專注電子技術(shù)學習與研究
當前位置:單片機教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
電子測速里程防盜報警器設(shè)計(2)
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2010年09月12日   【字體:
//標題:4乘4鍵盤的輸入函數(shù)
//  函數(shù)描述:   char gotkey(void)
//             從4*4小鍵盤輸入數(shù)據(jù),返回0~9,及其它數(shù)據(jù).
//時間遲延函數(shù)
void delay (void)
  unsigned char i,j;
  for(i=0;i<5;i++)
    for(j=0;j<255;j++);
//檢查是否有按鍵按下
char keypad_scan()
  char key,i;
  p2=0xF0;
  while(p2!=0XF0);
    do{
        for(i=0;i<=3;i++)
         {  p2=ksp;
           if(p2!=ksp)
             delay();
             key=p2;
             if(key!=ksp)
               return(key);
       }while(1);
//取得鍵值
char gotkey()
  char temp,i;
  temp=keypad_scan();
  for(i=0;i<=15;i++)
     if(temp==key_code)
      return(i);
//93c66驅(qū)動程序
unsigned char read_byte(int address)
{int i, command;
unsigned char temp;
CS=1;
command=(READ|address);
write_command(command);
for(i=0;i<8;i++)
  {SK=1;
   SK=0;
   temp=(temp<<1);
   if(DO==1)
     temp=(temp|0X01);
CS=0;
return(temp);
void write_enable()
{int command;
CS=1;
command=EWEN;
CS=0;
void write_disable()
{int command;
CS=1;
command=EWDS
CS=0;
void write_byte(int address,unsigned char write_date)
{int i,command;
write_enable();
CS=1;
command=(WRITE|address);
for(i=0;i<8;i++)
  {if(write_date&0X80)}
     DI=1;
   elae
     DI=0;
   SK=1;
   SK=0;
   write_date=(write_data<<1);
check_busy();
write_disable();
void write_command(int command)
{int i;
command=(command<<shiftbit);
for(i=0;i<12;i++)
  {if(command&0X8000)
    DI=1;
    DI=0;
   SK=1;
   SK=0;
   command=(command<<1);
void check_busy(void)
{CS=0;
CS=1;
while(DO==0);
//標題:ISD4004驅(qū)動法程序
//功能:語音選段播放
void delay(unsigned int time) //延遲n微秒
while(time!=0)
time-- ;
void delayms(unsigned int time) //延遲n毫秒
{ TMOD=0x01;
for(time;time>0;time--)
TH0=0xfc;
TL0=0x18;
TR0=1;
while(TF0!=1)
TF0=0;
TR0=0;
//ISD4004 spi串行發(fā)送子程序,16位數(shù)據(jù)
void spi_send(unsigned char isdx)
{ unsigned char isx_counter;
SS=0; //ss=0,打開spi通信端
SCLK=0;
for(isx_counter=0;isx_counter<8;isx_counter++)
//先發(fā)低位再發(fā)高位,依次發(fā)送。
{ if ((isdx&0x01)==1)
MOSI=1;
MOSI=0;
isdx=isdx>>1;
SCLK=1;
delay(2);
SCLK=0;
delay(2);
//發(fā)送stop指令
void isd_stop(void)
{ delay(10);
spi_send(0x30);
SS=1;
delayms(50);
//發(fā)送上電指令,并延遲50ms
void isd_pu(void)
{ delay(10);
SS=0;
spi_send(0x20);
SS=1;
delayms(50);
//發(fā)送掉電指令,并延遲50ms
void isd_pd(void)
{ delay(10);
spi_send(0x10);
SS=1;
delayms(50);
//發(fā)送分段語音setplay指令
void isd_setplay(unsigned char adl,unsigned char adh)
isd_pd();
delayms(1);
spi_send(adl);
delay(2);
spi_send(adh);
delay(2);
spi_send(0xe0);
SS=1;
spi_send(0xf0);
SS=1;
if(ISD_INT==0)
isd_stop();
isd_pd();
