#include <reg52.h>
#include <intrins.h>
typedef unsigned char uchar;
typedef unsigned char uint;
//****************************************NRF24L01端口定義***************************************
sbit MISO =P1^3;
sbit MOSI =P1^4;
sbit SCK =P1^2;
sbit CE =P1^1;
sbit CSN =P3^2;
sbit IRQ =P3^3;
//************************************按鍵***************************************************
sbit KEY1=P3^6;
sbit KEY2=P3^7;
//************************************數(shù)碼管位選*********************************************
sbit led3=P2^0;
sbit led2=P2^1;
sbit led1=P2^2;
sbit led0=P2^3;
//************************************蜂明器***************************************************
sbit BELL=P3^4;
//***********************************數(shù)碼管0-9編碼*******************************************
uchar seg[10]={0xC0,0xCF,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90}; //0~~9段碼
//*********************************************NRF24L01*************************************
#define TX_ADR_WIDTH 5
#define RX_ADR_WIDTH 5
#define TX_PLOAD_WIDTH 32
#define RX_PLOAD_WIDTH 32
uint const TX_ADDRESS[TX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //本地地址
uint const RX_ADDRESS[RX_ADR_WIDTH]= {0x34,0x43,0x10,0x10,0x01}; //接收地址
unsigned char tf =0;
unsigned char TxBuf[33]={0}; //
unsigned char RxBuf[33]={0};
//***************************************NRF24L01寄存器指令*******************************************************
#define READ_REG 0x00 // 讀寄存器指令
#define WRITE_REG 0x20 // 寫(xiě)寄存器指令
#define RD_RX_PLOAD 0x61 // 讀取接收數(shù)據(jù)指令
#define WR_TX_PLOAD 0xA0 // 寫(xiě)待發(fā)數(shù)據(jù)指令
#define FLUSH_TX 0xE1 // 沖洗發(fā)送 FIFO指令
#define FLUSH_RX 0xE2 // 沖洗接收 FIFO指令
#define REUSE_TX_PL 0xE3 // 定義重復(fù)裝載數(shù)據(jù)指令
#define NOP 0xFF // 保留
//*************************************SPI(nRF24L01)寄存器地址****************************************************
#define CONFIG 0x00 // 配置收發(fā)狀態(tài),CRC校驗(yàn)?zāi)J揭约笆瞻l(fā)狀態(tài)響應(yīng)方式
#define EN_AA 0x01 // 自動(dòng)應(yīng)答功能設(shè)置
#define EN_RXADDR 0x02 // 可用信道設(shè)置
#define SETUP_AW 0x03 // 收發(fā)地址寬度設(shè)置
#define SETUP_RETR 0x04 // 自動(dòng)重發(fā)功能設(shè)置
#define RF_CH 0x05 // 工作頻率設(shè)置
#define RF_SETUP 0x06 // 發(fā)射速率、功耗功能設(shè)置
#define STATUS 0x07 // 狀態(tài)寄存器
#define OBSERVE_TX 0x08 // 發(fā)送監(jiān)測(cè)功能
#define CD 0x09 // 地址檢測(cè)
#define RX_ADDR_P0 0x0A // 頻道0接收數(shù)據(jù)地址
#define RX_ADDR_P1 0x0B // 頻道1接收數(shù)據(jù)地址
#define RX_ADDR_P2 0x0C // 頻道2接收數(shù)據(jù)地址
#define RX_ADDR_P3 0x0D // 頻道3接收數(shù)據(jù)地址
#define RX_ADDR_P4 0x0E // 頻道4接收數(shù)據(jù)地址
#define RX_ADDR_P5 0x0F // 頻道5接收數(shù)據(jù)地址
#define TX_ADDR 0x10 // 發(fā)送地址寄存器
#define RX_PW_P0 0x11 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P1 0x12 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P2 0x13 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P3 0x14 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P4 0x15 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define RX_PW_P5 0x16 // 接收頻道0接收數(shù)據(jù)長(zhǎng)度
#define FIFO_STATUS 0x17 // FIFO棧入棧出狀態(tài)寄存器設(shè)置
void Delay(unsigned int s);
void inerDelay_us(unsigned char n);
void init_NRF24L01(void);
uint SPI_RW(uint uchar);
uchar SPI_Read(uchar reg);
void SetRX_Mode(void);
uint SPI_RW_Reg(uchar reg, uchar value);
uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars);
uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars);
unsigned char nRF24L01_RxPacket(unsigned char* rx_buf);
void nRF24L01_TxPacket(unsigned char * tx_buf);
//*****************************************長(zhǎng)延時(shí)*****************************************
unsigned int i;
for(i=0; i<s; i++);
for(i=0; i<s; i++);
uint bdata sta; //狀態(tài)標(biāo)志
sbit RX_DR =sta^6;
sbit TX_DS =sta^5;
sbit MAX_RT =sta^4;
/*延時(shí)函數(shù)
for(;n>0;n--)
_nop_();
static void Delay1(int n)
int i;
while(n--)
for(i=0;i<80;i++);
/*NRF24L01初始化
inerDelay_us(100);
CE=0; // chip enable
CSN=1; // Spi disable
SCK=0; //
SPI_Write_Buf(WRITE_REG + TX_ADDR, TX_ADDRESS, TX_ADR_WIDTH); // 寫(xiě)本地地址
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, RX_ADDRESS, RX_ADR_WIDTH); // 寫(xiě)接收端地址
SPI_RW_Reg(WRITE_REG + EN_AA, 0x01); // 頻道0自動(dòng) ACK應(yīng)答允許
SPI_RW_Reg(WRITE_REG + EN_RXADDR, 0x01); // 允許接收地址只有頻道0
SPI_RW_Reg(WRITE_REG + RF_CH, 40); // 設(shè)置信道工作為2.4GHZ,收發(fā)必須一致 、、 0
SPI_RW_Reg(WRITE_REG + RX_PW_P0, RX_PLOAD_WIDTH); //設(shè)置接收數(shù)據(jù)長(zhǎng)度,本次設(shè)置為32字節(jié) 、、0
SPI_RW_Reg(WRITE_REG + RF_SETUP, 0x0f); //設(shè)置發(fā)射速率為1MHZ,發(fā)射功率為最大值0dB 、、07
/*函數(shù):uint SPI_RW(uint uchar)
/*功能:NRF24L01的SPI寫(xiě)時(shí)序
uint bit_ctr;
for(bit_ctr=0;bit_ctr<8;bit_ctr++)
MOSI = (uchar & 0x80);
uchar = (uchar << 1);
SCK = 1;
uchar |= MISO;
SCK = 0;
return(uchar);
/*函數(shù):uchar SPI_Read(uchar reg)
/*功能:NRF24L01的SPI時(shí)序
uchar reg_val;
CSN = 0;
SPI_RW(reg);
reg_val = SPI_RW(0);
CSN = 1;
return(reg_val);
/*功能:NRF24L01讀寫(xiě)寄存器函數(shù)
uint status;
CSN = 0;
status = SPI_RW(reg);
SPI_RW(value);
CSN = 1;
return(status);
/*函數(shù):uint SPI_Read_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于讀數(shù)據(jù),reg:為寄存器地址,pBuf:為待讀出數(shù)據(jù)地址,uchars:讀出數(shù)據(jù)的個(gè)數(shù)
uint status,uchar_ctr;
CSN = 0;
for(uchar_ctr=0;uchar_ctr<uchars;uchar_ctr++)
pBuf[uchar_ctr] = SPI_RW(0);
CSN = 1;
return(status);
/*函數(shù):uint SPI_Write_Buf(uchar reg, uchar *pBuf, uchar uchars)
/*功能: 用于寫(xiě)數(shù)據(jù):為寄存器地址,pBuf:為待寫(xiě)入數(shù)據(jù)地址,uchars:寫(xiě)入數(shù)據(jù)的個(gè)數(shù)
CSN = 0; //SPI使能
for(uchar_ctr=0; uchar_ctr<uchars; uchar_ctr++) //
SPI_RW(*pBuf++);
CSN = 1; //關(guān)閉SPI
return(status); //
/*函數(shù):void SetRX_Mode(void)
/*功能:數(shù)據(jù)接收配置
CE=0;
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0f); // IRQ收發(fā)完成中斷響應(yīng),16位CRC ,主接收
CE = 1;
inerDelay_us(130);
/*函數(shù):unsigned char nRF24L01_RxPacket(unsigned char* rx_buf)
/*功能:數(shù)據(jù)讀取后放如rx_buf接收緩沖區(qū)中
unsigned char revale=0;
sta=SPI_Read(STATUS); // 讀取狀態(tài)寄存其來(lái)判斷數(shù)據(jù)接收狀況
if(RX_DR) // 判斷是否接收到數(shù)據(jù)
CE = 0; //SPI使能
SPI_Read_Buf(RD_RX_PLOAD,rx_buf,TX_PLOAD_WIDTH);
revale =1; //讀取數(shù)據(jù)完成標(biāo)志
if( RxBuf[1]==1)
RxBuf[1] = 0x00; TxBuf[1] = 2 ; tf = 1 ;
if( RxBuf[1]==2)
tf=0;//TxBuf[1] = 2 ; tf = 1 ;
RxBuf[1]=0;
SPI_RW_Reg(WRITE_REG+STATUS,sta); //接收到數(shù)據(jù)后RX_DR,TX_DS,MAX_PT都置高為1,通過(guò)寫(xiě)1來(lái)清楚中斷標(biāo)志
return revale;
/*函數(shù):void nRF24L01_TxPacket(unsigned char * tx_buf)
/*功能:發(fā)送 tx_buf中數(shù)據(jù)
CE=0; //StandBy I模式
SPI_Write_Buf(WRITE_REG + RX_ADDR_P0, TX_ADDRESS, TX_ADR_WIDTH); // 裝載接收端地址
SPI_Write_Buf(WR_TX_PLOAD, tx_buf, TX_PLOAD_WIDTH); // 裝載數(shù)據(jù)
SPI_RW_Reg(WRITE_REG + CONFIG, 0x0e); // IRQ收發(fā)完成中斷響應(yīng),16位CRC,主發(fā)送
CE=1; //置高CE,激發(fā)數(shù)據(jù)發(fā)送
inerDelay_us(10);
//************************************主函數(shù)************************************************************
void main(void)
uint i;
init_NRF24L01() ;
led0=0;led1=1;led2=1;led3=1;
P0=0x00;
for(i=0;i<32;i++) TxBuf[i]=i;
TxBuf[32]=0;
nRF24L01_TxPacket(TxBuf); // Transmit Tx buffer data
Delay(6000);
P0=0xBF;
KEY1=0; //強(qiáng)制為發(fā)送模式
SetRX_Mode();
nRF24L01_RxPacket(RxBuf);
if(KEY1 ==0 ) //進(jìn)入發(fā)送模式
TxBuf[1] = 1 ; tf = 1 ; P0=seg[(TxBuf[1])];
inerDelay_us(20);
if (tf==1)
SPI_RW_Reg(WRITE_REG+STATUS,0XFF);
TxBuf[1] = 0x00; //TxBuf[2] = 0x00;
tf=0;
inerDelay_us(200);
