// 本程序的電路很簡單就不畫圖了,就是8位數(shù)碼管的段選接在P0口,
//為了節(jié)約端口8個位接在了74hc138上,由P2.1 P2.0 P2.2控制譯碼器輸出位選.
//本程序完全測試通過.完整代碼下載地址: http://www.torrancerestoration.com/f/djsq.rar
/************8位數(shù)碼管倒計時顯示 時間格式24—00—00~~00-00-00**************/
#include <reg52.h>
sbit D0=P2^0; //定義數(shù)碼管片選參數(shù)
sbit D1=P2^1;
sbit D2=P2^2;
sbit D3=P1^2; //定義蜂鳴器輸出引腳
#define CLOCK_NUM 4 //動態(tài)定義鬧鐘的個數(shù)
struct SAVE_TIME {
uint save_hour;
uint save_minute;
uint save_second;
void key_scan_pro(void);
void Displaypro(void);
void Print_play_pro(void);
struct SAVE_TIME save_time[CLOCK_NUM]={0};
uchar code tab[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f}; //共陰極數(shù)碼管0—9
uchar StrTab[8]; //定義緩沖區(qū)
static uint minute=0,hour=24,second=0; //定義并初始化為 24:00:00
static uchar num=0;
static uchar temp,count1=1;
static uchar time_save_value=0;
void delay(uint z) //按鍵消抖延時函數(shù)
uint x,y;
for(x=z; x>0; x--)
for(y=110; y>0; y--);
void hour_add_pro(void) //小時加一減一處理函數(shù) KEY0
if(24==hour) { hour=24; minute=0; second=0; } //小時為24時,將分鐘和秒置零
else { hour++; }
Displaypro();
void hour_sub_pro(void) //KEY1
if(0==hour) { hour=0; }
else { hour--; }
Displaypro();
void minute_add_pro(void) //分鐘加一減一處理函數(shù) KEY2
if(59==minute) { minute=59; }
if((24==hour)&&(minute==0)){} //分鐘邊界壓力判斷,當(dāng)24:00:00,不允許往上加
else { minute++; }
Displaypro();
void minute_sub_pro(void) //KEY3
if(0==minute) { minute=0; }
else { minute--; }
Displaypro();
void second_add_pro(void) //秒加一減一處理函數(shù) KEY4
if(60==second) { second=60; }
else //秒邊界壓力判斷 當(dāng)24:00:00,不允許往上加
if((24==hour)&&(minute==0)) {}
else { second++; }
Displaypro();
void second_sub_pro(void) //KEY5
if(0==second) { second=0; }
else { second--; }
Displaypro();
void begin_suspend_pro(void) //開始/暫停處理函數(shù)
{ TR0 ^=0x1; }
void time_save_pro(void) //定時值保存函數(shù)
if(time_save_value<CLOCK_NUM)
save_time[time_save_value].save_hour = hour;
save_time[time_save_value].save_minute = minute;
save_time[time_save_value].save_second = second;
time_save_value++;
if(CLOCK_NUM==time_save_value) //循環(huán)調(diào)用鬧鐘
{ time_save_value=0; }
void clock_judge_pro(void) //鬧鐘值判斷函數(shù)
uchar i;
for(i=0; i< CLOCK_NUM; i++)
{ if((hour==save_time[i].save_hour)&&(minute==save_time[i].save_minute)&&(second==save_time[i].save_second))
{ TR0=0; TR1=1; } }
void time_init_pro(void) //定時器初始化函數(shù)
TMOD |=0x01; //定時器0 10ms inM crystal 用于計時
TH0=0xd8; //定時器初值10ms
TL0=0xf0;
ET0=1; //定時器/計數(shù)器T0中斷允許位
TR0=0; //TCON寄存器的TR0位 1:啟動T1/0 0:停止T1/0
TMOD |=0x10; //定時器1用于處理蜂鳴器
TH1=0xd8; //初值20ms
TL1=0xf0;
ET1=1;
TR1=0; //定時器的允許位
EA =1; //開總中斷
/********************************主函數(shù)***************************************/
void main(void)
time_init_pro(); //調(diào)用定時器初始化函數(shù)
Displaypro(); //調(diào)用顯示函數(shù)
key_scan_pro(); //不斷掃描按鍵
void key_scan_pro(void) //鍵盤掃描函數(shù)
D3=1;
Print_play_pro(); //調(diào)用顯示處理函數(shù)
P1=0xfe; temp=P1; temp&=0xf0;
while(temp!=0xf0) //按鍵消抖
delay(6); temp=P1; temp&=0xf0;
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xee: num=0;
hour_add_pro(); //按鍵0,1控制小時
break;
case 0xde: num=1;
hour_sub_pro();
break;
case 0xbe: num=2; //按鍵2,3控制分鐘
minute_add_pro();
break;
case 0x7e: num=3;
minute_sub_pro();
break;
default:
break;
while(temp!=0xf0)
{ temp=P1; temp&=0xf0; }
delay(6);
while(temp!=0xf0)
P1=0xfd; temp=P1; temp&=0xf0;
while(temp!=0xf0)
while(temp!=0xf0)
temp=P1;
switch(temp)
case 0xed: num=4; //按鍵4,5控制秒
second_add_pro();
break;
case 0xdd: num=5;
second_sub_pro();
break;
case 0xbd: num=6; //按鍵6控制開始/暫停處理函數(shù)
begin_suspend_pro();
break;
case 0x7d: num=7; //按鍵7控制定時保存函數(shù)
time_save_pro();
break;
default:
break;
while(temp!=0xf0)
delay(6);
while(temp!=0xf0)
StrTab[0]=tab[hour/10]; //存儲小時
StrTab[1]=tab[hour%10];
StrTab[2]=0x40; //存儲"-"
StrTab[3]=tab[minute/10]; //存儲分鐘
StrTab[4]=tab[minute%10];
StrTab[5]=0x40; //存儲"-"
StrTab[6]=tab[second/10]; //存儲秒
StrTab[7]=tab[second%10];
void Print_play_pro(void) //動態(tài)掃描數(shù)碼管
D0=1; D1=1; D2=1; //顯示秒
P0=StrTab[7];
delay(3);
D0=0;D1=1; D2=1;
P0=StrTab[6];
delay(3);
D0=1;D1=0; D2=1; //顯示"-"
P0=StrTab[5];
delay(3);
D0=0;D1=0;D2=1; //顯示分
P0=StrTab[4];
delay(3);
D0=1;D1=1;D2=0;
P0=StrTab[3];
delay(3);
D0=0;D1=1;D2=0; //顯示"-"
P0=StrTab[2];
delay(3);
D0=1;D1=0;D2=0; //顯示小時
P0=StrTab[1];
delay(3);
D0=0;D1=0;D2=0;
P0=StrTab[0];
delay(3);
/*****************************定時器1中斷*********************************/
void time1_isr(void) interrupt 3 //定時器1用來處理蜂鳴器
static uint count = 1; //位置待定
TH1=0xd8; //重入初值定時20ms
TL1=0xf0;
//Print_play_pro(); //抖動效果
count++;
D3=0; //產(chǎn)生鬧鐘方波
if(200==count)
TR0=1;
TR1=0;
count=1;
D3=1;
/***************************定時器0中斷**********************************/
void tim(void) interrupt 1 //定時器0用來處理倒計時
static uchar count; //定義內(nèi)部局部變量
TH0=0xd8; //重新賦值
TL0=0xf0;
count++;
switch (count)
case 80:Displaypro();break; //隔一定時間調(diào)用顯示處理
default:break;
if (count==100)
clock_judge_pro(); //定時時間判斷
count=0;
if((0==minute)&&(second==0)) //倒計時值處理
else { hour--; }
minute=60;
if(0==second)
if(0==minute) { minute=59; }
else { minute-=1; }
if(0==second) { second=60; }
else { second-=1; }
if((0==hour)&&(0==minute)&&(0==second)) //倒計時到00:00:00,結(jié)束倒計時
{ hour=0; minute=0; second=0; Displaypro(); TR0=0; }
