查看: 16977|回復(fù): 10
Arduino學(xué)習(xí)3-Arduino連接HMC5883L三軸電子羅盤傳感器
用途:測(cè)量地磁方向,測(cè)量物體靜止時(shí)候的方向,測(cè)量傳感器周圍磁力線的方向。注意,測(cè)量地磁時(shí)候容易受到周圍磁場(chǎng)影響,
主芯片HMC5883三軸磁阻傳感器特點(diǎn)(抄自網(wǎng)上):
1,數(shù)字量輸出:I2C數(shù)字量輸出接口,設(shè)計(jì)使用非常方便。
2,尺寸小: 3x3x0.9mm LCC封裝,適合大規(guī)模量產(chǎn)使用。
3,精度高:1-2度,內(nèi)置12位A/D,OFFSET, SET/RESET 電路,不會(huì)出現(xiàn)磁飽和現(xiàn)象,不會(huì)有累加誤差。
4,支持自動(dòng)校準(zhǔn)程序,簡(jiǎn)化使用步驟,終端產(chǎn)品使用非常方便。
5,內(nèi)置自測(cè)試電路,方便量產(chǎn)測(cè)試,無(wú)需增加額外昂貴的測(cè)試設(shè)備。
6,功耗低:供電電壓1.8V, 功耗睡眠模式-2.5uA 測(cè)量模式-0.6mA
連接方法:
只要連接VCC,GND,SDA,SCL四條線。Arduino GND -> HMC5883L GNDArduino 3.3V -> HMC5883L VCCArduino A4 (SDA) -> HMC5883L SDAArduino A5 (SCL) -> HMC5883L SCL
(注意,接線是A4,A5,不是D4,D5)
程序編寫:下載HMC5883L庫(kù)文件。下載地址: HMC5883L.zip (5.55 KB, 下載次數(shù): 100) 主要程序預(yù)覽:
  1. /*
  2. HMC5883L.cpp - Class file for the HMC5883L Triple Axis Magnetometer Arduino Library.
  3. Copyright (C) 2011 Love Electronics (loveelectronics.co.uk)
  4. This program is free software: you can redistribute it and/or modify
  5. it under the terms of the version 3 GNU General Public License as
  6. published by the Free Software Foundation.
  7. This program is distributed in the hope that it will be useful,
  8. but WITHOUT ANY WARRANTY; without even the implied warranty of
  9. MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  10. GNU General Public License for more details.
  11. You should have received a copy of the GNU General Public License
  12. along with this program.  If not, see .
  13. WARNING: THE HMC5883L IS NOT IDENTICAL TO THE HMC5883!
  14. */
  15. #include
  16. #include "HMC5883L.h"
  17. HMC5883L::HMC5883L()
  18. {
  19.   m_Scale = 1;
  20. }
  21. MagnetometerRaw HMC5883L::ReadRawAxis()
  22. {
  23.   uint8_t* buffer = Read(DataRegisterBegin, 6);
  24.   MagnetometerRaw raw = MagnetometerRaw();
  25.   raw.XAxis = (buffer[0] << 8) | buffer[1];
  26.   raw.ZAxis = (buffer[2] << 8) | buffer[3];
  27.   raw.YAxis = (buffer[4] << 8) | buffer[5];
  28.   return raw;
  29. }
  30. MagnetometerScaled HMC5883L::ReadScaledAxis()
  31. {
  32.   MagnetometerRaw raw = ReadRawAxis();
  33.   MagnetometerScaled scaled = MagnetometerScaled();
  34.   scaled.XAxis = raw.XAxis * m_Scale;
  35.   scaled.ZAxis = raw.ZAxis * m_Scale;
  36.   scaled.YAxis = raw.YAxis * m_Scale;
  37.   return scaled;
  38. }
  39. int HMC5883L::SetScale(float gauss)
  40. {
  41.         uint8_t regValue = 0x00;
  42.         if(gauss == 0.88)
  43.         {
  44.                 regValue = 0x00;
  45.                 m_Scale = 0.73;
  46.         }
  47.         else if(gauss == 1.3)
  48.         {
  49.                 regValue = 0x01;
  50.                 m_Scale = 0.92;
  51.         }
  52.         else if(gauss == 1.9)
  53.         {
  54.                 regValue = 0x02;
  55.                 m_Scale = 1.22;
  56.         }
  57.         else if(gauss == 2.5)
  58.         {
  59.                 regValue = 0x03;
  60.                 m_Scale = 1.52;
  61.         }
  62.         else if(gauss == 4.0)
  63.         {
  64.                 regValue = 0x04;
  65.                 m_Scale = 2.27;
  66.         }
  67.         else if(gauss == 4.7)
  68.         {
  69.                 regValue = 0x05;
  70.                 m_Scale = 2.56;
  71.         }
  72.         else if(gauss == 5.6)
  73.         {
  74.                 regValue = 0x06;
  75.                 m_Scale = 3.03;
  76.         }
  77.         else if(gauss == 8.1)
  78.         {
  79.                 regValue = 0x07;
  80.                 m_Scale = 4.35;
  81.         }
  82.         else
  83.                 return ErrorCode_1_Num;
  84.
  85.         // Setting is in the top 3 bits of the register.
  86.         regValue = regValue << 5;
  87.         Write(ConfigurationRegisterB, regValue);
  88. }
  89. int HMC5883L::SetMeasurementMode(uint8_t mode)
  90. {
  91.         Write(ModeRegister, mode);
  92. }
  93. void HMC5883L::Write(int address, int data)
  94. {
  95.   Wire.beginTransmission(HMC5883L_Address);
  96.   Wire.send(address);
  97.   Wire.send(data);
  98.   Wire.endTransmission();
  99. }
  100. uint8_t* HMC5883L::Read(int address, int length)
  101. {
  102.   Wire.beginTransmission(HMC5883L_Address);
  103.   Wire.send(address);
  104.   Wire.endTransmission();
  105.
  106.   Wire.beginTransmission(HMC5883L_Address);
  107.   Wire.requestFrom(HMC5883L_Address, length);
  108.   uint8_t buffer[length];
  109.   if(Wire.available() == length)
  110.   {
  111.           for(uint8_t i = 0; i < length; i++)
  112.           {
  113.                   buffer[i] = Wire.receive();
  114.           }
  115.   }
  116.   Wire.endTransmission();
  117.   return buffer;
  118. }
  119. char* HMC5883L::GetErrorText(int errorCode)
  120. {
  121.         if(ErrorCode_1_Num == 1)
  122.                 return ErrorCode_1;
  123.
  124.         return "Error not defined.";
  125. }
解壓HMC5883L庫(kù)文件到arduino文件夾:arduino-0022libraries下面。編寫以下程序,下載下面測(cè)試程序到arduino:
#include <Wire.h>
#include <HMC5883L.h>
HMC5883L compass;
void setup()
  Serial.begin(9600);
  Wire.begin();
  compass = HMC5883L();
  compass.SetScale(1.3);
  compass.SetMeasurementMode(Measurement_Continuous);
void loop()
  MagnetometerRaw raw = compass.ReadRawAxis();
  MagnetometerScaled scaled = compass.ReadScaledAxis();
  float xHeading = atan2(scaled.YAxis, scaled.XAxis);
  float yHeading = atan2(scaled.ZAxis, scaled.XAxis);
  float zHeading = atan2(scaled.ZAxis, scaled.YAxis);
  if(xHeading < 0) xHeading += 2*PI;
  if(xHeading > 2*PI) xHeading -= 2*PI;
  if(yHeading < 0) yHeading += 2*PI;
  if(yHeading > 2*PI) yHeading -= 2*PI;
  if(zHeading < 0) zHeading += 2*PI;
  if(zHeading > 2*PI) zHeading -= 2*PI;
  float xDegrees = xHeading * 180/M_PI;
  float yDegrees = yHeading * 180/M_PI;
  float zDegrees = zHeading * 180/M_PI;
  Serial.print(xDegrees);
  Serial.print(",");
  Serial.print(yDegrees);
  Serial.print(",");
  Serial.print(zDegrees);
  Serial.println(";");
  delay(100);
打開(kāi)Arduino串口監(jiān)視器即可看到結(jié)果(X平面角度,Y平面角度,Z平面角度):
收藏收藏2 分享淘帖 頂 踩
相關(guān)帖子
ID:114115 發(fā)表于 2016-4-14 02:54 | 只看該作者
最近實(shí)在太忙,就先單獨(dú)把我的八字校準(zhǔn)程序貼上來(lái)。
其實(shí)很簡(jiǎn)單,我沒(méi)去管Z軸,如果想要更高的精度,需要加一個(gè)加速度傳感器,我剛好沒(méi)有。
我的整個(gè)校準(zhǔn)分2個(gè)子函數(shù):calibRead() 和 calibration()
參照官方HMC5883L的程序先把該定義的變量定義好。
  1.     HMC5883L digicomp;
  2.
  3.     float X_max = 0.0;  //X軸最大讀數(shù)
  4.     float X_min = 0.0;  //X軸最小讀數(shù)
  5.
  6.     float Y_max = 0.0;  //Y軸最大讀數(shù)
  7.     float Y_min = 0.0;  //Y軸最小讀數(shù)
  8.
  9.     float X_offset = 0.0;  //X軸偏移
  10.     float Y_offset = 0.0;  //Y軸偏移
  11.
  12.     void calibRead() //指南針讀數(shù)
  13.     {
  14.             MagnetometerScaled scaled2 = digicomp.ReadScaledAxis();
  15.
  16.             if (  (abs(scaled2.XAxis) < 500) && (abs(scaled2.YAxis) < 500) && (abs(scaled2.ZAxis) < 500)) //這行對(duì)于我很重要,能過(guò)濾掉很多干擾,增加校準(zhǔn)的精度。
  17.             {  //下面幾行就是讀取到每個(gè)軸的最大值和最小值,然后算出相應(yīng)的偏移量
  18.                 if(scaled2.XAxis > X_max) {X_max = scaled2.XAxis;}
  19.                 if(scaled2.YAxis > Y_max) {Y_max = scaled2.YAxis;}
  20.
  21.                 if(scaled2.XAxis < X_min) {X_min = scaled2.XAxis;}
  22.                 if(scaled2.YAxis < Y_min) {Y_min = scaled2.YAxis;}
  23.
  24.                 X_offset = (X_max + X_min) / 2.0;
  25.                 Y_offset = (Y_max + Y_min) / 2.0;
  26.             }
  27.     }
  28.
  29.     void calibration()
  30.     {
  31.             int i = 0;
  32.             digitalWrite(motor1EnPin, 0);  // 定義轉(zhuǎn)彎方向,對(duì)于我的小車來(lái)說(shuō)是左轉(zhuǎn),逆時(shí)針?lè)较?br />
  33.             digitalWrite(motor2EnPin, 1);
  34.
  35.             analogWrite(motor1, 80);  // 啟動(dòng)馬達(dá)開(kāi)始轉(zhuǎn)動(dòng)
  36.             analogWrite(motor2, 80);
  37.
  38.             while(i < 1000)  // 逆時(shí)針?lè)较蜓h(huán)讀取XY軸每個(gè)方向的值,然后算出相應(yīng)的偏移量
  39.             {  calibRead();
  40.                 delay(10);
  41.                 i++;
  42.             }
  43.
  44.             i = 0;
  45.             digitalWrite(motor1EnPin, 1);  // 右轉(zhuǎn)小車,順時(shí)針?lè)较?br />
  46.             digitalWrite(motor2EnPin, 0);
  47.
  48.             while(i < 1000)  // 再順時(shí)針?lè)较蚍较蛐D(zhuǎn)測(cè)算偏移量
  49.             {  calibRead();
  50.                 delay(10);
  51.                 i++;
  52.             }
  53.
  54.             analogWrite(motor1, 0);  // 停止小車,校準(zhǔn)完成
  55.             analogWrite(motor2, 0);
  56.     }
  57.
  58.     float readCompass()  //得到偏移了就可以讀數(shù)了
  59.     {
  60.             MagnetometerScaled scaled = digicomp.ReadScaledAxis();
  61.
  62.             float heading = atan2(scaled.YAxis - Y_offset, scaled.XAxis - X_offset);  // 讀數(shù)的時(shí)候直接減掉偏移量就可以了
  63.
  64.             //float declinationAngle = 36.36/1000.0;  [這幾行是考慮磁偏角的,除非真的是想
  65.             //heading = heading + declinationAngle;    找地理北極,不然對(duì)方向判斷用處不大]
  66.
  67.             if(heading < 0)  heading += 2*PI;
  68.             if(heading > 2*PI)  heading -= 2*PI;
  69.
  70.             float headingDegrees = heading * 180/M_PI;
  71.
  72.             return headingDegrees;
  73.     }
嚴(yán)格來(lái)說(shuō)這個(gè)傳感器讀出來(lái)的僅僅是三軸方向磁場(chǎng)強(qiáng)度而已,角度是算出來(lái)的。另外他對(duì)磁場(chǎng)感應(yīng)很靈敏,周圍有金屬就會(huì)有干擾,拿塊金屬在他周圍轉(zhuǎn)轉(zhuǎn)就能看到讀數(shù)很大的變化,所以校準(zhǔn)還是很有必要的。
手機(jī)的話因?yàn)楫?字能很快測(cè)得XY的偏移,所以方法就叫8字校準(zhǔn)。小車的話因?yàn)榭梢孕D(zhuǎn),就沒(méi)必要真的去走8字,直接轉(zhuǎn)圈就可以了。這是我的理解。
上傳一個(gè)HMC5883L庫(kù)文件,放在C:\Program Files (x86)\Arduino\libraries就可運(yùn)行,ARDUINO 1.0.6版本的三軸傳感器。代碼詳見(jiàn)1樓。
    HMC5883L新頭文件: HMC5883L.rar (5.14 KB, 下載次數(shù): 41)
ID:114115 發(fā)表于 2016-4-14 02:55 | 只看該作者
焊接還是很簡(jiǎn)單的,個(gè)人玩買個(gè)可調(diào)溫和恒溫的電烙鐵,最好60W的,升溫快,焊接前先將烙鐵頭附錫(其實(shí)一般新電烙鐵都需要先附錫,每次用完也要附錫防氧化),面板焊接點(diǎn)注意刷好助焊劑(可以用松香+酒精自己調(diào),酒精要純度高的工業(yè)酒精大概酒精和松香1:0.2就差不多了,然后刷到要焊接的引腳和PCB板上),最后直接焊錫絲點(diǎn)烙鐵頭刷引腳(不要擔(dān)心連線,先讓焊錫全部下到引腳上,最后拿烙鐵刷一邊,焊錫會(huì)自己焊接到點(diǎn),最好讓板子稍微傾斜,自上而下刷,這樣多余的錫會(huì)流到最下邊,然后拿烙鐵點(diǎn)掉就好了),最后用酒精棉擦洗焊點(diǎn)(將多余助焊劑洗掉),檢查焊點(diǎn)是否有連接,如果不確定用鑷子刮一刮就好了。(烙鐵使用要快點(diǎn)快提,這樣錫會(huì)自己成非常漂亮的形狀,不要長(zhǎng)時(shí)間點(diǎn)焊點(diǎn))
PCB板是不會(huì)附著焊錫的,所以不用擔(dān)心焊不好,其實(shí)很簡(jiǎn)單,關(guān)鍵烙鐵要好,個(gè)人用我覺(jué)得黃花907調(diào)溫恒溫烙鐵就好,淘寶上很便宜,反正我自己用的就很不錯(cuò)。。。。
最后,烙鐵頭要多買幾個(gè)不同樣式的,以應(yīng)對(duì)不同焊點(diǎn)。。
另,最近發(fā)現(xiàn)一個(gè)HMC5883的問(wèn)題,一并記這兒:最近買了幾片HMC5883L模塊,結(jié)果被坑了,賣家沒(méi)說(shuō)不能用在5V系統(tǒng),只說(shuō)能5V供電,以為在MEGA2560上能用,結(jié)果讀數(shù)據(jù)有問(wèn)題,一開(kāi)始是讀出來(lái)不更新,每次復(fù)位更新一次數(shù)據(jù),后來(lái)發(fā)現(xiàn)上拉電阻不是裝的PCB上印的4.7K,裝的是10K,換成4.7K后,可以連續(xù)讀數(shù)據(jù),但讀一斷時(shí)間后就會(huì)死機(jī),以為程序有問(wèn)題,查來(lái)查去,后來(lái)發(fā)現(xiàn)以前買的模塊能正常讀,仔細(xì)比較兩個(gè)模塊,發(fā)現(xiàn)新買的模塊沒(méi)有電平轉(zhuǎn)換電路,以HMC5883L的IIc的1.8V電平直接接5V系統(tǒng),不死才怪,所以5V系統(tǒng)買這個(gè)模塊一定要買GY-271型號(hào),有兩個(gè)小6腳芯片的,一個(gè)是LDO,一個(gè)是雙MOS做電平轉(zhuǎn)換,只有一個(gè)LDO的模塊只能用在3.3V或1.8V系統(tǒng)。
ID:148138 發(fā)表于 2016-11-15 21:32 | 只看該作者
5893也出來(lái)了
ID:165193 發(fā)表于 2017-2-18 00:07 | 只看該作者
回復(fù)有黑幣嗎
ID:24730 發(fā)表于 2017-3-2 16:50 | 只看該作者
51黑有你更精彩
ID:1 發(fā)表于 2017-3-2 17:06 | 只看該作者
回復(fù)是沒(méi)有的 只能通過(guò)發(fā)布文件 管理員審核通過(guò)后 才會(huì)發(fā)放
ID:230088 發(fā)表于 2017-8-31 16:24 | 只看該作者
回復(fù)有黑幣么?
ID:326549 發(fā)表于 2019-5-30 15:51 | 只看該作者
fatal error: ../Wire/Wire.h: No such file or directory #include "../Wire/Wir
請(qǐng)問(wèn)這是怎么回事
ID:514567 發(fā)表于 2019-6-7 12:00 | 只看該作者
很厲害
