專注電子技術(shù)學習與研究
當前位置:單片機教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
freertos創(chuàng)建函數(shù)xTaskCreate( vIntegerGenerator, IntGen, 200, NULL, 1, NULL)
作者:未知   來源:布冬冬 的空間   點擊數(shù):  更新時間:2014年08月16日   【字體:
signed portBASE_TYPE xTaskGenericCreate( pdTASK_CODE pxTaskCode, const signed char * const pcName, unsigned short usStackDepth, void *pvParameters, unsigned portBASE_TYPE uxPriority, xTaskHandle *pxCreatedTask, portSTACK_TYPE *puxStackBuffer, const xMemoryRegion * const xRegions )
signed portBASE_TYPE xReturn;
tskTCB * pxNewTCB;
 configASSERT( pxTaskCode );
 configASSERT( ( uxPriority < configMAX_PRIORITIES ) );
 //分配任務(wù)TCB和堆棧
 pxNewTCB = prvAllocateTCBAndStack( usStackDepth, puxStackBuffer );
 if( pxNewTCB != NULL )
  portSTACK_TYPE *pxTopOfStack;
  #if( portUSING_MPU_WRAPPERS == 1 )
   portBASE_TYPE xRunPrivileged;
   if( ( uxPriority & portPRIVILEGE_BIT ) != 0U )
    xRunPrivileged = pdTRUE;
    xRunPrivileged = pdFALSE;
   uxPriority &= ~portPRIVILEGE_BIT;
  #endif
//判斷堆棧增長方式是否是由高到低增長
  #if( portSTACK_GROWTH < 0 )
   pxTopOfStack = pxNewTCB->pxStack + ( usStackDepth - ( unsigned short ) 1 );
//保持堆棧為字節(jié)對齊?
   pxTopOfStack = ( portSTACK_TYPE * ) ( ( ( portPOINTER_SIZE_TYPE ) pxTopOfStack ) & ( ( portPOINTER_SIZE_TYPE ) ~portBYTE_ALIGNMENT_MASK  ) );
   configASSERT( ( ( ( unsigned long ) pxTopOfStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
  #else
   pxTopOfStack = pxNewTCB->pxStack;
   configASSERT( ( ( ( unsigned long ) pxNewTCB->pxStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
   pxNewTCB->pxEndOfStack = pxNewTCB->pxStack + ( usStackDepth - 1 );
  #endif
  //TCB初始化
  prvInitialiseTCBVariables( pxNewTCB, pcName, uxPriority, xRegions, usStackDepth );
   pxNewTCB->pxTopOfStack = pxPortInitialiseStack( pxTopOfStack, pxTaskCode, pvParameters, xRunPrivileged );
  #else
//匯編語言對堆棧進行初始化
   pxNewTCB->pxTopOfStack = pxPortInitialiseStack( pxTopOfStack, pxTaskCode, pvParameters );
  #endif
  portALIGNMENT_ASSERT_pxCurrentTCB( ( ( ( unsigned long ) pxNewTCB->pxTopOfStack & ( unsigned long ) portBYTE_ALIGNMENT_MASK ) == 0UL ) );
  if( ( void * ) pxCreatedTask != NULL )
   *pxCreatedTask = ( xTaskHandle ) pxNewTCB;
  taskENTER_CRITICAL();
   uxCurrentNumberOfTasks++;//更新系統(tǒng)任務(wù)數(shù)
   if( pxCurrentTCB == NULL )
    pxCurrentTCB =  pxNewTCB;
    if( uxCurrentNumberOfTasks == ( unsigned portBASE_TYPE ) 1 )
     //如果當前任務(wù)數(shù)為1的話,則證明米有初始化就緒列表,等待列表,掛起列表等
    //初始化就緒列表的時候,定義優(yōu)先級為一個數(shù)據(jù)數(shù)組,則每個數(shù)據(jù)數(shù)組的元素代表一個優(yōu)先級
//其他列表則沒有這么復(fù)雜 直接定義 不區(qū)分優(yōu)先級
     prvInitialiseTaskLists();
    //比較,將當前最高的優(yōu)先級賦給pxCurrentTCB
    if( xSchedulerRunning == pdFALSE )
     if( pxCurrentTCB->uxPriority <= uxPriority )
   //更新uxTopUsedPriority,方便查詢的時候直接從uxTopUsedPriority開始查詢
   if( pxNewTCB->uxPriority > uxTopUsedPriority )
    uxTopUsedPriority = pxNewTCB->uxPriority;
   #if ( configUSE_TRACE_FACILITY == 1 )
    pxNewTCB->uxTCBNumber = uxTCBNumber;
   #endif
   uxTCBNumber++;
//將任務(wù)添加到就緒列表中。當任務(wù)處于阻塞態(tài)的時候,從就緒列表中刪除,加入到阻塞列表中。
   prvAddTaskToReadyQueue( pxNewTCB );
   xReturn = pdPASS;
   traceTASK_CREATE( pxNewTCB );
  taskEXIT_CRITICAL();
  xReturn = errCOULD_NOT_ALLOCATE_REQUIRED_MEMORY;
  traceTASK_CREATE_FAILED();
 if( xReturn == pdPASS )
  if( xSchedulerRunning != pdFALSE )
   if( pxCurrentTCB->uxPriority < uxPriority )
    portYIELD_WITHIN_API();
 return xReturn;
