專注電子技術學習與研究
LCD12232液晶的模塊化程序(51單片機)
作者:小卒   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2014年10月24日   【字體:
         lcd12232.h頭文件
#ifndef _LCD12232_H_
#define _LCD12232_H_
extern void lcd12232_busy(); //忙標志函數(shù)
extern void lcd12232_init(); //初始化函數(shù)
extern void lcd12232_clear();//清屏函數(shù)
extern void lcd12232_hanzi(unsigned char m,unsigned char n,unsigned char p,unsigned char y);//第一個參數(shù)代表的是共顯示幾個字(空格也算一個漢字),第二個參數(shù)是從第幾個字開始顯示,第三個參數(shù)是選屏,第四個是頁地址
                   //選屏函數(shù),2為兩屏,1為左屏,0為右屏
                   //頁地址設置的參數(shù)值應該為0、1、2三個數(shù)中的一個,因為液晶一共分為四頁
//extern void lcd12232_zifu(unsigned char m,unsigned char n,unsigned char y,unsigned char d);//第一個參數(shù)代表的是第幾個字,第二個參數(shù)是選屏,第三個參數(shù)是頁地址,第四個參數(shù)是列地址
#endif
         lcd12232.c文件
#include<reg51.h>
#define uint  unsigned char
#define port P0
sbit e1=P2^1;
sbit e2=P2^2;
sbit a0=P2^0;
sbit rw=P2^3;
uchar code ziku[]=
 0x00,0x00,0x00,0xC0,0x70,0x20,0x00,0xFF,0x00,0x10,0x20,0xC0,0x80,0x00,0x00,0x00,//小
 0x04,0x02,0x01,0x00,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00,0x01,0x07,0x02,0x00,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空" 什么也不顯示,需要的時候把它放在任意位置來當空格使用
 0x00,0x04,0x84,0x44,0x3C,0x44,0x85,0x06,0x04,0xC4,0x3C,0x44,0x84,0x04,0x00,0x00,//卒
 0x04,0x05,0x04,0x04,0x04,0x04,0x05,0xFE,0x05,0x04,0x04,0x04,0x05,0x04,0x04,0x00,
 0x40,0x41,0xCE,0x04,0x00,0x80,0x40,0xBE,0x82,0x82,0x82,0xBE,0xC0,0x40,0x40,0x00,//設
 0x00,0x00,0x7F,0x20,0x90,0x80,0x40,0x43,0x2C,0x10,0x10,0x2C,0x43,0xC0,0x40,0x00,
 0x20,0x21,0x2E,0xE4,0x00,0x00,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x00,//計
 0x00,0x00,0x00,0x7F,0x20,0x10,0x08,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//!
 0x00,0x00,0x00,0x5F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//,
 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//。
 0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
 0x80,0x84,0x44,0x44,0x24,0x14,0x04,0xFF,0x04,0x14,0x24,0x24,0x46,0xC4,0x40,0x00,//"李"
 0x00,0x08,0x08,0x08,0x09,0x49,0x89,0x7D,0x0D,0x0B,0x09,0x08,0x0C,0x08,0x00,0x00,
 0x10,0x10,0x10,0xFF,0x90,0x50,0xFE,0x92,0x92,0x92,0x92,0x92,0x9A,0xD3,0x82,0x00,//"振"
 0x02,0x42,0x81,0x7F,0x40,0x30,0x0F,0x00,0xFF,0x40,0x07,0x18,0x28,0x64,0x22,0x00,
 0x80,0x40,0x20,0xF8,0x07,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x68,0x4C,0x08,0x00,//"偉"
 0x00,0x00,0x00,0xFF,0x02,0x02,0x02,0x02,0x02,0xFF,0x02,0x12,0x22,0x1F,0x02,0x00
void delay(uchar z)    //延時函數(shù)
     int x;
     for(x=z;x>0;x--);
void lcd12232_cs(uchar cs) //選屏函數(shù),2為兩屏,1為左屏,0為右屏
   switch(cs)
    case 0:e1=1,e2=0;break;
    case 1:e1=0;e2=1;break;
    case 2:e1=0;e2=0;break;
    case 3:e1=1;e2=1;break;
void lcd12232_write_com(uchar com,uchar n)//寫命令函數(shù)
 lcd12232_cs(3);
 a0=0;
 rw=0;
 port=com;
 //delay(1);
 lcd12232_cs(n);
 delay(1);
void lcd12232_write_dat(uchar dat,uchar n)//寫數(shù)據(jù)函數(shù)
a0=1;
rw=0;
lcd12232_cs(3);
port=dat;
lcd12232_cs(n);
uchar lcd12232_read()   //讀狀態(tài)函數(shù)
 uchar dat;
 //e1=0;e2=0;
 lcd12232_cs(2);
 a0=0;
 rw=1;
 port=0xff;
 delay(1);
 //e1=1;e2=1;
 lcd12232_cs(3);
 dat=port;
 delay(1);
 //e1=0;e2=0;
 lcd12232_cs(2);
 return dat;
 uchar i;
 i=lcd12232_read();
 while(i&0x80==0x80);
void lcd12232_clear()    //清屏函數(shù)
 uchar i;
 lcd12232_write_com(0xb8,2);
 lcd12232_write_com(0x00,2);
 for(i=0;i<255;i++)
 lcd12232_write_dat(0x00,2);
void lcd12232_init() //第一個參數(shù)為指令,第二個參數(shù)為選屏,2為兩屏,1為左屏,0為右屏
 lcd12232_write_com(0xe2,2);//復位
 lcd12232_write_com(0xaf,2);//總顯示開
 lcd12232_write_com(0xc0,2);//從第一行開始顯示數(shù)據(jù)
 lcd12232_write_com(0xb8,2);//設置顯示頁地址為第一頁
 lcd12232_write_com(0x00,2);//設置顯示列地址為第一列
 lcd12232_write_com(0xa1,2);//設置正向顯示,a0為逆向顯示
 lcd12232_write_com(0xa9,2);// 1/32占空比
 lcd12232_write_com(0xa4,2);//動態(tài)驅動
 lcd12232_write_com(0xee,2);
 lcd12232_clear();     //清屏
void lcd12232_hanzi(uchar m,uchar n,uchar p,uchar y)   //漢字顯示函數(shù),第一個參數(shù)代表的是顯示m個字,第二個參數(shù)是從第n個字開始顯示,第三個參數(shù)是選屏,第四個是頁地址
 uchar i,a;
 lcd12232_write_com(0xb8+y,2);
 for(a=0;a<m;a++)
  for(i=0;i<16;i++)
   lcd12232_write_dat(ziku[i+a*32+(n-1)*32],p);
 lcd12232_write_com(0xb9+y,2);
 for(a=0;a<m;a++)
  for(i=0;i<16;i++)
   lcd12232_write_dat(ziku[i+a*32+16+(n-1)*32],p);
/*void lcd12232_zifu(uchar m,uchar n,uchar y,uchar d)  //第一個參數(shù)代表的是第幾個字,第二個參數(shù)是選屏,第三個參數(shù)是頁地址,第四個參數(shù)是列地址
 uchar i;
 lcd12232_write_com(0x00+d,2);
 for(i=0;i<16;i++)
 lcd12232_write_dat(ziku[m*32+i],n);
 for(i=0;i<16;i++)
 lcd12232_write_dat(ziku[m*32+i+16],n);
           main.c主文件
#include<reg51.h>
#include"lcd12232.h"
lcd12232_busy();//忙檢測
lcd12232_hanzi(3,1,1,1);//第一個參數(shù)代表的是共顯示幾個字(空格也算一個漢字),第二個參數(shù)是從第幾個字開始顯示,第三個參數(shù)是選屏,第四個參數(shù)是頁地址
lcd12232_busy();
lcd12232_hanzi(4,4,0,1);
//lcd12232_zifu(0,1,0,0);//第一個參數(shù)代表的是第幾個字,第二個參數(shù)是選屏,第三個參數(shù)是頁地址,第四個參數(shù)是列地址
while(1);
關閉窗口
相關文章
