C0851F410與12864液晶顯示
作者:佚名   來(lái)源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2012年03月24日   【字體:
#include "C8051F410.h"
#define LCMdata P2
#define Busy 0x80
sbit RS  = P1^3;
sbit RW  = P1^4;
sbit E   = P1^5;
sbit PSB = P1^6;
sbit REST= P0^7;
//sfr16 TMR2RL = 0xCA;                   // Timer2 Reload Register
//sfr16 TMR2   = 0xCC;
void Display_String(uchar line,uchar *string);
void Wr_Data(uchar wrdata); //寫數(shù)據(jù)
void Wr_Command(uchar wrcommand,busyc); //寫指令
void RDbf(void);//讀忙狀態(tài)
void Lcm_Init(void);//液晶初始化
void Delay5Ms(void);//延時(shí)5ms
void write_show(uchar);
void SET_CGRAM(uchar,uchar);
void Dis_CG(uchar,uchar,uchar);
void Timer0Init(void);
uchar count,miao;
//uchar OS_Delay[1];
uchar code string_1[] = {"祖國(guó)江山好,    "};
uchar code string_2[] = {"愛情少不了。    "};
uchar code string_3[] = {"  溫度:00      "};
uchar code string_4[] = {"溫州大學(xué)--設(shè)計(jì)  "};
uchar code CGRAM_ZIKU[]={0x70,0x00,0x50,0x00,0x70,0x00,0x07,0xFC,0x1C,0x06,0x38,0x02,0x70,0x00,0x70,0x00,
   0x70,0x00,0x70,0x00,0x70,0x02,0x38,0x02,0x1C,0x0C,0x0F,0xF0,0x00,0x00,0x00,0x00};
void main(void)
 PCA0MD &= ~0x40;                    // Clear watchdog timer enable
 OSCICN = 0x81;
 while ((OSCICN & 0x40 ) == 0);      // Wait until stable
 P0MDOUT   = 0x80;
 P1MDOUT   = 0x78;
 P2MDOUT   = 0xFF;
 XBR1      = 0x40;
 Lcm_Init();
 Timer0Init() ;
 EA = 1 ;
 Display_String(1,string_1);
 Display_String(2,string_2);
 Display_String(3,string_3);
 Display_String(4,string_4);
 SET_CGRAM(1,&CGRAM_ZIKU);
 Dis_CG(2,6,1);
            if(count==20)
   count=0;
   miao++;
   if(miao==100)
    miao=0;
   write_show(miao);
void SET_CGRAM(uchar num,uchar *CGRAM_ZIKU)
 uchar i,add;
 Wr_Command(0x34);
 Wr_Command(0x02);
 Wr_Command(0x30);
 add=(num<<4)|0x40;
 for(i=0;i<16;i++)
  Wr_Command(add+i);
  Wr_Data(CGRAM_ZIKU[i*2]);
  Wr_Data(CGRAM_ZIKU[i*2+1]);
void Set_Cursor(uchar x,uchar y)
 uchar i;
 switch(x)
  case 0x00:i=0x80;break;
  case 0x01:i=0x90;break;
  case 0x02:i=0x88;break;
  case 0x03:i=0x98;break;
  default:break;
 i=y+i;
 Wr_Command(i);
void Dis_CG(uchar x,uchar y,uchar num)
 Set_Cursor(x,y);
 Wr_Data(0x00);
 Wr_Data(num*2);
void write_show(uchar date)//顯示計(jì)時(shí)
 uchar shi,ge;
 shi=date/10;
 ge=date%10;
 Set_Cursor(2,4);
 Wr_Data(0x30+shi);
 Wr_Data(0x30+ge);
void Display_String(uchar line,uchar *string)//顯示字符串
 uchar addr,i;
 if(line==1)
  addr=0x80;
 else if(line==2)
  addr=0x90;
 else if(line==3)
  addr=0x88;
 else if(line==4)
  addr=0x98;
 Wr_Command(addr,1);
 for(i=0;i<16;i++)
  Wr_Data(*string++);
void Wr_Data(uchar wrdata) //寫數(shù)據(jù)
 //RDbf();
 RS=1;
 RW=0;
 E=1;
 LCMdata=wrdata;
 E=0;
void Wr_Command(uchar wrcommand,busyc) //寫指令
 //if(busyc)
  //RDbf();
 RS=0;
 RW=0;
 E=1;
 LCMdata=wrcommand;
 E=0;
void RDbf(void) //讀忙狀態(tài)
  RS=0;
  RW=1;
  E=0;
  LCMdata=P2;
  E=1;
  if((LCMdata&Busy)==0)
   break;
void Lcm_Init(void)
     PSB = 1;
 Delay5Ms();
 REST=1;
 Delay5Ms();
 Wr_Command(0x30,0);
 Delay5Ms();
 Wr_Command(0x30,0); //2次顯示模式設(shè)置,不用判忙
 Delay5Ms();
 Wr_Command(0x0C,1); //開顯示及光標(biāo)設(shè)置
 Delay5Ms();
 Wr_Command(0x01,1); //顯示清屏
 Delay5Ms();
 Delay5Ms();
 Wr_Command(0x06,1); //顯示光標(biāo)移動(dòng)設(shè)置
 Delay5Ms();
TMOD &= 0xf0 ;
TMOD |= 0x01 ; //定時(shí)器0工作方式1
TH0 = 0xfc ; //定時(shí)器初始值
TL0 = 0x66 ;
TR0 = 1 ;
ET0 = 1 ;
void Time0Isr(void) interrupt 1
TH0 = 0xfc ; //定時(shí)器重新賦初值
TL0 = 0x66 ;
count++; //1MS時(shí)標(biāo)標(biāo)志位置位
void Delay5Ms(void) //延時(shí)5ms
 unsigned int TempCyc=5552;
 while(TempCyc--);
