___________________________________________ 功能:99秒計(jì)時(shí) 時(shí)間2010—7—18 ___________________________________________ #include<reg52.h> code unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char Dis_Shiwei; unsigned char Dis_Gewei; void delay(unsigned int cnt) { while(--cnt); } main() { TMOD |=0x01; //10ms in 12M crystal,工作在模式一,16位定時(shí)器 TH0=0xd8; TL0=0xf0; IE= 0x82; //打開(kāi)中斷 TR0=1; //打開(kāi)定時(shí)開(kāi)關(guān) while(1) { P0=Dis_Shiwei; P2=0; delay(300); P0=Dis_Gewei; P2=1; delay(300); } } void tim(void) interrupt 1 using 1 { static unsigned char second,count; TH0=0xd8; TL0=0xf0; count++; if (count==100) //100x10ms { count=0; second++; if(second==100) second=0; Dis_Shiwei=tab[second/10]; Dis_Gewei=tab[second%10]; } } /* 定時(shí)器設(shè)定為:TH0=0xd8;TL0=0xf0;經(jīng)確定時(shí)10ms。從程序開(kāi)始執(zhí)行,每當(dāng)主程序中的16位數(shù)發(fā)生溢出則觸發(fā)中斷,主程序保護(hù)現(xiàn)場(chǎng)并調(diào)用中斷子程序,也可以寫(xiě)為:TH0=(65536-10000)/256;TL0=(65536-10000)%256。秒脈沖的產(chǎn)生要求精確定時(shí)1s,實(shí)際情況可能有延誤。 1 0000 0000 0000 0000 1101 1000 1111 0000 ———————————— 0010 0111 0001 0000 Time=16(1+16+32+64+512)=16*625=10000us=10ms 主函數(shù)中的關(guān)于定時(shí)器和中斷的控制位: TMOD |=0x01; //模式選擇 TH0=0xd8; //高8位 TL0=0xf0; //低8位 IE= 0x82; //打開(kāi)中斷 TR0=1; //打開(kāi)定時(shí)開(kāi)關(guān)(定時(shí)器運(yùn)行控制位,置“1”啟動(dòng)定時(shí)器0) TMOD |= 0x01; //使用模式1,16位定時(shí)器 TH0=0x00; TL0=0x00; EA=1; //總中斷打開(kāi) ET0=1; //定時(shí)器中斷打開(kāi) TR0=1; //定時(shí)器開(kāi)關(guān)打開(kāi) */ ______________________________________________ 功能:99秒倒計(jì)時(shí) 時(shí)間:2010—7—18 ______________________________________________ #include<reg52.h> code unsigned char tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; unsigned char Dis_Shiwei; unsigned char Dis_Gewei; void delay(unsigned int cnt) { while(--cnt); } main() { TMOD |=0x01; //10ms in 12M crystal TH0=0xd8; TL0=0xf0; IE= 0x82; TR0=1; while(1) { P0=Dis_Shiwei; P2=0; delay(300); P0=Dis_Gewei; P2=1; delay(300); } } void tim(void) interrupt 1 using 1 { static unsigned char second=99,count; TH0=0xd8; TL0=0xf0; count++; if (count==100) { count=0; second--; if(second==0) { second=99; } Dis_Shiwei=tab[second/10]; Dis_Gewei=tab[second%10]; } }
