這幾天研究了市場(chǎng)上常見(jiàn)的無(wú)線遙控開(kāi)關(guān),它們的無(wú)線部分大都是用2262-2272編碼實(shí)現(xiàn),在網(wǎng)上找了些2262-2272軟解碼的資料,發(fā)現(xiàn)少的可憐,即使有實(shí)用性也不高,于是乎就有了這篇博客。
22262頻率計(jì)算公式為F=32000/Ros(KΩ)KHz,其中Ros為震蕩電阻,發(fā)送一位占用32個(gè)時(shí)鐘周期,其中起始位占用128時(shí)鐘周期。2262編碼格式如下圖:
‘F’只有地址為才有,數(shù)據(jù)位只有‘0’‘1’。
cc1101與stc單片機(jī)連接如下:
SI-P1.5;
SO-P1.6;
CLK-P1.7;
CS-P3.4;
GDO0-P4.2(CCP0);
GDO2-P4.3(CCP1);
cc1101配置如下:
0x08,//0x0B, // FSCTRL1 Frequency synthesizer control. 0x00, // FSCTRL0 Frequency synthesizer control. 0x0c, // FREQ2 Frequency control word, high byte. 0x1d,//0xAA,//, // FREQ1 Frequency control word, middle byte. 0x89,//0x55,// // FREQ0 Frequency control word, low byte. 0xc6,//0x8A, //2d MDMCFG4 Modem configuration. 0x45,//0x01, //3B MDMCFG3 Modem configuration. 0xb2,//0x73, // MDMCFG2 Modem configuration. 0x02,//0xA2, // 22 MDMCFG1 Modem configuration. 0xF8, // MDMCFG0 Modem configuration. 0x00, // CHANNR Channel number. 0x40,//0x00, // DEVIATN Modem deviation setting (when FSK modulation is enabled). 0x56,//0xB6, // FREND1 Front end RX configuration. 0x11, //10 FREND0 Front end RX configuration. 0x18, // MCSM0 Main Radio Control State Machine configuration. 0x00, //0x0f, //MCSM1 //0x30, 0x16,//0x1D, // FOCCFG Frequency Offset Compensation Configuration. 0x6c,//0x1C, // BSCFG Bit synchronization Configuration. 0x43,//0xC7, // AGCCTRL2 AGC control. 0x40,//0x00, // AGCCTRL1 AGC control. 0x93,//0xB2, // AGCCTRL0 AGC control. 0xe9,//0xEA, // FSCAL3 Frequency synthesizer calibration. 0x2A,//0x0A, // FSCAL2 Frequency synthesizer calibration. 0x00, // FSCAL1 Frequency synthesizer calibration. 0x1f, // FSCAL0 Frequency synthesizer calibration. 0x59, // FSTEST Frequency synthesizer calibration. 0x81,//0x88, // TEST2 Various test settings. 0x35,//0x31, // TEST1 Various test settings. 0x09, // TEST0 Various test settings. 0x09, // IOCFG2 GDO2 output pin configuration. 0x4d, // IOCFG0D GDO0 output pin configuration. Refer to SmartRF?Studio User Manual for detailed pseudo register explanation. 0x00, // PKTCTRL1 Packet automation control. 0x30, // 05 PKTCTRL0 Packet automation control. 0x00, // ADDR Device address. 0x2e, // PKTLEN Packet length.
這里配置異步接收速度大約為2.1K,根據(jù)CC1101手冊(cè)說(shuō)明,異步接收時(shí),其發(fā)送頻率的誤差應(yīng)在設(shè)定接收頻率的1/8內(nèi),經(jīng)測(cè)試表明,此設(shè)置完全可以接受震蕩電阻為475的2262編碼。
這里要說(shuō)明一個(gè)問(wèn)題,我也沒(méi)有找出原因,cc1101在接收2262編碼時(shí),第一個(gè)起始位和第一個(gè)數(shù)據(jù)電平接收不到,大概會(huì)丟失132-140個(gè)震蕩周期,這個(gè)可以用一個(gè)cc1101和一個(gè)超再生接收模塊接收相同的數(shù)據(jù)在示波器上看出,但并不影響數(shù)據(jù)接收,因?yàn)橐话?262編碼至少會(huì)發(fā)送4次以上。
GDO0在接收時(shí)為數(shù)據(jù)輸出,在發(fā)送時(shí)自動(dòng)配置為數(shù)據(jù)輸入,將STC的ccp0上升沿和下降沿捕獲打開(kāi),并將ccp0跳轉(zhuǎn)至P4.2。
2262軟解碼的關(guān)鍵在于找到正確的起始位。使用定時(shí)器0資源,配置成16位向上計(jì)數(shù)器,初始值為0x0000。過(guò)程如下:ccp0第一次捕獲到上升沿時(shí),啟動(dòng)定時(shí)器計(jì)數(shù),捕獲到下降沿時(shí)停止定時(shí)器并記錄下此時(shí)TH0和TL0的計(jì)數(shù)并重新啟動(dòng)定時(shí)器,再一次捕獲到上升沿時(shí)停止定時(shí)器并記錄下TH0和TL0的值重啟定時(shí)器,此時(shí)已讀取到一個(gè)高電平和低電平的寬度了,然后比較,看低電平寬度是否為高電平寬度的30-33倍,如果是則可以認(rèn)為是2262編碼的起始位,如果不是,則如此循環(huán)直到找到比例合適的。
找到起始位后,循環(huán)捕獲,至少捕獲兩個(gè)2262編碼周期,因?yàn)镺OK/ASK方式太不穩(wěn)定了,取兩次解碼比較如果相同才能認(rèn)為是正確的。
假定捕獲完畢,到解碼過(guò)程了,注意到2262編碼規(guī)則,每位需要四個(gè)電平寬度來(lái)表示,其實(shí)可以不管是否為高電平或低電平,只需注意四個(gè)電平的比例規(guī)則:
‘0’1:3,1:3
‘1’3:1,3:1
‘F’1:3,3:1
還要注意一點(diǎn),2262編碼中‘F’只能出現(xiàn)在地址碼中,如果在數(shù)據(jù)碼中出現(xiàn)了‘F’,則可認(rèn)為解碼錯(cuò)誤。
