16X16點陣動態(tài)顯示32個字,文字內容可以增加,修改,可以用論壇里面的字模提取軟件,修改其他文字,顯示效果:卷簾出,卷簾入,上滾屏,左跑馬。大家一起學習,進步!
原理圖:
單片機源程序:
- 16×16點陣LED顯示屏程序
- MCU AT89C51 XAL 24MHz 12MHZ/晶振頻率不同、刷新率也不同、供參考。
- #include <reg51.h>
- #define BLKN 2 //列鎖存器數(shù)
- sbit G = 0x97; //P1.7為顯示允許控制信號端口
- sbit RCLK = 0x96; //P1.6為輸出鎖存器時鐘信號端
- sbit SCLR = 0x95; //P1.5為移位寄存器清○端
- void delay(unsigned int); //延時函數(shù)
- unsigned char data dispram[32]; //顯示緩存
- 主函數(shù) void main(void)
- void main(void)
- unsigned char code Bmp[][32]={//字模表
- {0xFF,0xFF,0x80,0x01,0xFD,0xFF,0xFD,0xFF,0xFD,0xEF,0xFC,0x07,0xFD,0xEF,0xFB,0xEF,
- 0xFB,0xEF,0xFB,0xEF,0xF7,0xEF,0xF7,0xEF,0xEF,0xEF,0xDF,0x1F,0xBF,0xBF,0xFF,0xFF},/*"W",0*/
- {0xFF,0xBF,0x07,0xAF,0xF7,0x77,0xB6,0x03,0xB7,0xFB,0xB7,0x77,0xB6,0xFB,0x83,0x7F,
- 0xFB,0x03,0xEA,0x77,0xD9,0xAF,0x3B,0xDF,0xFB,0xAF,0xD6,0x71,0xE9,0xFB,0xFF,0xFF},/*"J",1*/
- {0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xC0,0x07,0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,
- 0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,0xFE,0xFD,0xFE,0xFD,0xFF,0x01,0xFF,0xFF},/*"?",2*/
- {0xFF,0xFF,0xC0,0x0F,0xFF,0xDF,0xFF,0xBF,0xFF,0x7F,0xFE,0xFF,0xFE,0xFF,0xFE,0xFB,
- 0x00,0x01,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFA,0xFF,0xFD,0xFF},/*"?",3*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
- 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0xCF,0xFF,0xEF,0xFF,0xDF,0xFF,0xFF,0xFF},/*",",4*/
- {0xEF,0xBF,0xEB,0xAF,0xDD,0x87,0x80,0xBB,0xBE,0xBB,0xC1,0xC3,0xDD,0xFF,0xC1,0xB3,
- 0xDD,0x8F,0xC1,0xBB,0xDD,0xBB,0xD9,0xC3,0xD7,0x77,0xDB,0xBB,0xBB,0xBF,0xFF,0xFF},/*"?",5*/
- {0xDF,0xBF,0xEF,0xBF,0xEF,0xBF,0xF8,0x01,0x7B,0xBB,0xAB,0xBF,0xAB,0xBF,0xE8,0x07,
- 0xDA,0xF7,0xDB,0x6F,0x1B,0x6F,0xDB,0x9F,0xD7,0x9F,0xD7,0x68,0xCE,0xF1,0xD9,0xFB},/*"?",6*/
- {0xDB,0xFB,0xCB,0xFB,0xDB,0xDB,0xC0,0x5B,0xBB,0xDB,0xFB,0xDB,0x80,0x5B,0xFB,0xDB,
- 0xC0,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x7B,0xD8,0x7B,0xFA,0xEB,0xFB,0xF7},/*"制",7*/
- {0xF7,0x7F,0xF3,0x7F,0xF6,0xFF,0xEC,0x01,0xED,0x7F,0xCB,0x77,0xAF,0x03,0x6F,0x7F,
- 0xEF,0x7F,0xEF,0x7B,0xEF,0x01,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F},/*"作",8*/
- {0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0xF8,0x0F,0xE6,0x47,0xE6,0x47,0xE0,0x7F,0xF0,0x7F,
- 0xFC,0x1F,0xFE,0x07,0xE6,0x67,0xC2,0x63,0xE6,0x67,0xF0,0x1F,0xFE,0x7F,0xFF,0x7F},/*",",9*/
- {0xFF,0x7F,0xFF,0x7F,0x03,0x7F,0xFA,0x01,0x7A,0xFB,0xB5,0xB7,0xD7,0xBF,0xEF,0xBF,
- 0xE7,0xBF,0xE7,0x9F,0xDB,0x5F,0xDB,0x6F,0xBE,0xE7,0x79,0xF1,0xC7,0xFB,0xFF,0xFF},/*"歡",10*/
- {0xBF,0xFF,0xDE,0x7F,0xC9,0x83,0xDB,0xBB,0xFB,0xBB,0xFB,0xBB,0x1B,0xBB,0xDB,0xBB,
- 0xDA,0xBB,0xD9,0xAB,0xDB,0xB7,0xDF,0xBF,0xDF,0xBF,0xAF,0xFF,0x70,0x01,0xFF,0xFF},/*"迎",11*/
- {0xFF,0xFF,0xFE,0x03,0x82,0xFB,0xFA,0xDB,0xBA,0xDB,0xBA,0xDB,0xD6,0xDB,0xEE,0xDB,
- 0xD6,0xDB,0xDA,0xAB,0xB9,0xAF,0xBB,0x6F,0x7F,0x6D,0xFE,0xED,0xFD,0xF1,0xFB,0xFF},/*"觀",12*/
- {0xFF,0x07,0xC0,0xFF,0xFE,0xFF,0xC0,0x07,0xFD,0xFF,0x00,0x01,0xFB,0xFF,0xF0,0x0F,
- 0xE7,0xEF,0x90,0x0F,0x77,0xEF,0xF0,0x0F,0xF7,0xEF,0xF7,0xEF,0xF0,0x0F,0xF7,0xEF},/*"看",13*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xD9,0x9B,0xB9,0x9D,0xBF,0xFD,
- 0xBF,0xFD,0xBE,0x7D,0xBC,0x3D,0xDE,0x7B,0xEF,0xF7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*",",14*/
- {0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
- 0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"謝",15*/
- 0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"謝",16*/
- {0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFC,0x3F,0xFC,0x3F,0xFC,0x7F,0xFE,0x7F,0xFE,0x7F,
- 0xFE,0x7F,0xFE,0x7F,0xFF,0xFF,0xFF,0xFF,0xFC,0x3F,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF},/*"!",17*/
- {0xFE,0xFF,0xFE,0xFF,0xFD,0x7F,0xFD,0x7F,0xFD,0x7F,0xFB,0xBF,0x03,0x81,0xBF,0xFB,
- 0xCF,0xE7,0xF7,0xDF,0xF7,0xDF,0xEE,0x6F,0xE9,0xAF,0xE7,0xCF,0xDF,0xF7,0xFF,0xFF},/*"☆",18*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xF3,0x8F,0xF1,0x8F,0xF1,
- 0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7}, /*Q*/
- 0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7} , /*Q*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,
- 0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*4*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xE3,0xC7,0xE3,0xFF,0xC7,
- 0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF},/*2*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0F,0xE3,0xC7,0xC7,0xE3,0xC7,0xE3,0x87,0xE1,
- 0x87,0xE1,0xC7,0xE3,0xC7,0xE3,0xC7,0xE3,0xE3,0xC7,0xF8,0x1F,0xFF,0xFF,0xFF,0xFF},/*0*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xC7,0xE7,0xCF,0xE3,0x8F,0xE3,0x8F,0xE3,
- 0xC7,0xC3,0xE0,0x23,0xFF,0xE3,0xE7,0xC7,0xC3,0x8F,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF}, /*9*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,0xC7,0xF3,0xCF,0xEF,0xFF,0xCF,0xFF,0x9F,
- 0xFF,0x3F,0xFE,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFF,0xFF,0xFF,0xFF},/*7*/
- 0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF}, /*?*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x03,0xE7,0xFF,0xE7,0xFF,0xE7,0x3F,0xE0,0x07,
- 0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*8*/
- {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,
- 0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*?*/
- 0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF}, /*5*/
- {0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xDF,0xFB,0xBF,0xFD,0x63,0xC6,0x63,0xC6,
- 0x7F,0xFE,0x7E,0x7E,0x7E,0x7E,0x7B,0xDE,0xBC,0x3D,0xDF,0xFB,0xE0,0x07,0xFF,0xFF}
復制代碼
下載:
16X16點陣 原理圖.zip
(120.72 KB, 下載次數(shù): 31)
2017-4-21 21:36 上傳
點擊文件名下載附件
