51單片機(jī)控制DS18B20測(cè)溫的PID溫控程序
作者:未知   來(lái)源:不詳   點(diǎn)擊數(shù):  更新時(shí)間:2014年07月31日   【字體:
#include<reg51.h>
#include<intrins.h>
#include<math.h>
#include<string.h>
struct PID {
unsigned int SetPoint; // 設(shè)定目標(biāo) Desired Value
unsigned int Proportion; // 比例常數(shù) Proportional Const
unsigned int Integral; // 積分常數(shù) Integral Const
unsigned int Derivative; // 微分常數(shù) Derivative Const
unsigned int LastError; // Error[-1]
unsigned int PrevError; // Error[-2]
unsigned int SumError; // Sums of Errors
struct PID spid; // PID Control Structure
unsigned int rout; // PID Response (Output)
unsigned int rin; // PID Feedback (Input)
sbit data1=P1^0;
sbit clk=P1^1;
sbit plus=P2^0;
sbit subs=P2^1;
sbit stop=P2^2;
sbit output=P3^4;
sbit DQ=P3^3;
unsigned char flag,flag_1=0;
unsigned char high_time,low_time,count=0;//占空比調(diào)節(jié)參數(shù)
unsigned char set_temper=35;
unsigned char temper;
unsigned char i;
unsigned char j=0;
unsigned int s;
void delay(unsigned char time)
     unsigned char m,n;
     for(n=0;n
     for(m=0;m<2;m++){}
void write_bit(unsigned char bitval)
  EA=0;
  DQ=0;
if(bitval==1)
  _nop_();
  DQ=1;
 delay(5);
 DQ=1;
_nop_();
_nop_();
EA=1;
void write_byte(unsigned char val)
     unsigned char i;
    unsigned char temp;
    EA=0;
    TR0=0;
for(i=0;i<8;i++)
  temp=val>>i;
  temp=temp&1;
  write_bit(temp);
  delay(7);
// TR0=1;
  EA=1;
unsigned char read_bit()
unsigned char i,value_bit;
EA=0;
DQ=0;
_nop_();
_nop_();
DQ=1;
for(i=0;i<2;i++){}
value_bit=DQ;
EA=1;
return(value_bit);
unsigned char read_byte()
unsigned char i,value=0;
EA=0;
for(i=0;i<8;i++)
if(read_bit())
value|=0x01<<i;
delay(4);
EA=1;
return(value);
unsigned char reset()
unsigned char presence;
EA=0;
DQ=0;
delay(30);
DQ=1;
delay(3);
presence=DQ;
delay(28);
EA=1;
return(presence);
void get_temper()
unsigned char i,j;
do
   i=reset();
}  while(i!=0);
     i=0xcc;
   write_byte(i);
   i=0x44;
   write_byte(i);
   delay(180);
do
   i=reset();
}  while(i!=0);
   i=0xcc;
   write_byte(i);
   i=0xbe;
   write_byte(i);
   j=read_byte();
   i=read_byte();
   i=(i<<4)&0x7f;
   s=(unsigned int)(j&0x0f);     //得到小數(shù)部分
   s=(s*100)/16;
   j=j>>4;
   temper=i|j;
void PIDInit (struct PID *pp)
memset ( pp,0,sizeof(struct PID));    //全部初始化為0
unsigned int PIDCalc( struct PID *pp, unsigned int NextPoint )
unsigned int dError,Error;
Error = pp->SetPoint - NextPoint;          // 偏差
pp->SumError += Error;                     // 積分
dError = pp->LastError - pp->PrevError;    // 當(dāng)前微分
pp->PrevError = pp->LastError;
pp->LastError = Error;
return (pp->Proportion * Error             // 比例項(xiàng)
+ pp->Integral * pp->SumError              // 積分項(xiàng)
+ pp->Derivative * dError);                // 微分項(xiàng)
void compare_temper()
unsigned char i;
if(set_temper>temper)      //是否設(shè)置的溫度大于實(shí)際溫度
   if(set_temper-temper>1)  //設(shè)置的溫度比實(shí)際的溫度是否是大于1度
   high_time=100;      //如果是,則全速加熱
   low_time=0;
       else  //如果是在1度范圍內(nèi),則運(yùn)行PID計(jì)算
    for(i=0;i<10;i++)
    get_temper();   //獲取溫度
     rin = s; // Read Input
    rout = PIDCalc ( &spid,rin ); // Perform PID Interation
    if (high_time<=100)
      high_time=(unsigned char)(rout/800);
          high_time=100;
      low_time= (100-high_time);
else if(set_temper<=temper)
   if(temper-set_temper>0)
    high_time=0;
    low_time=100;
     for(i=0;i<10;i++)
         get_temper();
     if (high_time<100)
      high_time=(unsigned char)(rout/10000);
      high_time=0;
// else
void serve_T0() interrupt 1 using 1
if(++count<=(high_time))
output=1;
else if(count<=100)
output=0;
count=0;
TH0=0x2f;
TL0=0xe0;
void serve_sio() interrupt 4 using 2
void disp_1(unsigned char disp_num1[6])
unsigned char n,a,m;
for(n=0;n<6;n++)
// k=disp_num1[n];
 for(a=0;a<8;a++)
     clk=0;
  m=(disp_num1[n]&1);
  disp_num1[n]=disp_num1[n]>>1;
  if(m==1)
   data1=1;
   data1=0;
   _nop_();
   clk=1;
   _nop_();
void display()
unsigned char code number[]={0xfc,0x60,0xda,0xf2,0x66,0xb6,0xbe,0xe0,0xfe,0xf6};
unsigned char disp_num[6];
unsigned int k,k1;
k=high_time;
k=k00;
k1=k/100;
if(k1==0)
disp_num[0]=0;
disp_num[0]=0x60;
k=k0;
disp_num[1]=number[k/10];
disp_num[2]=number[k];
k=temper;
k=k0;
disp_num[3]=number[k/10];
disp_num[4]=number[k]+1;
disp_num[5]=number[s/10];
disp_1(disp_num);
unsigned char z;
unsigned char a,b,flag_2=1,count1=0;
unsigned char phil[]={2,0xce,0x6e,0x60,0x1c,2};
TMOD=0x21;
TH0=0x2f;
TL0=0x40;
SCON=0x50;
PCON=0x00;
TH1=0xfd;
TL1=0xfd;
PS=1;
EA=1;
EX1=0;
ET0=1;
ES=1;
TR0=1;
TR1=1;
high_time=50;
low_time=50;
PIDInit ( &spid );    // Initialize Structure
spid.Proportion = 10; // Set PID Coefficients  比例常數(shù) Proportional Const
spid.Integral = 8;    //積分常數(shù) Integral Const
spid.Derivative =6;   //微分常數(shù) Derivative Const
spid.SetPoint = 100; // Set PID Setpoint 設(shè)定目標(biāo) Desired Value
if(plus==0)
EA=0;
for(a=0;a<5;a++)
for(b=0;b<102;b++){}
if(plus==0)
set_temper++;
flag=0;
else if(subs==0)
for(a=0;a<5;a++)
for(b=0;a<102;b++){}
if(subs==0)
 set_temper--;
 flag=0;
else if(stop==0)
     for(a=0;a<5;a++)
    if(stop==0)
   flag=0;
   break;
   EA=1;
       get_temper();
   b=temper;
if(flag_2==1)
  a=b;
if((abs(a-b))>5)
  temper=a;
  temper=b;
  a=temper;
  flag_2=0;
if(++count1>30)
  display();
  count1=0;
  compare_temper();
   TR0=0;
   z=1;
    EA=0;
if(stop==0)
     for(a=0;a<5;a++)
    if(stop==0)
    disp_1(phil);
// break;
EA=1;
