當(dāng)前位置:單片機(jī)教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
ST7920控制芯片的帶字庫12864液晶驅(qū)動程序
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2010年09月14日   【字體:
/***測試OK,我的是12864-15型引腳。并口驅(qū)動****/-
#include "reg52.h"-
#include <intrins.h>-
#define LCD12864_IOP0-
#define LINE10-
#define LINE21-
#define HIGH1-
#define LOW 0-
#defineCLERADISPLAYLCD12864_command(0x01);-
code unsigned char gImage_test[1024] = {
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04}  ;
sbit LCD12864_EN=P2^7;
sbit LCD12864_DIN=P2^6;
sbit LCD12864_CLK=P2^5;
void LCD12864_busy(void);-
void LCD12864_command(unsigned char command);-
void LCD12864_data(unsigned char dat);-
void LCD12864_address(unsigned char row,unsigned char line);-
void LCD12864_char(unsigned char dat);-
void LCD12864_string(unsigned char row,unsigned char line,unsigned char *s);-
void LCD12864_picture(unsigned char *gImage);-
void LCD12864_init(void);-
void Mcu_init(void)-
LCD12864_init();-
CLERADISPLAY  -
CLERADISPLAY  -
LCD12864_init();-
void Delay(void)-
unsigned char i;-
    unsigned int j;-
for(i=0;i<200;i++)-
for(j=1000;j>0;j--);-
void main(void)-
Mcu_init();-
LCD12864_picture((unsigned char*)gImage_test); -
Delay();Delay();-
CLERADISPLAY  -
while(1)-
LCD12864_string(1,1," LCD12864-15  "); -
LCD12864_string(1,2,"中文顯示測試實驗"); -
LCD12864_string(1,3," 少占魚  ");-
LCD12864_string(1,4,"    2010-1-26  ");-
void LCD12864_DELAY(unsigned int a)-
for(;a>0;a--) -
_nop_();-
void LCD12864_busy(void)-
    bit BF = 0;-
    LCD12864_EN=0; -
    LCD12864_DIN=0;-
    LCD12864_CLK=1;-
    LCD12864_IO=0xff;//單片機(jī)讀數(shù)據(jù)之前必須先置高位-
    do-
    LCD12864_EN=1;-
        BF=LCD12864_IO&0x80;-
        LCD12864_EN=0;-
    } while(BF);-
//          寫入命令-
void LCD12864_command(unsigned char command)-
    LCD12864_busy();-
    LCD12864_EN=0;-
    LCD12864_DIN=0;-
    LCD12864_CLK=0;  -
    LCD12864_EN=1;-
    LCD12864_IO=command;-
    LCD12864_EN=0;-
//          寫入一字節(jié)數(shù)據(jù)-
void LCD12864_data(unsigned char dat)-
    LCD12864_busy();-
    LCD12864_EN=0;-
    LCD12864_DIN=1;-
    LCD12864_CLK=0;-
    LCD12864_EN=1;-
    LCD12864_IO=dat;-
    LCD12864_EN=0;-
-//讀數(shù)據(jù)函數(shù)
unsigned char LCD12864_ReadData()
  unsigned char read_data;
   LCD12864_busy();
    LCD12864_IO=0xff;
 LCD12864_RS=1;
 LCD12864_RW=1;
 LCD12864_EN=0;
 LCD12864_EN=1;
 read_data=LCD12864_IO;
    LCD12864_EN=0;
 return(read_data);
void LCD12864_char(unsigned char dat)-
if((dat>=0)&&(dat<=9))-
    dat|=0x30;-
    LCD12864_data(dat);-
//          設(shè)置顯示位置    X(1~8),Y(1~4)-
void LCD12864_address(unsigned char line,unsigned char row)-
    switch(row) -
        case 1:LCD12864_command(0x7f + line);-
        break;-
        case 2:LCD12864_command(0x8f + line);-
        break;-
        case 3:LCD12864_command(0x87 + line);-
        break;-
        case 4:LCD12864_command(0x97 + line);-
        default:-
        break;-
//          在指定位置顯示字符串-
void LCD12864_string(unsigned char row,unsigned char line,unsigned char *s)-
    unsigned char LCD12864_temp; -
    LCD12864_address(row,line); -
    LCD12864_temp=*s;-
    while(LCD12864_temp != 0x00) -
        LCD12864_data(LCD12864_temp);-
        LCD12864_temp=*(++s);-
//          繪制一幅圖片-
void LCD12864_picture(unsigned char *gImage) -
    unsigned char X = 0x80,Y = 0x80;-
    unsigned char i,j;-
    for(i=0;i<64;i++) -
        for(j=0;j<16;j++) -
            LCD12864_command(0x34);-
            LCD12864_command(Y);-
            LCD12864_command(X);-
            LCD12864_data(*(gImage+i*16+j));      //  low 8 bits-
            LCD12864_data(*(gImage+i*16+j+1));    //  high 8 bits-
            LCD12864_command(0x36);-
            X++;-
            j++;-
        Y++; -
        if(Y>0x9f) -
            Y=0x80; -
        X=0x80+((i+1)/32)*8; -
    LCD12864_command(0x30);-
//          初始化設(shè)置-
void LCD12864_init(void)-
    CLERADISPLAY    //  clear DDRAM-
    LCD12864_command(0x30);     //  8 bits unsigned interface,basic instrument-
    LCD12864_command(0x02);     //  cursor return-
    LCD12864_command(0x0c);     //  display,cursor on-
    LCD12864_command(0x03);   -
    LCD12864_command(0x06);-
0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 上半屏行坐標(biāo),表示的是多少列
0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 下半屏行坐標(biāo),每組8列,每列16位,共128位,
0x80
0x81
0x82
0x83
0x9f    //列坐標(biāo),共32個,表示的是行數(shù) ,分兩個半屏,每個32行,共64行
         //Y坐標(biāo) 只是用來確定具體坐標(biāo),在哪一行
   功能:圖形模式下,顯示(X,Y)點
        輸入:X(0~127) Y(0~63) 相對屏幕坐標(biāo)
        輸出:無
點亮某一點的操作步驟: 1.求出水平坐標(biāo)X對應(yīng)的地址和是哪一位  0x80-----0x8f  (范圍0-15) X/16求地址 X%16求該地址哪一位
         2.求垂直坐標(biāo)Y對應(yīng)的地址和上下半屏  0x80------0x9f(范圍0-63) Y本身就是8位地址,Y=63-Y ,Y--(0-31)
         3.寫入行列地址(Y是行X是列),0x80+Y  ,0X80+X/16
                       4.讀要顯示的數(shù)據(jù) DAT
                       5.區(qū)分上下半屏(X%16<=7&&X%16>=0是上半屏)寫入數(shù)據(jù)每一位 DAT|0x80 ;DAT<<1
             注意:這個函數(shù)顯示某一點時,可能會把上次顯示的處于同一地址的其他位的點擦掉,所以先保存所有數(shù)據(jù),最后顯示,就連貫起來了
//------------------清整個GDRAM空間----------------------------
void clrgdram()
    unsigned char x,y ;
    for(y=0;y<64;y++)
    for(x=0;x<16;x++)
       LCD12864_command(y+0x80);
       LCD12864_command(x+0x80);
      LCD12864_data(0x00);
/*******8==========================================================================
功能:圖形模式下,顯示(X,Y)點
輸入:X(0~127) Y(0~63)
輸出:無
0x80 0x81 0x82 0x83 0x84 0x85 0x86 0x87 上半屏行坐標(biāo),表示的是多少列,X地址
0x88 0x89 0x8a 0x8b 0x8c 0x8d 0x8e 0x8f 下半屏行坐標(biāo),X地址 (水平地址 )
0x80  (垂直地址)
0x81
0x82
0x83
void LCD12864_Drawpoint(uchar X,uchar Y)
     uchar i= 0, j = 0,ok=0;
     uchar temp1 = 0x00,temp2 = 0x00;
     LCD12864_command(0x34);  //8位,擴(kuò)充指令,繪圖關(guān)
     LCD12864_command(0x36);  //8位,擴(kuò)充指令,繪圖開
     i = X/16;  //計算出X字節(jié)地址(0X80-0X8F)
     j = X%16;  //計算出該字節(jié)的具體位(0-15)
     //Y = 63 - Y;
   if(Y>=0 && Y<=31)//判斷上下半屏
        ok=1;
   else if(Y>=32 && Y<=63)//下半屏
       Y = Y - 32;//Y只有0-31共32個 地址
       i = i + 8;//X地址進(jìn)入下半屏 (0X88-0X8F)
    ok=1;
   if(ok)
     //讀數(shù)據(jù)操作
        LCD12864_command(0x80+Y);   //第一步:設(shè)置Y坐標(biāo),讀數(shù)據(jù)先寫地址,寫GDRAM時先寫垂直地址(0X80-0X9F)
        LCD12864_command(0x80+i);  //第二步:設(shè)置X坐標(biāo)
        LCD12864_ReadData();    //第三步:空讀取一次
        temp1 =LCD12864_ReadData();    //第四步:讀取高字節(jié),先讀高字節(jié)
        temp2 =LCD12864_ReadData();   //第五步:讀取低字節(jié)
          //圖形模式下的寫數(shù)據(jù)操作
         if(j>=0 && j<=7)   //判斷是高字節(jié)
         LCD12864_data(temp1|(0x80>>j));  //第三步:寫高字節(jié)數(shù)據(jù)
         LCD12864_data(temp2);      //第四步:寫低字節(jié)數(shù)據(jù)
         else if(j>7 && j<=15)   //判斷是低字節(jié)
              j = j - 8;
            LCD12864_data(temp1);
            LCD12864_data(temp2|(0x80>>j));  //改變字節(jié)里的位
//畫線
//畫水平線
void LCD12864_LineX(unsigned char X0, unsigned char X1, unsigned char Y)
 unsigned char Temp ;
 if( X0 > X1 )
 Temp = X1 ;    //交換X0 X1值
 X1 = X0 ;     //大數(shù)存入X1
 X0 = Temp;   //小數(shù)存入X0
for( ; X0 <= X1 ; X0++ )
LCD12864_Drawpoint(X0,Y);
//畫垂直線
void LCD12864_LineY( unsigned char X, unsigned char Y0, unsigned char Y1)
if( Y0 > Y1 )//交換大小值
Temp = Y1 ;
Y1 = Y0 ;
Y0 = Temp ;
for(; Y0 <= Y1 ; Y0++)
LCD12864_Drawpoint( X, Y0) ;
/**************畫圖************************/
  void LCD12864_DrawPicture( unsigned char code *pic)
    unsigned char i, j, k ;
        LCD12864_command(0x34);//開擴(kuò)充指令
        LCD12864_command(0x36);//開繪圖功能
for( i = 0 ; i < 2 ; i++ )//分上下兩屏寫
for( j = 0 ; j < 32 ; j++)//垂直地址遞加 ,行掃方式
  LCD12864_command( 0x80 + j ) ;//寫Y坐標(biāo)(Y的范圍: 0X80-0X9F )
if( i == 0 ) //寫X坐標(biāo)
LCD12864_command(0x80);//上半屏
LCD12864_command(0x88);//下半屏開始地址
for( k = 0 ; k < 16 ; k++ ) //寫一整行數(shù)據(jù)
 LCD12864_data( *pic++ );//前面只寫入首地址,后面依次寫入數(shù)據(jù),地址會自動遞增
LCD12864_command( 0x30);//恢復(fù)到一般模式
