查看: 6739|回復(fù): 5
JD642項(xiàng)目簡(jiǎn)介
ID:72008 發(fā)表于 2015-1-13 00:52 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
項(xiàng)目簡(jiǎn)介:
基于TMS320DM642芯片,主要實(shí)現(xiàn)運(yùn)動(dòng)檢測(cè)和自動(dòng)跟蹤
功能接口要求:
視頻輸入:2路分時(shí)復(fù)用
視頻輸出:1路VGA輸出
串口通訊:UART+RS485各1路
網(wǎng)絡(luò)口:10M 100M自適應(yīng)網(wǎng)口1路
主要使用芯片:
DSP:TMS320DM642A(GDKA6,600M主頻,理論處理最高速度可達(dá)4800M條指令每秒)
SDRAM:HY57V283220((L)T(P)-H)(設(shè)計(jì)使用133M外頻)
FLASH:AM29LV320D(T90EC)
Video in:TVP5150A(PBS)
Video out:SAA7105H
UART:SC16C2550(IB48)
RS485:MAX487E
Internet:LXT971A(LC)
CPLD:EPM3064A(TC100-10)
PLL:ICS512
WDT:MAX706T(CSA)
IIC EEPROM:24C16
使用軟件:
SCH&PCB:PROTEL99SE
CPLD編程調(diào)試:QuartusⅡ
DSP編程調(diào)試:CCS
原理圖及PCB仿真:multisim(for SCH) and Hyperlynx(for PCB)
此項(xiàng)目的pcb文件下載地址:http://www.torrancerestoration.com/f/JD642.rar
ID:1 發(fā)表于 2015-1-13 01:43 | 只看該作者
JD642電源設(shè)計(jì):
  各電源均由5V電源轉(zhuǎn)換得到(所需電流值為(1430*3.3/90%+70*5+850*1.4/85%)/5=1440mA)。1.4V和3.3V均使用MAX1951ESA提供,1MHz的開關(guān)頻率能極大的降低濾波需求,雖然芯片成本高一些,但提高了系統(tǒng)的電源利用率,降低了對(duì)5V供電的需求,很大程序上提高了模塊的可移植性。另外,電源濾波全部使用瓷片電容,不但提高了性能,還能對(duì)電源芯片提高的成本有很大補(bǔ)償。1.8V由LM1117-18得到。
  FB腳電壓達(dá)到0.8V時(shí)回路穩(wěn)定,輸出電壓VO=0.8V*(1+R3/R2)。
  R1C2是用于補(bǔ)償L1和輸出濾波電容諧振效果,保證在整個(gè)頻帶內(nèi)能提供穩(wěn)定的電源,需根據(jù)輸出電流大小和L1、C4值進(jìn)行計(jì)算,計(jì)算方法見MAX1951數(shù)據(jù)手冊(cè)。
  下面是DM642數(shù)據(jù)手冊(cè)里對(duì)DSP電源電容分布的要求:
In order to properly decouple the supply planes from system noise, place as many capacitors (caps) as possible close to the DSP. Assuming 0603 caps, the user should be able to fit a total of 60 caps, 30 for the core supply and 30 for the I/O supply. These caps need to be close to the DSP power pins, no more than 1.25 cm maximum distance to be effective. Physically smaller caps, such as 0402, are better because of their lower parasitic inductance. Proper capacitance values are also important. Small bypass caps (near 560 pF) should be closest to the power pins. Medium bypass caps (220 nF or as large as can be obtained in a small package) should be next closest. TI recommends no less than 8 small and 8 medium caps per supply (32 total) be placed immediately next to the BGA vias, using the "interior" BGA space and at least the corners of the "exterior".
Eight larger caps (4 for each supply) can be placed further away for bulk decoupling. Large bulk caps (on the order of 100 μF) should be furthest away (but still as close as possible). No less than 4 large caps per supply (8 total) should be placed outside of the BGA.
  綜上:DSP芯片附近電源電容需求如下:
  0402封裝1nF電容16*2個(gè)
  0603封裝0.1uF電容8*2個(gè)
  10uF瓷片電容2*2個(gè)
  220uF鉭電容2*2個(gè)
  上面組合應(yīng)可滿足DSP芯片電源對(duì)C、ESR、ESL需求。因采用高頻開關(guān)電源,鉭電容應(yīng)當(dāng)可以不焊,視調(diào)試情況決定是否保留。(后經(jīng)樣板調(diào)試驗(yàn)證可以去掉全部鉭電容)
ID:1 發(fā)表于 2015-1-13 01:44 | 只看該作者
JD642時(shí)鐘設(shè)計(jì):
  因?yàn)闀r(shí)鐘為高易失效元件,所以對(duì)系統(tǒng)能造成致命影響的晶體或晶振用的越少越好,合理的時(shí)鐘優(yōu)化可以很大的提高系統(tǒng)的可靠性。
  整個(gè)系統(tǒng)時(shí)鐘需求如下:
  1)50M晶振為DSP提供系統(tǒng)時(shí)鐘,同時(shí)為CPLD提供主時(shí)鐘。CPLD由此50M時(shí)鐘源產(chǎn)生兩路25M時(shí)鐘分別送到ICS512(為DSP提供EMIF所需的133M時(shí)鐘)和網(wǎng)絡(luò)接口芯片LXT971。
  2)串口擴(kuò)展芯片16C2550使用11.0592M晶體。
  3)視頻輸入芯片TVP5150使用14.31818M晶體。
  4)視頻輸出芯片SAA7105使用27M基頻晶體。
  因?yàn)镃PLD距DSP較遠(yuǎn),50M時(shí)鐘走線較長(zhǎng),經(jīng)仿真使用50歐終端并聯(lián)匹配,匹配電阻靠近DSP時(shí)鐘管腳(時(shí)鐘線遠(yuǎn)端)輸入端,50M時(shí)鐘線使用10mil寬度,P片厚度為8mil(阻抗接近50歐)。(因?yàn)檫h(yuǎn)端信號(hào)會(huì)比近端好,而DSP對(duì)時(shí)鐘占空比要求相對(duì)CPLD要高,所以把DSP放在遠(yuǎn)端,CPLD緊靠近時(shí)鐘--50M晶振在CPLD下方。因?yàn)镈SP時(shí)鐘和CPLD時(shí)鐘相位沒有要求,所以布線可以長(zhǎng)一些,有終端匹配的話信號(hào)會(huì)沒有問題的。)
ID:1 發(fā)表于 2015-1-13 01:49 | 只看該作者
JD642系統(tǒng)框圖及空間分配:
系統(tǒng)框圖如下:
EMIF接口空間分配如下:
ID:1 發(fā)表于 2015-1-13 01:54 | 只看該作者
JD642 CPLD部分設(shè)計(jì)
  選用AlteraCPLD EPM3064ATC100。內(nèi)部64個(gè)宏單元,1250可用邏輯門,最大可用IO數(shù)為66pin,應(yīng)用GCLK最高頻率為222.2MH。系統(tǒng)使用到的對(duì)應(yīng)管腳信號(hào)及功能見下表:
CPLD管腳分配及功能說(shuō)明
信號(hào)名稱
IO類型
功能及邏輯描述
備注
空間選擇:
CE[0..3]
I
DSP外部空間片選信號(hào)。
SDRAMCE0選通,其它為CE1選通
CE2配合EA[20..22]對(duì)FLASH頁(yè)高地址控制
CE3預(yù)留擴(kuò)展用,可實(shí)現(xiàn)對(duì)更大容量FLASH的兼容。
EA[19..22]
I
DSP外部存儲(chǔ)器地址高4bit。
EA22用于區(qū)分FLASH和串口,并且配合CE2EA6選擇FLASH其它存儲(chǔ)空間,以及控制報(bào)警音頻選擇,控制報(bào)警開關(guān)量輸出及備用擴(kuò)展輸出。
EA6
I
串口AB選擇
0選擇A口,為1選擇B
SDWE#
I
EMIF寫允許
透?jìng)鞯玫?font face="Times">EWE#信號(hào)
SDCAS#
I
EMIF讀允許
SDRAS#或邏輯生成WRE#信號(hào)
SDRAS#
I
EMIF輸出允許
SDCAS#或邏輯生成WRE#信號(hào)
TDOE#
O
8bit數(shù)據(jù)位通道開關(guān)
DSP CE1透?jìng)鞯玫剑?font face="Times">CE1無(wú)效時(shí)關(guān)斷
FLASHA[19..22]
O
FLASH地址高4bit
DSP只能尋址1M,其中FLASH與串口各占512kFLASH最高地址由CPLD配合CE2的高地址寫操作選擇。
CSFLASH#
O
FLASH片選信號(hào)
DSPCE1EA22選擇
CSSA#、CSSB#
O
串口AB選擇
DSPCE1EA22、EA6選擇
ERE#
O
外部存儲(chǔ)器讀允許信號(hào)
DSPSDCAS/ARESDRAS/AOE邏輯得到
EWE#
O
外部存儲(chǔ)器寫允許信號(hào)
DSPSDWE/AWE透?jìng)鞯玫?
看門狗及復(fù)位
RST_SYS#
I
看門狗芯片復(fù)位輸出信號(hào)
用于參與邏輯生成各芯片復(fù)位信號(hào)
WDI
O
清看門狗計(jì)數(shù)器信號(hào)
DSP0x900c xxxx操作或GPIO取反產(chǎn)生清狗信號(hào)
PFO#
I
電源電壓過低報(bào)警
5V供電電壓低于4V時(shí)出現(xiàn)低電平。參與邏輯生成各芯片復(fù)位信號(hào)
REST_DSP#
O
DSP復(fù)位信號(hào)
DSP復(fù)位時(shí)間可以單獨(dú)調(diào)整
REST
O
高電平復(fù)位信號(hào)輸出
16C2550高電平復(fù)位
REST#
O
低電平復(fù)位信號(hào)輸出
其它芯片復(fù)位信號(hào)
中斷處理
INTA
I
串口芯片中斷信號(hào)
高電平有效
INTB
I
串口芯片中斷信號(hào)
高電平有效
GPIO4(INTS0#)
O
串口中斷0
發(fā)送給DSP,INTA取反得到,DSPGPIO4
GPIO5(INTS1#)
O
串口中斷1
發(fā)送給DSP,INTB取反得到,接DSPGPIO5
其它信號(hào)
CLK50M
I
50M時(shí)鐘輸入
有源晶振一驅(qū)二,一路到DSP,一路到CPLD GCLK1輸入端
CLK25LXT
O
網(wǎng)口芯片25M時(shí)鐘
提供給LXT971(T觸發(fā)器)
CLK25PLL
O
PLL25M時(shí)鐘
ICS512生成133M時(shí)鐘
FLASHWP#
O
FLASH寫保護(hù)
輸出低電平時(shí)禁止寫FLASH,用于程序代碼保護(hù)
LED[1..0]
O
LED指示燈
調(diào)試或維護(hù)使用,由DSPGPIO[7..6]透?jìng)鞯玫?font face="Times">(LED0為心跳顯示)
GPIO6、GPIO7
I
DSP通用IO
用于控制LED并清看門狗
GPIO[9…12]
I
DSP通用IO
GPIO9控制485收發(fā),其余備用
ALM_Q
O
報(bào)警開關(guān)量控制
輸出到連接板的開關(guān)量(OC)。最大上拉電平為9V,灌電流為500mA
ALM_S
O
報(bào)警音頻輸出
輸出控制蜂鳴器
RESV
O
預(yù)留擴(kuò)展輸出
ALM_Q
RT485
O
485收發(fā)模式選擇
GPIO9透?jìng)鞯玫?
  系統(tǒng)共計(jì)使用23個(gè)輸入腳,25個(gè)輸出腳。報(bào)警聲調(diào)部分可能需要宏單元比較多,時(shí)鐘源為50M時(shí)鐘?赡苄枰20-30個(gè)宏單元,其他部分需要宏單元較少,總共應(yīng)不超過55個(gè)宏單元。選擇EPM3064能滿足設(shè)計(jì)需求。
  元件數(shù)據(jù)手冊(cè)里沒有芯片管腳名稱,需到www.altera.com下載封裝及引腳信息。
ID:1 發(fā)表于 2015-1-13 01:57 | 只看該作者
最后看看關(guān)于此項(xiàng)目的仿真:http://www.torrancerestoration.com/bbs/dpj-30593-1.html
