請(qǐng)問(wèn)為什么(Rxbuff[0]=='0')&&(Rxbuff[1]==',')&&(Rxbuff[3]=='O')這個(gè)條件能夠判斷是否有客戶(hù)端連接到WiFi以及 為什么(Rxbuff[9]=='1')&&(Rxbuff[10]=='0')能夠判斷手機(jī)發(fā)送過(guò)來(lái)的指令要求關(guān)燈
全部代碼如下
#include "DHT11.h"
#include <stdio.h>
#include "string.h"
extern unsigned char F16T,F16RH; //溫濕度數(shù)據(jù)
sbit LED1=P2^0;
sbit LED2=P2^3;
unsigned char idata Rxbuff[50],Rxnum;
unsigned char Recwifi_data[5],led[2];
char *strx=0;
char clinetid;//連接ID
unsigned char getflag;//獲取標(biāo)志
void Get_Clinet(void);
void InitUART(void) //這是串口的基本配置,配置他的波特率是9600.這些參數(shù)都是標(biāo)準(zhǔn)的。
TMOD = 0x20;
SCON = 0x50;
TH1 = 0xFD;
TL1 = TH1;
PCON = 0x00;
EA = 1;
ES = 1;
TR1 = 1;
void delayms(unsigned int x)
unsigned int i;
while(x--)
for(i=125;i>0;i--);
* UART 發(fā)送一字節(jié)
void UART_send_byte(char dat)
SBUF = dat; //發(fā)送
while (TI == 0); //等待發(fā)送完畢
TI = 0; //清發(fā)送完畢中斷請(qǐng)求標(biāo)志位
* UART 發(fā)送字符串
void Send_Str(unsigned char *buf)
while (*buf != '\0')
UART_send_byte(*buf++);
void ESP8266_SERVER(void)//服務(wù)器建立
Send_Str("AT\r\n");
delayms(500);
Send_Str("AT\r\n");
delayms(500);
Send_Str("AT\r\n");
delayms(500);
Send_Str("ATE0\r\n"); //關(guān)閉回顯
delayms(500);
Send_Str("AT+CWSAP=\042ESP8266_001\042,\0421234567890\042,5,3\r\n"); //設(shè)置顯示名稱(chēng)和密碼ESP8266_001 1234567890
delayms(500);
Send_Str("AT+CIPMUX=1\r\n");//啟動(dòng)多連接,建立服務(wù)器都需要配置
delayms(500);
Send_Str("AT+CIPSERVER=1,5000\r\n");//建立服務(wù)器
delayms(500);
Send_Str("AT+CIPSTO=0\r\n");
void Get_Clinet(void)//判斷是否獲取到了客戶(hù)端接入
if((Rxbuff[0]=='0')&&(Rxbuff[1]==',')&&(Rxbuff[3]=='O'))//返回連接值
getflag=1;
if((Rxbuff[0]=='0')&&(Rxbuff[1]==',')&&(Rxbuff[3]=='L'))//返回連接值
getflag=0;
void Send_DATA(uchar *buffer)
Send_Str("AT+CIPSEND=0,7\r\n");
delayms(300);
Send_Str(buffer);//發(fā)送數(shù)據(jù)
delayms(500);
if((Rxbuff[9]=='1')&&(Rxbuff[10]=='0'))//關(guān)燈
LED1=1;
if((Rxbuff[9]=='1')&&(Rxbuff[10]=='1'))//開(kāi)燈
LED1=0;
if((Rxbuff[9]=='2')&&(Rxbuff[10]=='0')) //關(guān)燈
LED2=1;
if((Rxbuff[9]=='2')&&(Rxbuff[10]=='1'))//開(kāi)燈
LED2=0 ;
unsigned char Tx_Buf[10];
unsigned char LEDstatus;//燈的狀態(tài)
delayms(500);
delayms(500);
delayms(1000); //延時(shí)一段時(shí)間,讓W(xué)IFI模塊穩(wěn)定
InitUART(); //初始化串口
ESP8266_SERVER(); //初始化ESP8266
Get_Clinet();
if(getflag)
getDHT11(); //獲取溫濕度值
Tx_Buf[0]='T'; //幀頭
Tx_Buf[1]=F16T/10%10+0x30; //將溫濕度數(shù)據(jù)送往發(fā)送數(shù)組,送給藍(lán)牙模塊讓手機(jī)APP顯示
Tx_Buf[2]=F16T%10+0x30;
Tx_Buf[3]=F16RH/10%10+0x30;
Tx_Buf[4]=F16RH%10+0x30;
LEDstatus=LED1;
Tx_Buf[5]=LEDstatus+0x30;//發(fā)送燈的狀態(tài)
LEDstatus=LED2;
Tx_Buf[6]=LEDstatus+0x30;
Send_DATA(Tx_Buf) ;//發(fā)送數(shù)據(jù)
/*****************串口接收中斷函數(shù),接收數(shù)據(jù)*********************/
void UARTInterrupt(void) interrupt 4
if(RI)
ES=0;
RI = 0;
Rxbuff[Rxnum]=SBUF;
if(Rxbuff[Rxnum]=='\n')
Rxnum=0;
Rxnum++;
if(Rxnum>22)
Rxnum=0;
ES=1;
