x + yc, y + xc, show);//在X+YC(最右側(cè)數(shù)值最小)上下畫兩個點
  writepoint(x + yc, y - xc, show);
  writepoint(x - yc, y + xc, show);//在X-YC(最右側(cè)數(shù)值最。┥舷庐媰蓚點
  writepoint(x - yc, y - xc, show);
  if (p < 0)
  p += (xc++ << 2) + 6;
  p += ((xc++ - yc--)<<2) + 10;
       Delay(500) ;
void fangbo (uchar F,int A)                   //周期為T,振幅為A,能顯示240/T個周期
      {  uchar T0;
         int j=0;
         clear_graph();
         l240wc(0x9C);//98開圖,9c開文本和圖,94開文本
        af(A,F);
        T0=1000/F;
        line(00,64,240,64,1);
        for(j=0;j<240/T0;j++)
        { line(j*T0,64-A,(2*j+1)*T0/2,64-A,1);
          line((2*j+1)*T0/2,64+A,(j+1)*T0,64+A,1);
void juchibo(uchar F,int A)
   {  int i=0;
      float T0;
      clear_graph();
      l240wc(0x9c);
       T0=1000/F;
        af(A,F);
      for(i=0;i<240/T0;i++)
         { line(i*T0,64,(i+1)*T0,64-A,1);
           line((i+1)*T0,64-A,(i+1)*T0,64,1);
//********正弦函數(shù)顯示**************************
//四個參數(shù)分別為:x,y為原點坐標(精確位置);t為周期;f為振幅。
void zhengxian (uchar x,uchar y,uchar t,uchar A)
{  uchar i=0,j=0,m=0,p=0,q=0;
   m=x;
   clear_graph();
    l240wc(0x9c);
   af(A,t);
       A=45;
       t=30;
    line(00,64,240,64,1);//x軸,從x到y(tǒng)+f+10
 writepoint(x,y-(uchar)A*sin(0),1); //坐標原點(x,y)
  for(i=0;i<=230-m;i++)  // m=x,230-x個點
  if(i!=0)  //i!=0時畫點(),x為原點橫坐標,p=0????
   p=q ;
   writepoint(x,p,1);
   else p=y;  //開始i=0時,
   j++;   x++;  //橫坐標加一,每個周期內(nèi)第j個采樣值,指針遞增
   q=y-(unsigned char)A*sin(6.28*j/t);//q=y-f*sin(jw);振幅;2πj/t=jw
   line(x,p,x,q,1);//橫坐標為0,縱坐標從0到振幅的直線
   if(j==t)  //如果采樣個數(shù)達到周期,重新開始下一周期
    j=0;
uchar kbscan(void)
{uchar sccode,j,k=0;
 P1=0xf0;
if((P1&0xf0)!=0xf0)
{Delay(30);
 if((P1&0xf0)!=0xf0)
  {sccode=0xfe;
   for(j=0;j<4;j++)
     {P1=sccode;
      if((P1&0xf0)!=0xf0)
   {k=~P1;
   while((P1&0XF0)!=0XF0);
    return (k);
      else sccode=(sccode<<1)|0x01;
return(0);
uchar bian(uchar key)
{switch(key)
{case 0x81: return   0;break;
 case 0x82: return   1;break;
 case 0x84: return   2;break;
 case 0x88: return   3;break;
 case 0x41: return   4;break;
 case 0x42: return   5;break;
 case 0x44: return   6;break;
 case 0x48: return   7;break;
 case 0x21: return   8;break;
 case 0x22: return   9;break;
 case 0x24: return   10;break;
 case 0x28: return   11;break;
 case 0x11: return   12;break;
 case 0x12: return   13;break;
 case 0x14: return   14;break;
 case 0x18: return   15;
 default:
 break;
main()
 uchar key;
        int fb=1,sjb=0,zxb=0;
        uchar f1=40,f2=200,f3=100;
 RST=0;
  Delay(10);
 RST=1;
 Delay(100);
  intl240();  ///初始化必有
        clear_c();
  key=bian(kbscan());
                Write7279(0xC8,key);
       switch (key)
          {      case 1:if(fb==1)               //1鍵頻率加100
                        {f1=jiaf(f1);
                         P2=f1;
                         fangbo(f1,35);
                         else if(sjb==1)
                         {f2=jiaf(f2);
                         P2=f2;
                         juchibo(f2,40);
                         else {f3=jiaf(f3);
                         P2=f3;
                         zhengxian(00,64,f3,45);
                         break;
                  case 2:if(fb==1)              //2鍵頻率減100
                        {f1=jianf(f1);
                        P2=f1;
                        fangbo(f1,35);
                        else if(sjb==1)
                       {f2=jianf(f2);
                        P2=f2;
                        juchibo(f2,40);
                        else if(zxb==1)
                       {f3=jianf(f3);
                        P2=f3;
                        break;
                 case 4:fb=1;
                        sjb=0;
                        zxb=0;
                        P0=0x01;        //201方波
                        fangbo(f1,35);
                        break;
                 case 5:fb=0;
                        sjb=1;
                        zxb=0;
                        P0=0x02;        //202鋸齒波
                        juchibo(f2,40);
                        break;
                 case 6:fb=0;
                        sjb=0;
                        zxb=1;
                        P0=0x03;       //203正弦波
                        break;
                 case 15:clear_c();
                         clear_graph();
                         l240wc(0x9c);
                         default:
                          break;
