查看: 3777|回復: 0
HT01引腳圖等資料下載 空氣五合一傳感器CO2 VOC溫濕度甲醛
ID:204415 發(fā)表于 2017-5-24 18:45 | 顯示全部樓層 |閱讀模式
一個經(jīng)典的傳感器,空氣五合一CO2 VOC溫濕度甲醛傳感器,他都能檢測.
VOCs Detectors Module
Model:HT01
HT01引腳圖:
Key Benefits
Ultra-low power consumption
Wide VOCs detection range
Direct correlation to equivalent CO2 levels
Direct correlation to equivalent HCHO levels
High sensitivity
Fast response & recovery times
High resistance to shocks and vibrations
Precise temperature and humidity sensing
Parameters:
Power Input: 2.5~5.5 VDC
Operating current: Max 200mA
Operating temperature:-5~50℃  Work humidity: 0-99%RH (no coagulation)
Preheating time:<=1 min
Interface: I2C
Sensor type: Semiconductor
Sampling way: Diffusion
Equipment service life: 5 years ( in the air ) Warranty does not include sensor3
HT01 pdf資料下載地址:
HT01-空氣五合一產(chǎn)品規(guī)格V2.0.pdf (1.22 MB, 下載次數(shù): 8)
admin + 50 共享資料的黑幣獎勵!
相關帖子
