最新的MSP430普通IO模擬IIC程序!
作者:佚名   來源:本站原創(chuàng)   點(diǎn)擊數(shù):  更新時(shí)間:2012年11月28日   【字體:
#include <GLOBAL.h>
#include <stdlib.h>
#include <stdbool.h>
#include <msp430x41x.h>
#define IicWpDirOut           P6DIR |=  BIT5
#define IicWpLow              P6OUT &=~ BIT5
#define IicWpHig              P6OUT |=  BIT5
#define IicSclDirOut          P6DIR |=  BIT6
#define IicSclLow             P6OUT &=~ BIT6
#define IicSclHig             P6OUT |=  BIT6
#define IicSdaDirOut          P6OUT &= ~BIT7
#define IicSdaLow             P6DIR |=  BIT7
#define IicSdaHig             P6DIR &=~ BIT7
#define IicSdaInSt            P6IN  &   BIT7
bool AckErr;
//------------------------------ *** - 時(shí)間延時(shí) - *** ------------------------------//
void Delay(unsigned int count)
   unsigned int i;
   _NOP();
   _NOP();
   for(i=count; i>0; i--);
void IIcDelay(void)
   _NOP();
//-----***-IIC初始化-***-----//
void IicInit(void)
IicWpDirOut;
IicSdaDirOut;
IicSclDirOut;
IicWpHig;
IicSdaHig;
IicSclHig;
//-----***-IIC啟示-***-----//
void IicStart(void)
      IicSdaHig;//IicSda=1;
      IIcDelay();
      IicSclHig;//IicScl=1;
      IIcDelay();
      IicSdaLow;//IicSda=0;
      IIcDelay();
      IicSclLow;//IicScl=0;
      IIcDelay();
//-----***-IIC停止-***-----//
void IicStop(void)
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-IIC應(yīng)答-***-----//
void SendAcknowledge(bool ack)
      IicSdaDirOut;
      if(ack)//IicSda=ack;
              IicSdaHig;
              IicSdaLow;
      IIcDelay();
      IIcDelay();
      IIcDelay();
//-----***-從slave端讀取一個(gè)數(shù)據(jù)-***-----//
unsigned char IicReceiveByte(void)
      unsigned char i;
      unsigned char bytedata=0;
      IicSdaDirOut;
      for(i=0;i<8;i++)
          IIcDelay();
          bytedata<<=1;
          if(IicSdaInSt)
                  bytedata |=0x01;
                  bytedata &=0xfe;
          IIcDelay();
      IicSdaDirOut;
      return bytedata;
//-----***-傳送一個(gè) Byte 數(shù)據(jù)到 slave-***-----//
void IicSentByte(unsigned char DataByte)
    unsigned char i;
    for(i=0;i<8;i++)
        if(DataByte & 0x80)
     DataByte <<=1;
     IIcDelay();
     IIcDelay();
     IIcDelay();
    IicSdaHig;//IicSda=1;-----Y------D---IicSdaDirIn
    IIcDelay();
    IIcDelay();
    IIcDelay();
//-----***-無扇區(qū)讀---多字節(jié)-***-----//
//讀取指定器件無扇區(qū)指定地址多字節(jié)數(shù)據(jù)到指定地址
//Device=器件地址---單字節(jié)
//DataAdd=字節(jié)地址---單字節(jié)
void IicMuchByteRead(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicStart();
    IicSentByte(0xa0);
    IicSentByte(DataAdd);
    IicStart();
    IicSentByte(0xa1);
    for(i=DataLend-1;i>0;i--)
          *DataDptr=IicReceiveByte();
          DataDptr++;
       SendAcknowledge(0);
    SendAcknowledge(1);
    IicStop();
    WDT();
    Delay(500);
    _EINT();
//-----***-無扇區(qū)寫---多字節(jié)-***-----//
//寫入指定器件無扇區(qū)指定地址中的多字節(jié)數(shù)據(jù)
//DataAdd=字節(jié)地址---雙字節(jié)
//DataByte=被存放數(shù)據(jù)的地址
//DataLend=被存放數(shù)據(jù)的長度
void IicMuchByteWrite(unsigned char DataAdd,unsigned char *DataDptr,unsigned char DataLend)
    unsigned char i;
    _DINT();
    WDT();
    IicInit();
    IicWpLow;
    IicStart();
    IicSentByte(0xa0);
    for(i=DataLend;i>0;i--)
        IicSentByte(*DataDptr);
        DataDptr++;
    IicStop();
    WDT();
    Delay(3500);
    IicWpHig;
    _EINT();
//---特別說明
//---利用430芯片來模擬IIC,是不能夠把SDA設(shè)置為輸出模式而是
//---設(shè)置為輸入,然后利用方向控制器來輸出高或者低
//---如下:
