/*------------------------------------------------------------------------------ 聲明: ①使用共陽數(shù)碼管,選位碼12、9、8、6接P3^0 ~ P3^3,如0xaa=1010 1010,左至右為0101 ②中間兩小數(shù)點(diǎn),點(diǎn)亮選3、8 ③a、b、c、d、e、f、g、h 分別接P1口個(gè)管腳 ④任意8位二進(jìn)制,如1100 0000,在共陽上顯示0 ⑤P2^2口接一個(gè)發(fā)光二極管 ⑥P0^0和P0^4分別接了兩個(gè)按鍵 -------------------------------------------------------------------------------*/ #include<reg52.h> sbit KEY1=P0^0; sbit KEY2=P0^4; sbit LED=P2^2; code unsigned char tab[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90}; unsigned char StrTab[4]; unsigned char minute=30,hour=20,second; //初始化為20:30 void delay(unsigned int cnt) { while(--cnt); } void Displaypro(void) //顯示處理函數(shù) { StrTab[0]=tab[hour/10]; //顯示小時(shí) StrTab[1]=tab[hour%10]; StrTab[2]=tab[minute/10]; //顯示分鐘 StrTab[3]=tab[minute%10]; } main() { TMOD|=0x01; //定時(shí)器0 10ms in 12M crystal 用于計(jì)時(shí) TH0=0xd8; //(65536-10000)/256 TL0=0xf0; //(65536-10000)%256 ET0=1; TR0=1; TMOD|=0x10; //定時(shí)器1 1.8ms in 12M crytal 用于動(dòng)態(tài)掃描 TH1=0xF8; //(65536-1808)/256 TL1=0xF0; //(65536-1808)%256 ET1=1; TR1=1; EA=1; Displaypro(); //調(diào)用顯示處理函數(shù) while(1) { if(!KEY1) { delay(10000); //延時(shí)一段時(shí)間(去抖動(dòng)) if(!KEY1) { hour++; if(hour==24) hour=0; Displaypro(); } } if(!KEY2) { delay(10000); if(!KEY2) { minute++; if(minute==60) minute=0; Displaypro(); } } } } void time1_isr(void) interrupt 3 using 0 //定時(shí)器1用來動(dòng)態(tài)掃描 { static unsigned char num; //TH1=0xf8; //TL1=0xf0; //中斷源每1.8ms向主程序發(fā)一個(gè)脈沖,執(zhí)行中斷程序 TH1=(65536-3600)/256; TL1=(65536-3600)%256; //不是因?yàn)檫@里出錯(cuò),掃描速度可以 switch(num) { case 0: P3=0x01; P1=StrTab[num];break; case 1: P3=0x02; P1=StrTab[num];break; case 2: P3=0x04; P1=StrTab[num];break; case 3: P3=0x08; P1=StrTab[num];break; default: break; } num++; if(num==4) num=0; } void time(void) interrupt 1 using 1 { static unsigned char count; //定義內(nèi)部靜態(tài)變量 TH0=0xd8; TL0=0xf0; count++; switch(count) { case 0: case 20: case 40: case 60: case 80: Displaypro(); break; //隔一段時(shí)間調(diào)用顯示處理函數(shù) case 50: P2=~P2;break; //每1s亮一下 case 100: P2=~P2;break; default: break; } if(count==100) { count=0; second++; if(second==60) { second=0; minute++; if(minute==60) { minute=0; hour++; if(hour==24) hour=0; } } } }
主函數(shù)中最主要的時(shí)鍵盤調(diào)節(jié)時(shí)間函數(shù),函數(shù)首先檢測(cè)按鍵是否按下,如果按下則端口接地,變?yōu)榈碗娖剑?br />
判斷語句if成立,就準(zhǔn)備調(diào)時(shí),但是首先延時(shí)delay(10000),主要目的時(shí)去抖動(dòng)。在進(jìn)行調(diào)節(jié)以后,都要調(diào)用顯
示處理函數(shù),對(duì)將要顯示的時(shí)間進(jìn)行處理。
在主函數(shù)不斷循環(huán)之中,中斷源要發(fā)送中斷請(qǐng)求,定時(shí)器1每1.8ms發(fā)送一個(gè)中斷請(qǐng)求,來顯示處理函數(shù)處
理過的時(shí)間,也就是每個(gè)數(shù)碼管位1.8*4=7.2ms掃描一次(顯示一次),定時(shí)器2每10ms發(fā)送一個(gè)中斷請(qǐng)求,每20*10ms=0.2s進(jìn)行一次顯示處理函數(shù),也就是每20個(gè)定時(shí)器
1脈沖,處理一次,且每50個(gè)定時(shí)器1脈沖,處理一次二極管閃爍。
但是最重要的是每100個(gè)中斷請(qǐng)求后,進(jìn)行second的加1操作。所以定時(shí)器1中的count定義為static。
這個(gè)程序還是存在問題的,在使用定時(shí)器觸發(fā)中斷,只需要一個(gè)中斷就足夠了,但是定時(shí)器的工作模式還是存在不明白的地方。但是我在下一個(gè)版本中修正了一些錯(cuò)誤地址:http://www.torrancerestoration.com/mcu/1052.html
硬件電路存在兩個(gè)問題,P0口的驅(qū)動(dòng)能力強(qiáng)于P1口,帶動(dòng)數(shù)碼管的時(shí)候,一般接P0口,即使是這樣有時(shí)候也需要加
下拉電阻,而不是限流電阻。
延時(shí)抖動(dòng)的問題,在用示波器后可以清晰的看出抖動(dòng)存在,及其周期,根據(jù)周期設(shè)定延時(shí)。
定時(shí)器工作模式及中斷優(yōu)先級(jí)問題,還有中斷機(jī)理,并行工作模式?
