/****************簡(jiǎn)易信號(hào)發(fā)生器**************************** 程序功能:輸出正弦波、鋸齒波、方波、三角波 涉及芯片:TLC5615 **********************************************************/ #include<reg52.h> #define uint unsigned int #define uchar unsigned char sbit din=P3^0; sbit scl=P3^1; sbit cs1=P3^2; sbit key1=P1^0; sbit key2=P1^1; sbit key3=P1^2; sbit key4=P1^3; //sbit w2= P1^0; uchar code sine_tab[256]={ //輸出電壓從0到最大值(正弦波1/4部分) 0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab, 0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4, 0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1, 0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff, 0xff,0xff,0xff,0xff, //輸出電壓從最大值到0(正弦波1/4部分) 0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7, 0xf6,0xf5,0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde, 0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba, 0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d, 0x89,0x86,0x83,0x80, //輸出電壓從0到最小值(正弦波1/4部分) 0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55, 0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b, 0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e, 0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00, 0x00,0x00,0x00,0x00, //輸出電壓從最小值到0(正弦波1/4部分) 0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02,0x02,0x03,0x04,0x05,0x06,0x07,0x08, 0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,0x1a,0x1c,0x1e,0x20, 0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,0x40,0x43,0x45, 0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66,0x69,0x6c,0x6f,0x72, 0x76,0x79,0x7c,0x80}; uchar bdata date; //位尋址 sbit date7=date^7; sbit date6=date^6; sbit date5=date^5; sbit date4=date^4; sbit date3=date^3; sbit date2=date^2; sbit date1=date^1; sbit date0=date^0; void delay(uint t) { while(t--); } void write_sip5615(uchar k) { date=k; din=date7; scl=0; scl=1; din=date6; scl=0; scl=1; din=date5; scl=0; scl=1; din=date4; scl=0; scl=1; din=date3; scl=0; scl=1; din=date2; scl=0; scl=1; din=date1; scl=0; scl=1; din=date0; scl=0; scl=1; } void write_5615(uint k) { k<<=2; cs1=0; write_sip5615(k>>8);//送高八位 write_sip5615(k);//送低八位 cs1=1; } void main() { uint k1=0,k2=0,k3=0,k4=0,i=0,j=0,x=0,z,p; while(1) { /* w2=0; delay(500); w2=1; delay(500); */ if(key1==0)//按鍵1檢測(cè) { k1=1; k2=0,k3=0,k4=0; while(!key1); } if(key2==0) //按鍵2檢測(cè) { k2=1; k3=0,k1=0,k4=0; while(!key2); } if(key3==0)//按鍵3檢測(cè) { k3=1; k1=0,k2=0,k4=0; while(!key1); } if(key4==0)//按鍵4檢測(cè) { k4=1; k1=0,k2=0,k3=0; while(!key2); } if(k1==1)//正弦波 { write_5615(sine_tab[i]); i++; delay(100); if(i==256)i=0; } if(k2==1)//鋸齒波 { write_5615(j); j++; delay(100); if(j==250)j=0; } if(k3==1)//方波(次處用單片機(jī)的I/O效果更好) { write_5615(10); delay(10000); write_5615(200); delay(10000); } if(k4==1)//三角波 { for(z=0;z<301;z++) { delay(50); write_5615(z); if(z==300) { for(p=300;p>0;p--) { if(p==0)break; write_5615(p); delay(50); } } } } } }
