/*************簡(jiǎn)易數(shù)控電壓表************************** 程序功能:輸出可調(diào)0~5伏電壓,步進(jìn)值為0.1V 涉及芯片:1602液晶、TLC5615、TLC549、AT89S52單片機(jī) ******************************************************/ #include<reg52.h> #define uint unsigned int #define uchar unsigned char uchar code num[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39}; /*uchar code dianya[]={21,41,65,84,104,125,145,166,186,206,227,247,267, 288,308,330,350,370,392,412,432,452,472,494,514, 534,556,576,596,616,636,658,678,698,720,740,760, 780,802,822,842,862,884,904,924,944,964}; */ sbit key1=P1^0; sbit key2=P1^1; sbit key3=P1^2; sbit key4=P1^3; sbit din=P3^0; sbit scl=P3^1; sbit cs1=P3^2; sbit clock=P3^3;//時(shí)鐘線 sbit dout=P3^4;//數(shù)據(jù)輸出端 sbit cs=P3^5;//片選(低電平有效) sbit rs=P2^0;//數(shù)據(jù)/命令選擇端(H/L) sbit rw=P2^1;//讀/寫(xiě)選擇端(H/L) sbit en=P2^2; //使能選擇端 uchar bdata date; //位尋址 sbit date7=date^7; sbit date6=date^6; sbit date5=date^5; sbit date4=date^4; sbit date3=date^3; sbit date2=date^2; sbit date1=date^1; sbit date0=date^0; /****************函數(shù)聲明**********************/ void delay(uint time); void write_com(uchar mingling); void write_date(uchar shuju); void chushihua(); void delayus(uint t) { while(t--); } void write_sip5615(uchar k) { date=k; din=date7; scl=0; scl=1; din=date6; scl=0; scl=1; din=date5; scl=0; scl=1; din=date4; scl=0; scl=1; din=date3; scl=0; scl=1; din=date2; scl=0; scl=1; din=date1; scl=0; scl=1; din=date0; scl=0; scl=1; } void write_5615(uint k) { k<<=2; cs1=0; write_sip5615(k>>8); write_sip5615(k); cs1=1; } uchar read_549()//數(shù)據(jù)得采集 { uint i; uchar k=0x00;//定義一個(gè)變量k,將在dout上采集的到的數(shù)據(jù)裝進(jìn)K dout=1;//該地方置不置高電平都可以,應(yīng)為單片機(jī)的I/O口默認(rèn)值為高點(diǎn)平 for(i=0;i<8;i++) { if(dout) { k|=(0x80)>>i; } clock=1;//高電平期間采集dout線上的數(shù)據(jù) clock=0; delayus(10); } return k;//返回值 } uchar shuchu_549()//數(shù)據(jù)得讀取 { uchar date; cs=0;//片選低電平時(shí)數(shù)據(jù)有效 date=read_549();//將read_549()函數(shù)中采集到的數(shù)據(jù)付給變量date cs=1;//片選拉高,表示數(shù)據(jù)讀取完畢 delayus(50); return date;//返回值 } void main() { uint i=0,n=0,m=0; uchar k0,k1,k2,k3,k4,temp; uchar t1,t2,t3,t4; chushihua(); write_5615(0); write_com(0x80+0x00); write_date('O'); write_com(0x80+0x01); write_date('X'); write_com(0x80+0x03); write_date('N'); write_com(0x80+0x04); write_date('u'); write_com(0x80+0x05); write_date('m'); write_com(0x80+0x06); write_date(':'); write_com(0x80+0x40); write_date('D'); write_com(0x80+0x41); write_date('i'); write_com(0x80+0x42); write_date('a'); write_com(0x80+0x43); write_date('n'); write_com(0x80+0x45); write_date('Y'); write_com(0x80+0x46); write_date('a'); write_com(0x80+0x47); write_date(':'); write_com(0x80+0x4a); write_date('.'); write_com(0x80+0x4f); write_date('V'); while(1) { if(key1==0) { n++; if(n==50)n=0; while(!key1); } if(key2==0) { n--; if(n==0)n=50; while(!key2); } write_5615(20*n); delayus(30); k0=shuchu_549(); temp=k0; k1=k0/100; k2=k0%100; k3=k2/10; k4=k2%10; t1=(uint)(temp*0.0186); t2=(uint)(temp*0.186)%10; t3=(uint)(temp*1.86)%10; t4=(uint)(temp*18.6)%10; write_com(0x80+0x08);//代碼 write_date(num[k1]); write_com(0x80+0x09); write_date(num[k3]); write_com(0x80+0x0a); write_date(num[k4]); write_com(0x80+0x49);//電壓 write_date(num[t1]); write_com(0x80+0x4b); write_date(num[t2]); write_com(0x80+0x4c); write_date(num[t3]); write_com(0x80+0x4d); write_date(num[t4]); } } /*void delay(uint time)//延時(shí)函數(shù)(運(yùn)行的時(shí)間與晶振有關(guān)系) { uint i,j; for(i=time;i>0;i--) for(j=110;j>0;j--); } */ void write_com(uchar mingling)//命令輸入函數(shù) { uchar gao,di; //定義高、低四位 gao=mingling&0xf0;//分出高四位 di=(mingling<<4)&0xf0;//分出低四位 //==========================================讀走高四位 P2=gao;//讓數(shù)據(jù)(mingling)高四位有效 rs=0;//rs端為低電平時(shí),為接收命令 delayus(8); en=1; //en一個(gè)高脈沖讀走高四位數(shù)據(jù)(mingling) delayus(10); en=0;//把使能端拉回低電平 //============================================讀走低四位 delayus(8); P2=di;//讓數(shù)據(jù)(mingling)低四位有效 rs=0;//rs端為低電平時(shí),為接收命令 delayus(8); en=1 ;//en一個(gè)高電平讀走低四位命令(mingling) delayus(10); en=0;//把使能端拉回低電平 } void write_date(uchar shuju)//數(shù)據(jù)輸入函數(shù) { uchar gao,di; gao=shuju&0xf0;//分出高四位 di=(shuju<<4)&0xf0;//分出低四位 //=======================================讀走高四位 P2=gao;//讓數(shù)據(jù)(shuju)高四位有效 rs=1;//rs端為高電平時(shí),為接收數(shù)據(jù) delayus(8); en=1;//en一個(gè)高電平讀走低四位數(shù)據(jù) (shuju) delayus(10); en=0;//把使能端拉回低電平 //============================================讀走低四位 delayus(8); P2=di;//讓數(shù)據(jù)(shuju)低四位有效 rs=1;//rs端為高電平時(shí),為接收數(shù)據(jù) delayus(8); en=1;//en一個(gè)高電平讀走低四位數(shù)據(jù)(shuju) delayus(10); en=0;//把使能端拉回低電平 } void chushihua() { rw=0;//把數(shù)據(jù)/命令選擇端先置為零 en=0;//把使能端先置為零 write_com(0x28);//設(shè)置16*12顯示,5*7點(diǎn)陣,4位數(shù)據(jù)接口 write_com(0x01);//清屏 write_com(0x0c);//顯示開(kāi)啟,不顯示光標(biāo) write_com(0x06);//整屏不移動(dòng) }
