專注電子技術(shù)學習與研究
當前位置:單片機教程網(wǎng) >> MCU設(shè)計實例 >> 瀏覽文章
曼徹斯特編碼的接收C51程序
作者:佚名   來源:本站原創(chuàng)   點擊數(shù):  更新時間:2012年01月18日   【字體:
曼碼接收程序,常用在無線信號的編碼與解碼中,給大家分享:
rxi()
    // this routine gets called every time TMR0 overflows
    if(T0IF)  //定時器中斷程序
        TMR0 = PERIOD;             // 裝計時器初值
        T0IF = 0;     // 清定時器溢出標志
        XTMR++;                     // 外部的系統(tǒng)時鐘計時器加1
        RFcount++;     // 脈沖寬度計數(shù)器加1
  return;
    if(RAIF)  //端口電平變化中斷程序
     if (RFFull)                 // 如果接收位滿就退出
         return;
  RFBit = RFIn;               // 取樣信號接收的值
  RAIF = 0;
     switch (RFstate)            // 當前狀態(tài)
      case TRFDATAUP:
    switch (RFcount)
        case 4:
        case 5:
        case 6:
        case 7:
      PORTA = PORTA;//啟動端口電平中斷
        break;
        case 8:
        case 9:
        case 10:
        case 11:
        case 12:
      B[Bptr] <<= 1;              // rotate
      if ( RFBit==0)  //如是有效的下跳變則該位的數(shù)據(jù)值為1,上跳變?yōu)?
       B[Bptr]+=1;          // shift in bit
      if ( ( ++BitCount & 7) == 0)
       Bptr++;                 // advance one byte
      if (BitCount == NBIT)
       RFstate = TRFreset;     // finished receiving
       RFFull = 1;
      RFcount=0; //重新記時
         break;
        default:  //超時或不足則退出接收
            RFstate = TRFSYNC;        // reset state machine in all other cases
            RFcount = 0;
            Bptr = 0;
            BitCount = 0;
   break;
   case TRFSYNC:
          if ( RFBit)
          { // rising edge detected  +---+                +---..
            //                       |   |  <-Theader->   |
              if ( ( RFcount < SHORT_HEAD) || ( RFcount >= LONG_HEAD))
                  RFstate = TRFreset;
                  break;                  // too short/long, no header
                  RFcount =0;             // restart counter
                  RFstate= TRFDATAUP;
          { // still low
              RFcount=0;
          break;
     case TRFreset:
     default:
         RFcount = 0;
         Bptr = 0;
         BitCount = 0;
         break;
     } // switch
    } //電平中斷
} // rxi
void InitReceiver()
IOCA = 2;
    T0IF = 0;
    T0IE = 1;                   // TMR0 overflow interrupt
RAIE = 1;     //使能端口電平變化中斷
    GIE = 1;                    // enable interrupts
    RFstate = TRFreset;         // reset state machine in all other cases
    RFFull = 0;                 // start with buffer empty
    XTMR = 0;                   // start extended timer
