//----------------------------------------------------- //<<12*12點(diǎn)陣+音樂(lè)產(chǎn)生>> // MCU:89C51 晶振:12M //編寫(xiě)日期:2010。12。25 //編寫(xiě)人:李春起 #include <REG51.H> #define uchar unsigned char #define uint unsigned int uint a=0,a1=0,a2=0; uint miusfla,miust,mius=64536; uint disfla1,sta=0; char flag=0,mdflag=0; sbit k1=P3^2; sbit k2=P3^3; sbit YY=P3^1; uchar code tabfas[]={ //==============笑臉=================================== //P0口 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P1口 0x8E,0x4D,0xAB,0x57,0x5F,0x9F,0x9F,0x5F,0x5F,0xAF,0x4F,0x8F, 0x8E,0x4D,0xAB,0x97,0x9F,0x9F,0x9F,0x9F,0x9F,0xAF,0x4F,0x8F, //P2口 0x87,0x88,0x50,0x20,0xA4,0x68,0x68,0xA4,0x20,0x50,0x88,0x87, 0x87,0x88,0x50,0x20,0xA4,0x68,0x68,0xA4,0x20,0x50,0x88,0x87, //P0口 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, 0xFF,0xFF,0xFF,0xFF,0xFE,0xFD,0xFB,0xF7,0xEF,0xDF,0xBF,0x7F, //P1口 0x8E,0x8D,0xEB,0x87,0x8F,0xCF,0x4F,0x4F,0x4F,0xCF,0x0F,0x0F, //祝 0x0E,0x0D,0x8B,0xE7,0x8F,0x8F,0x0F,0x0F,0xEF,0x0F,0x0F,0x0F, //鐘 0x0E,0x0D,0x0B,0x87,0x4F,0x0F,0x0F,0xCF,0x0F,0x0F,0x0F,0x0F, //仕 0x0e,0xed,0xab,0xa7,0xef,0xaf,0xbf,0xaf,0xef,0xaf,0xaf,0x0f,//廉 0x0E,0x0D,0x8B,0xE7,0x8F,0x8F,0xEF,0x8F,0x8F,0x8F,0x0F,0x0F, //生 0x0E,0x0D,0x0B,0xE7,0x2F,0x2F,0x2F,0x2F,0xEF,0x0F,0x0F,0x0F, //日 //0x0E,0x4D,0xDB,0x67,0xCF,0x4F,0x0F,0x8F,0x4F,0x4F,0x2F,0x0F, //新 //0x0E,0x0D,0x8B,0x47,0x7F,0x4F,0xCF,0x4F,0x4F,0x4F,0x4F,0x0F, //年 0x0E,0x0D,0xEB,0x07,0x8F,0x8F,0xEF,0x8F,0x8F,0x8F,0x0F,0x0F, //快 0x0E,0x8D,0x4B,0x47,0x4F,0xAF,0x1F,0x0F,0x0F,0x0F,0x0F,0x0F, //樂(lè) 0xCE,0x2D,0x2B,0x27,0x4F,0x8F,0x8F,0x4F,0x2F,0x2F,0x2F,0xCF, //心形 0x0F,0x0F,0x2B,0x27,0xAF,0x6F,0xFF,0x6F,0xAF,0x2F,0x2F,0x0F, //李 0x0E,0x0D,0x2B,0xA7,0xAF,0xFF,0xAF,0xAF,0x2F,0x0F,0x0F,0x0F, //春 0x0E,0x0D,0x4B,0x47,0xEF,0x4F,0x4F,0x8F,0x8F,0x8F,0x0F,0x0F, //起 //0x0E,0xFD,0x5B,0x57,0x5F,0xFF,0x0F,0x4F,0x4F,0xCF,0x4F,0x0F, //題 0xCE,0x2D,0x2B,0x27,0x4F,0x8F,0x8F,0x4F,0x2F,0x2F,0x2F,0xCF, //心形 //P2口 0x08,0x04,0xFE,0x05,0x08,0x43,0x3E,0x02,0x3E,0x23,0x30,0x00, //祝 0x00,0x09,0x0A,0x7F,0x2A,0x08,0x0F,0x09,0x7F,0x09,0x0F,0x00, //鐘 0x00,0x02,0x01,0x7F,0x02,0x22,0x22,0x3F,0x22,0x22,0x02,0x00, //仕 0xc0,0x3f,0x88,0x6a,0x2a,0xff,0x2a,0xff,0x2a,0x6a,0xde,0x88,//廉 0x00,0x21,0x20,0x20,0x24,0x24,0x3F,0x24,0x24,0x20,0x20,0x00, //生 0x00,0x00,0x00,0x3F,0x22,0x22,0x22,0x22,0x3F,0x00,0x00,0x00, //日 //0x00,0x2A,0x5A,0xFF,0x1A,0x2A,0x40,0x3F,0x02,0x7E,0x02,0x00, //新 //0x08,0x09,0x0F,0x09,0x09,0x09,0xFF,0x09,0x09,0x09,0x08,0x00, //看 0x01,0x06,0x7F,0x22,0x14,0x0C,0x07,0x0C,0x14,0x27,0x24,0x00, //快 0x00,0x23,0x12,0x0E,0x22,0x7F,0x06,0x0A,0x13,0x22,0x00,0x00, //樂(lè) 0x03,0x04,0x08,0x10,0x20,0x60,0x20,0x10,0x08,0x04,0x02,0x01, //心形 0x00,0x00,0x11,0x11,0x12,0x52,0xFB,0x1A,0x16,0x11,0x11,0x00, //李 0x00,0x12,0x0A,0xFE,0xAB,0xAA,0xAA,0xFE,0x0A,0x12,0x00,0x00, //春 0x40,0x21,0x1D,0x09,0x1F,0x25,0x41,0x5D,0x54,0x53,0x58,0x00, //起 //0x84,0x45,0x35,0x3D,0x55,0x95,0x84,0xAF,0x9D,0x91,0xAF,0x80, //題 0x03,0x04,0x08,0x10,0x20,0x60,0x20,0x10,0x08,0x04,0x02,0x01, //心形 }; //----------------音符---------------------- uint code miusdata[]={ //祝你生日快樂(lè) 64260,64260,64399,64260,64579,64524,64260,64260, 64399,64260,64684,64580,64260,64260,64898,64777, 64580,64524,64399,64819,64819,64777,64580,64777, 64684,0, 64260,64260,64399,64260,64579,64524,64260,64260, 64399,64260,64684,64580,64260,64260,64898,64777, 64580,64524,64399,64819,64819,64777,64580,64684, 64580,0, 64580,64580,64684,64580,64819,64777,64580,64580, 64684,64580,64898,64819,64580,64580,65058,64968, 64819,64777,64684,65000,65000,64960,64819,64967, 64898,0, 64580,64580,64684,64580,64819,64777,64580,64580, 64684,64580,64898,64819,64580,64580,65058,64968, 64819,64777,64684,65000,65000,64960,64819,64898, 64819,0 }; //---------------節(jié)拍----------------------- uchar code miustime[]={ 40,40,80,80,80,160,40,40,80,80,80,160,40,40, 80,80,80,80,80,40,40,80,80,80,160,80, 40,40,80,80,80,160,40,40,80,80,80,160,40,40, 80,80,80,80,80,40,40,80,80,80,160,80, 40,40,80,80,80,160,40,40,80,80,80,160,40,40, 70,75,80,80,80,40,40,80,80,80,160,80, 40,40,80,80,80,160,40,40,80,80,80,160,40,40, 70,75,80,80,80,40,40,80,80,80,160,80, }; void delay500(); //==========按鍵========================================== void kk() { if(!k1){delay500();if(++flag>1)flag=0;else {a=72;a2=0;}sta=1;} if(!k2){delay500();if(++mdflag>1)mdflag=0;sta=1;} } //=========延時(shí)=========================================== void delay(uint m) { uint i,j; for(i=0;i<m;i++) { for(j=0;j<300;j++) {kk();if(sta){sta=0;goto abc;}} } abc:; } //------按鍵消拉動(dòng)用---------------- void delay500() { uint i1; P0=0XFF; P1=0X0F; P2=0X00; for(i1=0;i1<32000;i1++); } //=========定時(shí)器T0用于頻率產(chǎn)生和顯示====================== void time0() interrupt 1 { P0=0XFF; P1=0X0F; P2=0X00; TH0=mius>>8; TL0=mius&0xff; YY=~YY; switch(flag) { case 0:{ //笑臉 P0=tabfas[a]; P1=tabfas[a+24]; P2=tabfas[a+48]; if(++disfla1<700){if(++a>11)a=0;} if(disfla1>=700){if(++a>23)a=11;} if(disfla1>800){a=0;disfla1=0;} }break; case 1:{ //漢字 P0=tabfas[a]; P1=tabfas[a+192]; P2=tabfas[a+348]; if(++disfla1<500){if(++a>(a2+83))a=(a2+72);} else{if(++a>(a2+83))a=(a2+72);} if(disfla1>1000){a2+=12;disfla1=0;} if(a2>144){a2=0;} }break; default:break; } } //========定時(shí)器T1只用于顯示================================ void time1() interrupt 3 { P0=0XFF; P1=0X0F; P2=0X00; TH1=0xf8; TL1=0x30; switch(flag) { case 0:{ //笑臉 P0=tabfas[a]; P1=tabfas[a+24]; P2=tabfas[a+48]; if(++disfla1<700){if(++a>11)a=0;} if(disfla1>=700){if(++a>23)a=11;} if(disfla1>800){a=0;disfla1=0;} }break; case 1:{ //漢字 P0=tabfas[a]; P1=tabfas[a+192]; P2=tabfas[a+348]; if(++disfla1<500){if(++a>(a2+83))a=(a2+72);} else{if(++a>(a2+83))a=(a2+72);} if(disfla1>1000){a2+=12;disfla1=0;} if(a2>144){a2=0;} }break; default:break; } } ///////////////////////////////////////////////////////////// //=========================================================// //----------------主程序-----------------------------------// //=========================================================// ///////////////////////////////////////////////////////////// void main() { P0=0XFF; P1=0X0F; P2=0X00; P3=0XFD; TMOD=0X11; TH0=mius>>8; TL0=mius&0xff; TH1=0xf8; TL1=0x30; TR0=1; ET0=1; TR1=0; ET1=1; EA=1; while(1) { switch(mdflag) { case 0:{//音樂(lè)暫停 TR0=0;TR1=1;kk();sta=0; }break; case 1:{ //音樂(lè)繼續(xù) TR0=0; delay(1); TR0=1; mius=miusdata[a1]; if(mius==0){TR0=0;TR1=1;} else {TR1=0;TR0=1;} delay(miustime[a1]); if(++a1>=104)a1=0; }break; default:break; } } }
