查看: 3596|回復: 3
DS18b20溫度傳感器51單片機程序 帶溫度報警功能
ID:114097 發(fā)表于 2016-4-13 22:51 | 顯示全部樓層 |閱讀模式
帶溫度報警功能
  1. /*#include<reg52.h>
  2. #include<intrins.h>
  3. #define uint unsigned int
  5. sbit DQ=P3^7;         //連接DS18B20
  6. sbit rs=P2^7;          //??1602 RS?
  7. sbit rw= P2^6;  //??1602 ?R/W?,???????
  8. sbit en=P2^5;          //??1602 E?
  9. */
  10. /*****************Happy Everyday!**************/
  11. //DS18B20????,?????1602????!???!
  12. //DS18B20????,LCD1602??
  13. #include<reg52.h>
  14. #define uchar unsigned char
  15. #define uint unsigned int
  16. uchar table[]={"  temp:"};
  17. uchar table1[]={"warntemp: "};
  18. /********IO????**********/
  19. sbit rs=P0^7;
  20. sbit rw=P0^6;
  21. sbit en=P0^5;
  22. sbit dq=P3^7;
  23. sbit beep=P3^6;
  24. sbit led1=P1^0;
  25. sbit key1=P3^5;
  26. sbit key2=P3^4;
  27. sbit key3=P3^3;
  28. sbit key4=P3^2;
  29. uchar num;
  30. uint tempwarn,d=0,h=0;
  31. uint warntem=31;
  32. void delay(uint n)                //????
  33. {
  34.         while(n>0)n--;
  35. }
  36. void write_com(uchar com)  //???????
  37. {
  38.         rs=0;                        //?0????
  39.         en=0;                        //?????????
  40.         P2=com;                        //?com??,????????P2?
  41.         delay(100);                //??,???????????
  42.         en=1;                        //????,0?1??????????????????
  43.         delay(100);
  44.         en=0;                        //??????
  45. }
  46. void write_data(uchar date)           //???????
  47. {
  48.         rs=1;                  //?1??????
  49.         en=0;
  50.         P2=date;          //?date??,???????P2?
  51.         delay(100);
  52.         en=1;
  53.         delay(100);
  54.         en=0;
  55. }
  56. void init()        //???????
  57. {
  58.         en=0;
  59.         write_com(0x38);        //??16X2??,5X7??,8????
  60.         write_com(0x0c);        //?????,?????
  61.         write_com(0x06);        //???????????1
  62.         write_com(0x01);        //???0,?????0
  63. }
  64. void  Writebyte(uchar dat)//DS18B20??????????
  65. {
  66.         uchar j;
  67.         for(j=0;j<8;j++)
  68.         {
  69.                 dq=0;
  70.                 dq=dat&0x01;
  71.                 delay(5);
  72.                 dq=1;
  73.                 dat>>=1;
  74.         }
  75. }
  76. uchar Readbyte(void)//DS18B20?????????
  77. {
  78.         uchar i,dat=0;
  79.         for(i=0;i<8;i++)
  80.         {
  81.                 dq=0;
  82.                 dat>>=1;
  83.                 dq=1;
  84.                 if(dq==1)
  85.                 dat|=0x80;
  86.                 delay(4);
  87.         }
  88.         return dat;
  89. }
  90. void initds18b20(void)//?????????
  91. {
  92.         uchar x=0;
  93.         dq=1;
  94.         delay(8);
  95.         dq=0;
  96.         delay(80);
  97.         dq=1;
  98.         delay(14);
  99.         x=dq;
  100.         delay(20);
  101. }
  102. void Readtemp(void)//?????
  103. {
  104.         initds18b20();
  105.         Writebyte(0xcc);
  106.         Writebyte(0x44);
  107.         initds18b20();
  108.         Writebyte(0xcc);
  109.         Writebyte(0xbe);
  110.         d=Readbyte();        //??????8?????
  111.         h=Readbyte();        //??????8?????
  112. }
  113. convert() //????????,???????????????
  114. {
  115.         uint temp,tmp;
  116.         float tt,yy;
  117.         tmp=d;         //?8????tmp
  118.         temp=h;         //?8????temp
  119.         temp<<=8;  //?8???8?
  120.         temp|=d;   //??8?????????temp
  121.         if((h&0x80)!=0)         //?8?h&10000000???0,??0??????
  122.         {
  123.                 table[7]='-';        //?-????????8???,??-???8?,1602???16???
  124.                 temp=temp-1;
  125.                 temp=~temp;
  126.         }
  127.         else
  128.                 table[7]='+';
  129.                 temp>>=4;
  130.                 table[8]=(temp/100)+'0';        //???9??????????,??120??1
  131.                 table[9]=(temp/10)%10+'0';        //???10??????????,??120??2
  132.                 table[10]=(temp%10)+'0';        //???9??????????,??120??0
  133.                 tmp=tmp&0x0f;  //??????????
  134.                 tt=tmp*0.0625; //????????
  135.                 table[11]='.'; //?????
  136.                 table[12]=((uchar)(tt*10))%10+'0';//??????????
  137.
  138.          table[13]='.';
  139.          table[14]='C';
  140.         tempwarn=temp;
  141.
  142.         warntem>>=4;
  143.                 table1[8]=(warntem/100)+'0';        //???9??????????,??120??1
  144.                 table1[9]=(warntem/10)%10+'0';        //???10??????????,??120??2
  145.                 table1[10]=(warntem%10)+'0';        //???9??????????,??120??0
  146.                 warntem=warntem&0x0f;  //??????????
  147.                 yy=warntem*0.0625; //????????
  148.                 table1[11]='.'; //?????
  149.                 table1[12]=((uchar)(tt*10))%10+'0';//??????????
  150.
  151.          table1[13]='.';
  152.          table1[14]='C';
  153.
  154.
  155.         return tempwarn;//?????
  156. }
  157. void warn(uint tempwarn)//??????
  158. {
  159.         if(tempwarn<=warntem) //?????????,??????20????????????
  160.         {
  161.                 beep=0;
  162.                 delay(5000);//??????????
  163.                 beep=0;
  164.                 delay(50000); //???????????
  165.                 led1=1;
  166.         }
  167.         else if(tempwarn>warntem)//??????25???????
  168.         {
  169.                 beep=~beep;
  170.                 led1=0;
  171.                 //delay(300);
  172.                 //beep=1;
  173.                 //delay(300));
  174.         }
  175. }
  176. void main()
  177. {
  178.
  179.
  180.
  181.         rw=0;                  //rw???0,?????????,?????????????,??!!!
  182.         init();         //???????
  183.
  184.         /*
  185.                         if(key1==0)
  186.                 {
  187.                         delay(5);          //消抖動
  188.                         if(key1==0)          //確認按鍵被按下
  189.                         {
  190.                                 while(!key1);//松手檢測
  191.                                 warntem+=1;
  192.
  193.                         }
  194.                         if(key2==0)
  195.                 {
  196.                         delay(5);          //消抖動
  197.                         if(key2==0)          //確認按鍵被按下
  198.                         {
  199.                                 while(!key2);//松手檢測
  200.                                 warntem-=1;
  201.
  202.                         }
  203.                         */
  204.
  205.         //write_com(0x80+0x40); //0x80+0x40????????????
  206.         //for(num=0;num<15;num++)        //num<16,16????16?
  207.         //{
  208.         //        write_data(table1[num]);//?????????,?????????,??????dengtianming
  209.         //}
  210.         while(1)        //???,?????????
  211.         {
  212.                  Readtemp();
  213.                  convert();
  214.                  warn(tempwarn);
  215.                  write_com(0x80);  //??????????
  216.                  for(num=0;num<15;num++)//??16???,?????????????16,????????????????????
  217.                  {
  218.                         write_data(table[num]);//?????????
  219.                  }
  220.
  221.                  write_com(0x80+0x40); //0x80+0x40????????????
  222.         for(num=0;num<15;num++)        //num<16,16????16?
  223.         {
  224.                 write_data(table1[num]);//?????????,?????????,??????dengtianming
  225.         }
  226.
  227.
  228.          //table1[11]=warntem/10;
  229.          //table1[12]=warntem%10;
  230.                 // table1[13]='.';
  231.          //table1[14]='C';
  232.
  233.         }
  234. }
復制代碼
18B20程序.rar
32.3 KB, 下載次數(shù): 25, 下載積分: 黑幣 -5
admin + 50 共享資料的黑幣獎勵!
ID:136144 發(fā)表于 2016-8-6 21:00 | 顯示全部樓層
很多亂碼啊。
ID:136011 發(fā)表于 2016-8-6 22:33 | 顯示全部樓層
看看學習學習
ID:136902 發(fā)表于 2016-8-16 17:24 | 顯示全部樓層
名稱:18B20溫度傳感器測溫程序
  內容:18B20單線溫度檢測的應用樣例程序,請將18b20插緊,
        然后在數(shù)碼管可以顯示XX.XC,C表示攝氏度,如顯示25.3C表示當前溫度25.3度
#include<reg52.h>     //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
#include<math.h>
#include<INTRINS.H>
#define uint   unsigned int;
/*                    定義端口                                    */
sbit DQ=P1^3;//ds18b20 端口
sfr dataled=0x80;//顯示數(shù)據(jù)端口
/*                    全局變量                                    */
uint temp;
uchar flag_get,count,num,minute,second;
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
                                               //7段數(shù)碼管段碼表共陽
uchar  str[6];
/*                   函數(shù)聲明                                     */
void delay1(uchar MS);
unsigned int ReadTemperature(void);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void delay(unsigned int i);
/*                    主函數(shù)                                      */
main()
unsigned char TempH,TempL;
TMOD|=0x01;//定時器設置
TH0=0xef;
TL0=0xf0;
IE=0x82;
TR0=1;
P2=0x00;
count=0;
   str[5]=0x39;         //顯示C符號
   str[1]=tab[TempH/100]; //百位溫度
   str[2]=tab[(TempH%100)/10]; //十位溫度
   str[3]=tab[(TempH%100)%10]|0x80; //個位溫度,帶小數(shù)點
   str[4]=tab[TempL];
  if(flag_get==1)       //定時讀取當前溫度--定時器中斷一次,flag_get=1一次。
  temp=ReadTemperature();
  if(temp&0x8000)
     str[0]=0x40;//負號標志
     temp=~temp;  // 取反加1
  temp=temp+1;
     str[0]=0;
     TempH=temp>>4;
     TempL=temp&0x0F;
     TempL=TempL*6/10;//小數(shù)近似處理
     flag_get=0;
/*                  定時器中斷                                    */
void tim(void) interrupt 1 using 1//中斷,用于數(shù)碼管掃描和溫度檢測間隔
TH0=0xef;//定時器重裝值
TL0=0xf0;
num++;
if(num==20)
  {num=0;
flag_get=1;//標志位有效
    second++;
     if(second>=60)
        second=0;
        minute++;
count++;
if(count==1)
     P2=0;
     dataled=str[0];  //數(shù)碼管掃描
if(count==2)
   { P2=1;
     dataled=str[1];
if(count==3)
     P2=2;
     dataled=str[2];
if(count==4)
     P2=3;
     dataled=str[3];
if(count==5)
     P2=4;
     dataled=str[4];
if(count==6)
     P2=5;
     dataled=str[5];
     count=0;
/*                    延時函數(shù)                                    */
void delay(unsigned int i)//延時函數(shù)
while(i--);
/*                    初始化                                      */
unsigned char x=0;
DQ = 1;    //DQ復位
delay(8);  //稍做延時
DQ = 0;    //單片機將DQ拉低
delay(80); //精確延時 大于 480us
DQ = 1;    //拉高總線
delay(10);
x=DQ;      //稍做延時后 如果x=0則初始化成功 x=1則初始化失敗
delay(5);
/*                    讀一個字節(jié)                                  */
unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
  DQ = 0; // 給脈沖信號
  dat>>=1;
  DQ = 1; // 給脈沖信號
  if(DQ)
   dat|=0x80;
  delay(5);
return(dat);
/*                 寫一個字節(jié)                                     */
unsigned char i=0;
for (i=8; i>0; i--)
  DQ = 0;
  DQ = dat&0x01;
  delay(5);
  DQ = 1;
  dat>>=1;
delay(5);
/*                   讀取溫度                                     */
unsigned char a=0;
unsigned int b=0;
unsigned int t=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號列號的操作
WriteOneChar(0x44); // 啟動溫度轉換
delay(200);
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號列號的操作
WriteOneChar(0xBE); //讀取溫度寄存器等(共可讀9個寄存器) 前兩個就是溫度
a=ReadOneChar();   //低位
b=ReadOneChar();   //高位
b<<=8;
t=a+b;
return(t);
