18B20溫度傳感器
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2010年10月04日   【字體:
_________________________________________________________
功能:數(shù)碼管顯示XX.XC標(biāo)示攝氏度,例如25.3C標(biāo)示當(dāng)前溫度
時間:2010—7—20
#include<reg52.h>
#include<math.h>
#include<INTRINS.H>
#define uint   unsigned int;
sbit seg1=P2^0;
sbit seg2=P2^1;
sbit seg3=P2^2;
sbit DQ=P1^3;
sfr dataled=0x80;
uint temp;
uchar flag_get,count,num,minute,second;
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
uchar  str[6];
void delay1(uchar MS);
unsigned int ReadTemperature(void);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void delay(unsigned int i);
main()
        unsigned char TempH,TempL;
        TMOD|=0x01;
        TH0=0xef;
        TL0=0xf0;
        IE=0x82;
        TR0=1;
        P2=0x00;
        count=0;
                str[5]=0x39;
                str[1]=tab[TempH/100];
                str[2]=tab[(TempH%100)/10];
                str[3]=tab[(TempH%100)%10]|0x80;
                str[4]=tab[TempL];
                if(flag_get==1)
                        temp=ReadTemperature();
                        if(temp&0x8000)
                                str[0]=0x40;
                                temp=~temp;
                                temp +=1;
                                str[0]=0;
                        TempH=temp>>4;
                        TempL=temp&0x0F;
                        TempL=TempL*6/10;
                        flag_get=0;
void tim(void) interrupt 1 using 1
        TH0=0xef;
        TL0=0xf0;
        num++;
        if (num==50)
                num=0;
                flag_get=1;
                second++;
                if(second>=60)
                        second=0;
                        minute++;
        count++;
        if(count==1)
                P2=0;
                dataled=str[0];
        if(count==2)
                P2=1;
                dataled=str[1];
        if(count==3)
                P2=2;
                dataled=str[2];
        if(count==4)
                P2=3;
                dataled=str[3];
        if(count==5)
                P2=4;
                dataled=str[4];
        if(count==6)
                P2=5;
                dataled=str[5];
                count=0;
        while(i--);
        unsigned char x=0;
        DQ = 1;
        delay(8);
        DQ = 0;
        delay(80);
        DQ = 1;
        delay(10);
        x=DQ;
        delay(5);
        unsigned char i=0;
        unsigned char dat = 0;
        for (i=8;i>0;i--)
                DQ = 0;
                dat>>=1;
                DQ = 1;
                if(DQ)
                        dat|=0x80;
                delay(5);
        return(dat);
        unsigned char i=0;
        for (i=8; i>0; i--)
                DQ = 0;
                DQ = dat&0x01;
                delay(5);
                DQ = 1;
                dat>>=1;
        delay(5);
        unsigned char a=0;
        unsigned int b=0;
        unsigned int t=0;
        Init_DS18B20();
        WriteOneChar(0xCC);
        WriteOneChar(0x44);
        delay(200);
        Init_DS18B20();
        WriteOneChar(0xCC);
        WriteOneChar(0xBE);
        a=ReadOneChar();
        b=ReadOneChar();
        b<<=8;
        t=a+b;
        return(t);
