功能說(shuō)明:
利用定時(shí)器1的定時(shí)模式制作一個(gè)秒表。
電路說(shuō)明:
HT48R50A-1 的端口A,端口C控制4個(gè)共陽(yáng)極七段顯示器以顯示秒表的s及1/100s。
HT48R50A-1 的復(fù)位鍵SW1作為秒表的開(kāi)始計(jì)時(shí),停止計(jì)時(shí)和回零按鍵。
程序:
; *************************************************** ; * Filename : 9712a.ASM * ; * Function : Stop watch * ; * Microprocessor : HT48R50A-1/28SKDIP-A * ; * Crystal : 4MHz * ; *************************************************** #INCLUDE HT48R50A-1.INC TIMER_START EQU 55H TIMER_STOP EQU 66H ;---------------------------------------------------- DATA .SECTION AT 60H 'DATA' WARM_RESET DB ? ;[60H] DELAY_COUNTER DB ? ;[61H] DISPLAY_DATA DB ? ;[62H] DISPLAY_COUNTER DB ? ;[63H] DISPLAY_SHIFT DB ? ;[64H] SECOND DB 4 DUP(?);[65H] ;---------------------------------------------------- CODE .SECTION AT 00H 'CODE' ORG 00H JMP START ORG 0CH JMP TIMER1 ORG 20H START: CLR PAC CLR PCC MOV A,WARM_RESET SUB A,TIMER_START SZ ACC JMP TIMER_STOP_C MOV A,TIMER_STOP MOV WARM_RESET,A JMP TIMER_START_GO TIMER_STOP_C: MOV A,WARM_RESET SUB A,TIMER_STOP SZ ACC JMP TIMER_ONE CLR WARM_RESET JMP DISPLAY TIMER_ONE: MOV A,TIMER_START MOV WARM_RESET,A CALL CLEAN JMP DISPLAY TIMER_START_GO: MOV A,09H MOV INTC,A MOV A,80H MOV TMR1C,A MOV A,0F0H MOV TMR1L,A MOV A,0D8H MOV TMR1H,A SET TMR1C.4 CALL CLEAN TIMER: MOV A,OFFSET SECOND MOV MP1,A MOV A,R1 SUB A,0AH SZ ACC JMP DISPLAY CLR R1 INC MP1 INC R1 MOV A,R1 SUB A,0AH SZ ACC JMP DISPLAY CLR R1 INC MP1 INC R1 MOV A,R1 SUB A,0AH SZ ACC JMP DISPLAY CLR R1 INC MP1 INC R1 MOV A,R1 SUB A,06H SZ ACC JMP DISPLAY CALL CLEAN DISPLAY: MOV A,OFFSET SECOND MOV MP0,A MOV A,0FEH MOV DISPLAY_SHIFT,A MOV A,04H MOV DISPLAY_COUNTER,A DISPLAY_LOOP: MOV A,R0 MOV TBLP,A TABRDL DISPLAY_DATA MOV A,DISPLAY_DATA MOV PA,A MOV A,DISPLAY_SHIFT MOV PC,A INC MP0 RL DISPLAY_SHIFT CALL DELAY SDZ DISPLAY_COUNTER JMP DISPLAY_LOOP MOV A,WARM_RESET SUB A,TIMER_STOP SZ ACC JMP DISPLAY JMP TIMER RET ;---------------------------------------------------- TIMER1: INC SECOND RETI ;---------------------------------------------------- CLEAN PROC MOV A,OFFSET SECOND MOV MP1,A MOV A,04H MOV DISPLAY_COUNTER,A CLEAN_LOOP: CLR R1 INC MP1 SDZ DISPLAY_COUNTER JMP CLEAN_LOOP RET CLEAN ENDP ;---------------------------------------------------- DELAY PROC MOV A,0FFH MOV DELAY_COUNTER,A WAIT: SDZ DELAY_COUNTER JMP WAIT RET DELAY ENDP ;---------------------------------------------------- ORG 0F00H DC 081H,0CFH,092H,086H ;0123 DC 0CCH,0A4H,0A0H,08FH ;4567 DC 080H,084H ;89 ;---------------------------------------------------- END
