#include "SPI.h"
#define DEBUGMSG printf
STATIC UINT32 g_unSpi0Rx0Data = 0, g_unSpi1Rx0Data = 0;
*函數(shù)名稱:Spi0MasterInit
*輸 入:無
*輸 出:無
*功 能:SPI0初始化為主機(jī)模式
VOID Spi0MasterInit(VOID)
P1_MFP &= ~(P14_AIN4_SPI0SS | P15_AIN5_SPI0MOSI | P16_AIN6_SPI0MISO | P17_AIN7_SPI0CLK);
P1_MFP |= (SPI0SS | SPI0MOSI | SPI0MISO | SPI0CLK) ; //使能SPI0相關(guān)引腳
ENABLE_SPI0_CLK; //SPI0時(shí)鐘使能
SPI0_SSR &= ~LVL_H; //從機(jī)選擇選擇信號(hào)通過低電平激活
SPI0_CNTRL &= ~LSB_FIRST; //優(yōu)先發(fā)送/接收最高有效位
SPI0_CNTRL &= ~CLKP_IDLE_H; //SCLK空閑時(shí)為低電平
SPI0_CNTRL |= TX_NEG_F; //SDO 信號(hào)在SPICLK的下降沿改變
SPI0_CNTRL &= ~RX_NEG_F; //SDI 信號(hào)在SPICLK上升沿鎖存
CLKDIV &= 0xFFFFFFF0; //HCLK_N = 0, Pclk = SYSclk/(HCLK_N+1)
SPI0_DIVIDER &= 0xFFFF0000; //SPIclk = Pclk/((HCLK_N+1)*2)
SPI0_DIVIDER |= 0x00000002;
SET_SPI0_MASTER_MODE; //SPI0工作在主機(jī)模式
ENABLE_SPI0_AUTO_SLAVE_SLECT; //使能自動(dòng)從機(jī)選擇
SPI0_SSR |= SSR_ACT;
*函數(shù)名稱:Spi0Send1W
*輸 入:ulData 發(fā)送的數(shù)據(jù)
ucLength 數(shù)據(jù)長(zhǎng)度
*輸 出:無
*功 能:SPI0發(fā)送數(shù)據(jù)
VOID Spi0Send1W(UINT32 ulData, UINT8 ucLength)
SPI0_CNTRL &= TX_NUM_ONE;
Spi0Length(ucLength);
SPI0_TX0 = ulData;
SPI0_CNTRL |= GO_BUSY;
*函數(shù)名稱:GetSlaveID
*輸 入:無
*輸 出:無
*功 能:獲取從機(jī)ID
VOID GetSlaveID(VOID)
Spi0Send1W(0x00000055, 0x08);
while((SPI0_CNTRL & GO_BUSY)!=0);
Spi0Send1W(0x00000000, 0x08);
g_unSpi0Rx0Data = SPI0_RX0;
*函數(shù)名稱:Spi0Length
*輸 入:ucLength 數(shù)據(jù)長(zhǎng)度
*輸 出:無
*功 能:設(shè)置SPI0數(shù)據(jù)長(zhǎng)度
VOID Spi0Length(UINT8 ucLength)
if(ucLength <= 0x20)
if((ucLength & 0x01) == 0)
SPI0_CNTRL &= ~(1<<3);
SPI0_CNTRL |= (1<<3);
if((ucLength & 0x02) == 0)
SPI0_CNTRL &= ~(1<<4);
SPI0_CNTRL |= (1<<4);
if((ucLength & 0x04) == 0)
SPI0_CNTRL &= ~(1<<5);
SPI0_CNTRL |= (1<<5);
if((ucLength & 0x08) == 0)
SPI0_CNTRL &= ~(1<<6);
SPI0_CNTRL |= (1<<6);
if((ucLength & 0x10) == 0)
SPI0_CNTRL &= ~(1<<7);
SPI0_CNTRL |= (1<<7);
*函數(shù)名稱:Spi1SlaveInit
*輸 入:無
*輸 出:無
*功 能:SPI1初始化為從機(jī)
VOID Spi1SlaveInit(VOID)
P0_MFP &= ~(P04_AD4_SPI1SS | P05_AD5_SPI1MOSI | P06_AD6_SPI1MISO | P07_AD7_SPI1CLK);
P0_MFP |= (SPI1SS | SPI1MOSI | SPI1MISO | SPI1CLK) ; //使能SPI1相關(guān)引腳
ENABLE_SPI1_CLK;
SPI1_SSR &= LTRIG_EDG; //從機(jī)輸入邊沿觸發(fā)
SPI1_SSR &= ~LVL_H; //從機(jī)選擇選擇信號(hào)通過低電平激活
SPI1_CNTRL &= ~LSB_FIRST; //優(yōu)先發(fā)送/接收最高有效位
SPI1_CNTRL &= ~CLKP_IDLE_H; //SCLK空閑時(shí)為低電平
SPI1_CNTRL |= TX_NEG_F; //SDO 信號(hào)在SPICLK的下降沿改變
SPI1_CNTRL &= ~RX_NEG_F; //SDI 信號(hào)在SPICLK上升沿鎖存
SPI1_DIVIDER &= 0xFFFF0000; //SPIclk = Pclk/((HCLK_N+1)*2)
SPI1_DIVIDER |= 0x00000002;
SET_SPI1_SLAVE_MODE; //SPI1工作在從機(jī)模式
ENABLE_SPI1_INTERRUPT; //使能SPI1中斷
NVIC_ISER |= SPI1_INT;
Spi1Length(8); //設(shè)置SPI1數(shù)據(jù)長(zhǎng)度
SPI1_GO_BUSY; //等待SPI1 RX0接收信號(hào)
*函數(shù)名稱:Spi1Length
*輸 出:無
*功 能:設(shè)置SPI1數(shù)據(jù)長(zhǎng)度
VOID Spi1Length(UINT8 ucLength)
SPI1_CNTRL &= ~(1<<3);
SPI1_CNTRL |= (1<<3);
SPI1_CNTRL &= ~(1<<4);
SPI1_CNTRL |= (1<<4);
SPI1_CNTRL &= ~(1<<5);
SPI1_CNTRL |= (1<<5);
SPI1_CNTRL &= ~(1<<6);
SPI1_CNTRL |= (1<<6);
SPI1_CNTRL &= ~(1<<7);
SPI1_CNTRL |= (1<<7);
*函數(shù)名稱:PrintGetData
*輸 入:無
*輸 出:無
*功 能:打印SPI0/1接收到的數(shù)據(jù)
VOID PrintGetData(VOID)
DEBUGMSG("Slave Get Command = %X\n", g_unSpi1Rx0Data);
DEBUGMSG("Master Get Feed Back Data = %X\n", g_unSpi0Rx0Data);
*函數(shù)名稱:SPI1_IRQHandler
*輸 入:無
*輸 出:無
*功 能:SPI1中斷服務(wù)函數(shù)
VOID SPI1_IRQHandler(VOID)
SPI1_CNTRL |= SPI_IF; //清除中斷標(biāo)志
if(SPI1_RX0 == 0x55)
g_unSpi1Rx0Data = SPI1_RX0;
SPI1_TX0 = 0x000000DA;
SPI1_TX0 = 0x00000000;
*函數(shù)名稱:main
*輸 入:無
*輸 出:無
*功 能:函數(shù)主體
INT32 main(VOID)
PROTECT_REG //ISP下載時(shí)保護(hù)FLASH存儲(chǔ)器
PWRCON |= XTL12M_EN; //默認(rèn)時(shí)鐘源為外部晶振
while((CLKSTATUS & XTL12M_STB) == 0); //等待12MHz時(shí)鐘穩(wěn)定
CLKSEL0 = (CLKSEL0 & (~HCLK)) | HCLK_12M; //設(shè)置外部晶振為系統(tǒng)時(shí)鐘
UartInit(12000000,9600); //波特率設(shè)置為9600bps
Spi0MasterInit(); //SPI0初始化為主機(jī)模式
Spi1SlaveInit(); //SPI1初始化為從機(jī)模式
DEBUGMSG("Master will send 0x55 data to slave and receive 0xDA data\r\n");
DEBUGMSG("Put AnyKey to Start Test\r\n");
GetSlaveID();
PrintGetData();
printf("\r\n\r\n");
Delayms(1000);
