DIY 1602時(shí)鐘可調(diào)節(jié)顯示
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2010年12月06日   【字體:
#include<reg52.h>
sbit key0 = P3^0;//時(shí)間調(diào)節(jié)分秒時(shí)切換
sbit key1 = P3^1; //時(shí)間加
sbit key2 = P3^2; //時(shí)間減
sbit lcdrw = P2^5;//讀寫(xiě)操作選擇,1讀 0寫(xiě)
sbit rs = P2^6;//寄存器選擇,1數(shù)據(jù) 0指令
sbit lcden = P2^7;//使能信號(hào)
uchar code table[] = {" 2010-10-22 FRI"};
uchar code table1[] = {"    00:00:00"};
uchar count,shi,fen,miao,s1num;
void delay(uint z)
 uint x,y;
 for(x = z;x > 0;x --)
  for(y = 110;y > 0;y --);
void write_com(uchar com)//寫(xiě)指令
 rs = 0;
 lcden = 0;
 P0 = com;
 delay(5);
 lcden = 1;
 delay(5);
 lcden = 0;
void write_date(uchar date)//寫(xiě)數(shù)據(jù)
 rs = 1;
 lcden = 0;
 P0 = date;
 delay(5);
 lcden = 1;
 delay(5);
 lcden = 0;
void init()
 uchar num;
 lcdrw = 0;
 lcden = 0;
 write_com(0x38);
 write_com(0x0c);
 write_com(0x06);
 write_com(0x01);//清零
 write_com(0x80); //液晶第一行地址
 for(num = 0;num < 15;num ++)
  write_date(table[num]);
  delay(5);
 write_com(0x80+0x40);//液晶第二行地址
 for(num = 0;num < 12;num ++)
  write_date(table1[num]);
  delay(5);
 TMOD = 0x01;
 TH0 = (65536-50000)/256;
 TL0 = (65536-50000)%256;
 EA = 1; // 開(kāi)中斷
 ET0 = 1; //定時(shí)器0中斷
 TR0 = 1; //啟動(dòng)定時(shí)器
void write_sfm(uchar add,uchar date)
 uchar shi,ge;
 shi = date/10;
 ge = date%10;
 write_com(0x80+0x40+add);
 write_date(0x30+shi);
 write_date(0x30+ge);
void keyscan()
 if(key0 == 0)
  delay(5);
  if(key0 == 0)
   s1num ++;
   while(!key0);
   if(s1num == 1)
    TR0 = 0;
    write_com(0x80+0x40+10);
    write_com(0x0f);
   if(s1num == 2)
    write_com(0x80+0x40+7);
   if(s1num == 3)
    write_com(0x80+0x40+4);
   if(s1num == 4)
    s1num = 0;
    write_com(0x0c);//不閃光標(biāo)
    TR0 = 1;
 if(s1num != 0)
   if(key1 == 0)
    delay(5);
    if(key1 == 0)
     while(!key1);
     if(s1num == 1)
      miao ++;
      if(miao == 60)
      miao = 0;
      write_sfm(10,miao);
     if(s1num == 2)
      fen ++;
      if(fen == 60)
      fen = 0;
      write_sfm(7,fen);
     if(s1num == 3)
      shi ++;
      if(shi == 24)
      shi = 0;
      write_sfm(4,shi);
   if(key2 == 0)
    delay(5);
    if(key2 == 0)
     while(!key2);
     if(s1num == 1)
       if(miao == 0)
        miao = 60;
        write_sfm(10,miao);
       miao --;
       write_sfm(10,miao);
     if(s1num == 2)
      if(fen == 0)
        fen = 60;
        write_sfm(7,fen);
       fen --;
       write_sfm(7,fen);
     if(s1num == 3)
        if(shi == 0)
        shi = 24;
        write_sfm(4,shi);
       shi --;
       write_sfm(4,shi);
 init();
  keyscan();
 // while(1);
void timer0() interrupt 1
 count ++;
 if(count == 20)
   count = 0;
   miao ++;
   if(miao == 60)
    miao = 0;
    fen ++;
    if(fen == 60)
     fen = 0;
     shi ++;
     if(shi ==24)
      shi = 0;
     write_sfm(4,shi);
    write_sfm(7,fen);
   write_sfm(10,miao);
