查看: 4919|回復: 5
帶origin校正的精確度很高的頻率計仿真及源程序
ID:137190 發(fā)表于 2016-9-9 00:23 | 顯示全部樓層 |閱讀模式
帶origin校正的頻率計的仿真原理圖:
下面是數(shù)字頻率計的誤差分析:
誤差數(shù)據(jù):
高精度頻率計源程序:
  1. #include<reg52.h>
  2. #include<intrins.h>
  3. sbit RS=P2^6;
  4. sbit RW=P2^5;
  5. sbit E=P2^7;
  6. #define LCD_data  P0
  7. uchar   code  table1[10]={"f=      Hz"};
  8. uchar code f_table[88]={13,14,15,16,17,        18,        19,        20,        21,        22,        23,        24,        25,        26,        27,        28,        29,        30,        31,        32,        33,        34,        35,        36,        37,        38,        39,        40,        41,        42,        43,        44,        45,        46,        47,        48,        49,        50,        51,        52,        53,        54,        55,        56,        57,        58,        59,        60,        61,        62,        63,        64,        65,        66,        67,        68,        69,        70,        71,        72,        73,        74,        75,        76,        77,        78,        79,        80,        81,        82,        83,        84,        85,        86,        87,        88,        89,        90,        91,        92,        93,        94,        95,        96,        97,        98,        99,        100};
  9. uchar code f_correct[88]={9,10,        11,        12,        12,        12,        13,        14,        15,        16,        17,        18,        18,        18,        19,        20,        21,        21,        22,        23,        24,        25,        25,        26,        26,        27,        28,        29,        29,        30,        30,        31,        32,        33,        33,        34,        35,        35,        36,        37,        38,        38,        39,        40,        41,        41,        42,        42,        43,        44,        45,        45,        46,        47,        48,        49,        49,        50,        51,        51,        52,        53,        54,        54,        55,        55,        56,        57,        57,        58,        59,        60,        60,        62,        62,        63,        64,        64,        65,        66,        66,        67,        67,        68,        69,        70,        71,        71,};
  10. uchar a6,a5,a4,a3,a2,a1;
  11. uchar flag;
  12. unsigned long cnt;
  13. uchar f_cnt;
  14. /********************************/
  15. void delay_us(); //18us
  16. void delay_ms(uint);
  17. void lcd_init();
  18. void lcd_write_com(uchar com);
  19. void lcd_write_dat(uchar dat);
  20. void lcd_init();
  21. void lcd_display(uchar add,uchar dat);
  22. /***********************************/
  23. void delay_us()
  24. {
  25.         uchar x;
  26.         for(x=0;x<5;x++);
  27. }
  28. void delay_ms(uint z)
  29. {
  30.         uint x,y;
  31.         for(x=0;x<z;x++)
  32.                 for(y=0;y<123;y++);
  33. }
  34. void lcd_write_com(uchar com)
  35. {
  36.   E=0;
  37.   RS=0;
  38.   RW=0;
  39.   delay_us();
  40.   LCD_data=com;
  41.   E=1;           //高脈沖寫入數(shù)據(jù)
  42.   delay_us();
  43.   E=0;
  44. }
  45. void lcd_write_dat(uchar dat)
  46. {
  47.   E=0;
  48.   RS=1;
  49.   RW=0;
  50.   delay_us();
  51.   LCD_data=dat;
  52.   E=1;           //高脈沖寫入數(shù)據(jù)
  53.   delay_us();
  54.   E=0;
  55. }
  56. void lcd_init()                  //lcd初始化
  57. {
  58.         delay_ms(15);
  59.         lcd_write_com(0x38);
  60.         delay_ms(10);
  61.         lcd_write_com(0x0c);
  62.         lcd_write_com(0x06);
  63.         lcd_write_com(0x01);
  64.         delay_ms(2);
  65.
  66.
  67. }
  68. void timer_init(void)  //定時器初始化
  69. {
  70.                 TMOD=0X51;
  71.     PT0=1;     /*中斷優(yōu)先*/
  72.         TH0=0x3c;
  73.         TL0=0xb0;
  74.         TH1=0;
  75.         TL1=0;
  76.         ET0=1;
  77.         ET1=1;
  78.         TR0=1;
  79.         TR1=1;
  80.         EA=1;
  81. }
  82. void lcd_display(uchar add,uchar dat)           //lcd顯示(地址,數(shù)據(jù))
  83. {
  84.         lcd_write_com(add);
  85.
  86.         lcd_write_dat(dat);
  87.         delay_us();
  88. }
  89. void real_display(void)
  90. {
  91.         lcd_display(0x80,table1[0]);
  92.                         lcd_display(0x80+1,table1[1]);
  93.                         if(a6)
  94.                           lcd_display(0x80+2,0x30+a6);
  95.                         else
  96.                         lcd_display(0x80+2,' ');
  97.                         if(a6||a5)
  98.                         lcd_display(0x80+3,0x30+a5);
  99.                         else
  100.                                  lcd_display(0x80+3,' ');
  101.                         if(a6||a5||a4)
  102.                         lcd_display(0x80+4,0x30+a4);
  103.                         else
  104.                    lcd_display(0x80+4,' ');
  105.                         if(a6||a5||a4||a3)
  106.                         lcd_display(0x80+5,0x30+a3);
  107.                         else
  108.                     lcd_display(0x80+5,' ');
  109.                         if(a6||a5||a4||a3||a2)
  110.                         lcd_display(0x80+6,0x30+a2);
  111.                         else
  112.                         lcd_display(0x80+6,' ');
  113.
  114.                         lcd_display(0x80+7,0x30+a1);
  115.
  116.                         lcd_display(0x80+8,table1[8]);
  117.                         lcd_display(0x80+9,table1[9]);
  118. }
  119. void correct(void)                        //誤差修正函數(shù)
  120. {
  121.         uchar i,k;
  122.         unsigned long wucha;
  123.         if(cnt<100000)                   //100KHz以內(nèi)的修正
  124.         {
  125.                 if(cnt>980&&cnt<2100)     cnt-=1;
  126.                 if(cnt>=2100&&cnt<3900)   cnt-=2;
  127.                 if(cnt>=3900&&cnt<4800)   cnt-=3;
  128.                 if(cnt>=4800&&cnt<5700)   cnt-=4;
  129.                 if(cnt>=5700&&cnt<8000)   cnt-=5;
  130.                 if(cnt>=8000&&cnt<9100)          cnt-=6;
  131.                 if(cnt>=9100&&cnt<10900)  cnt-=7;
  132.                 if(cnt>=10900&&cnt<11900) cnt-=8;
  133.                 if(cnt>=11900&&cnt<13000) cnt-=9;
  134.                 if(cnt>=13000&&cnt<=100000)
  135.                 {
  136.                         k=cnt/1000;
  137.                         for(i=0;i<88;i++)
  138.                         {
  139.                                 if(k==f_table[i])
  140.                                 {
  141.                                         cnt-=f_correct[i];
  142.                                 }
  143.                         }
  144.                 }
  145.
  146.
  147.         }
  148.         if(cnt>100000)
  149.         {
  150.                 wucha=(cnt/1000)*73065/100000;
  151.                 cnt-=wucha;
  152.         }
  153. }
  154. void main()
  155. {
  156.     timer_init();
  157.         lcd_init();
  158.         while(1)
  159.         {
  160.                    if(flag==1)
  161.                    {
  162.                         real_display();
  163.                         flag=0;
  164.                         }
  165.
  166.
  167.         }
  168.
  169. }
  170. void timer0() interrupt 1
  171. {
  172.         uchar timer0;
  173.
  174.         TH0=0x3c;          //50ms
  175.         TL0=0xb0;
  176.         timer0++;
  177.         if(timer0==20)
  178.         {
  179.                 TR1=0;          //關閉的計數(shù)器
  180.                 EA=0;
  181.                 cnt=TL1+TH1*256+f_cnt*65536;
  182.                 correct();
  183.                 timer0=0;
  184.
  185.                 a6=cnt%10000000/100000;
  186.                 a5=cnt%100000/10000;
  187.                 a4=cnt%10000/1000;
  188.                 a3=cnt%1000/100;
  189.                 a2=cnt%100/10;
  190.                 a1=cnt%10;
  191.                 flag=1;
  192.              TH1=0;
  193.                 TL1=0;
  194.                 TH0=0x3c;
  195.              TL0=0xb0;
  196.                 cnt=0;
  197.                 f_cnt=0;
  198.                 EA=1;
  199.                 TR1=1;           //打開計數(shù)器
  200.
  201.
  202.         }
  203.
  204. }
  205. void int1() interrupt 3
  206. {
  207.          f_cnt++;
  208. }
復制代碼
下載:
頻率計.zip (878.8 KB, 下載次數(shù): 27)
ID:150693 發(fā)表于 2017-4-6 11:54 | 顯示全部樓層
謝謝樓主的分享,51黑有你更精彩
ID:194701 發(fā)表于 2017-5-1 09:03 | 顯示全部樓層
謝謝樓主的分享
ID:345426 發(fā)表于 2019-6-15 13:00 | 顯示全部樓層
謝謝樓主的分享
ID:150257 發(fā)表于 2019-6-15 20:09 | 顯示全部樓層
感謝大佬分享
ID:573825 發(fā)表于 2019-6-28 01:23 | 顯示全部樓層
謝謝謝謝
